Neat 6.7 engine tech article - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 03-03-2010, 10:52 PM   #1 (permalink)
First Look: Ford's All-New 6.7-Liter V-8 Power Stroke Diesel Engine - PickupTrucks.com News
turbo bearings cooled by water, two independent water systems (1 higher temp for the engine, 1 lower temp for trans, intercooler, fuel and EGR cooler), reverse flow aluminum heads. It has slanted connecting rods like the cummins and 6 bolts around each cylinder for strength.
They went all out in the diesel tech department.
I am thinking I would not want to have a year 1 motor no matter how cool it sounds on paper.
2002 Excursion Diesel-Stock owned 3 years 203k miles
Planning upgrades with the following order: durability, milage, power: 203 thermostat, Cat ELC, AIS delete, DieselSite engine and intercooler boots,
2002 VW Golf TDI-Nearly stock +taller 5th gear, LSD, 50+MPG, owned since new, 205k miles
I am 6'5" so the Golf is know as the clown car
ftboomer1 is offline
