P20E8 code - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 64 (permalink) Old 12-01-2012, 02:09 PM Thread Starter
Desert John's Avatar
P20E8 code
My 2011 F350 just started throwing a P20E8 code. "Reductant Pressure too Low". Can any body tell me what that means. Thanks for the help.
2001 F-250 SuperCab SRW 7.3L with AIC, Firestone air bags, Edge tuner, Ford HD air filter, 4" Turbo back exhaust, B&W turn over hitch, Fuel tank mod, A pillar gauges, Line X.
2011 F-350 Crew Cab SRW 6.7L Lariat Ultimate 4x4 with SEIC
Desert John is offline
post #2 of 64 (permalink) Old 12-01-2012, 03:30 PM
Reductant = DEF
Kevin
'13 F150 Ecoboost Screw Platinum 4x4, LineX Premium, Retrax1, Sterling Gray
Purchased 5/26/11... 2011 F250 Lariat CC SWB 6.7, LineX Premium, Retrax Pro.... 53k traded 12/24/12
Stolen 5/15/11... 2002 F250 XLT Sport SC SWB 7.3 304xxx, LineX, Retrax
KJ Smith is offline
post #3 of 64 (permalink) Old 12-01-2012, 05:43 PM
It means you most likely need a new pump assembly. Either the sensor or the pump itself is bad, and they are an assembly.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
post #4 of 64 (permalink) Old 12-05-2012, 04:25 PM
Reductant Pressure Too Low
Description: The powertrain control module (PCM) monitors reductant pressure as the system primes for injection. If the system pressure does not exceed 350 kPa (51 psi) within 45 seconds after the reductant pump starts, this DTC sets.
Possible Causes:
Damaged reductant pump
Damaged reductant purge valve
Damaged reductant pressure line
Damaged reductant injector
Damaged reductant pressure sensor
Diagnostic Aids The presence of this DTC may indicate that the vehicle is operating in derate mode and may experience a loss of power.
RyanP2317 is offline
post #5 of 64 (permalink) Old 12-05-2012, 04:32 PM
I just got my truck back . I dropped it off Monday night and picked it up the following Monday. I
2000,F250SD,SC,PSD,4X4,SB,6SPD.TRADED 2002 F250SD,CC,PSD,4X4,6SPD.TRADED Both bone stock,NO cackle!Rotella T,Stanadyne performance additive every tank.2 out of 2 an't bad. 2004 F350 CC 6.0 Torque shift,4X4,TRADED. 2008 F350 CC4X4 GAS!!!TRADED. 2011 F350 CC Lariat FX4 Back to DIESEL
TRADED. 2013 F350 CC Lariat ultimate 4x4 Ruby Red.
tomallen is offline
post #6 of 64 (permalink) Old 12-05-2012, 04:51 PM
Sorry about the incompleat post, my ham fingers hit the wrong button. My truck threw that code and they replaced the reductant tank assy and the reductant heater and sender assy. The code came up a few days after I had the NOX update done. I don't think it can be related but who knows. 20,400 miles still under warrenty
tomallen is offline
post #7 of 64 (permalink) Old 12-07-2012, 11:37 AM
FordService's Avatar
Hi Desert John and tomallen,
I want to step in here and get both of you escalated to your regional customer service managers. They can assist by working directly with your dealership on a resolution for your concerns. To get started, send me a PM with your VIN, dealer, mileage, daytime phone number, and full name.
Originally Posted by KJ Smith View Post
Reductant = DEF
Possible Causes:
Thanks for all the great info, gang! I'm sure Desert John appreciates it!
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
FordService is offline
post #8 of 64 (permalink) Old 10-08-2014, 09:24 AM
My 2011 F350 just threw this code yesterday. Went out of 3 year warranty 3 Sept 2014. Oh joy.
HillbillyGirl is offline
post #9 of 64 (permalink) Old 10-08-2014, 12:48 PM
Welcome to the forum, HillbillyGirl. What's the current mileage on your truck? Do you plan on having your dealership check it out?
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
post #10 of 64 (permalink) Old 10-09-2014, 07:37 AM
Hi Crystal.
She has 31236 on her currently. Went out of warranty the first week of Sept. I have a appointment for this coming Tuesday.
Hopefully it isn't too painful.
Hillbilly
post #11 of 64 (permalink) Old 10-09-2014, 11:12 AM
Hi Crystal.
Hillbilly
Come back and tell us how things go on Tuesday, Hillbilly. I'll be able to check out ways to help once this has been diagnosed by your dealer.
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
post #12 of 64 (permalink) Old 11-07-2014, 03:50 PM
Is there a difference between an exhaust temperature sensor and a DEF pressure sensor? Getting conflicting information from garages about the P20E8 code on my 2011 F-250.
wildcat06 is offline
post #13 of 64 (permalink) Old 11-07-2014, 04:29 PM
gearhead1011's Avatar
My Photos: (10)
Yes there is a difference. The exhaust temperature sensor is a thermocouple that measures exhaust gas temperature. The DEF pressure sensor measures fluid pressure.
P20E8 sets under the following conditions:
2012 F250 XLT
Sterling Grey
6.7 CCSB 4X4
gearhead1011 is offline
post #14 of 64 (permalink) Old 11-14-2014, 05:46 PM
knoweigh's Avatar
I too have just purchased a 2011 with 166k miles and has the p20e8 code (no other codes)
Definite noticeable power loss (mainly under heavy throttle) and fuel economy loss with that code. I just drove 1100 miles with it on.
Dealer replaced the pump only to the tune of $600
I told them prior to doing this that I've found many cases where other's have done the pump and didn't cure it so I wanted to make sure they understood that if it didn't fix the problem.......I'm not into "throwing parts" at something on the chance it'll fix it.
No kidding.......exactly 1 mile down the road light back on.
So I'm going back in Monday morning; they're a good dealer and I trust they'll take care of me on the $600 in the form of a refund or some sort of free services to make up for it. If not, I'll be disputing the charge on my credit card. I'll post back what I find out next week.
Is there anyone with more experience on this code that can shed light?
(not sure if there's a tank and sending unit as well that could have a problem that would throw that code???)
I"m guessing they'll need to pressure test the system.....and in my mind, it has to either be
-the pump (already replaced & no change)
-a line leak between pump and injector in exhaust
-the injector itself
But what do I know I'm a 7.3 junkie and the tree hugger system is all new to me! I understand they're trying to "help our environment" but.....is it REALLY helping our environment?
I really think this 6.7 could be a very reliable strong powerplant if it wasn't for the emssisions junk.
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 230k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
2011 6.7 Lariat 4x4 CCSB CM/TM bed w/b&w turnover 285/65r20
knoweigh is offline
post #15 of 64 (permalink) Old 11-16-2014, 01:05 AM
My Photos: (10)
I'm pretty sure the pump, sender (actually 3 sensors for fluid level) & tank are serviced as an assembly and it includes the reductant heater.
2012 F250 XLT
Sterling Grey
6.7 CCSB 4X4
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
