seic hookup - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 01-24-2013, 08:27 PM   #1 (permalink)
My Photos: (6)
seic hookup
I done a search and found the instructions to do the high idle hookup, my question is do you have to use a resistor or can it be like the 6.0 and just connect the wires? This will be on my new '13 F250 XLT 6.7. Any help.
05 F250 SD XLT Reg cab 4x4 Arizona Beige 6.0L PSD, AT, Advanced Security Group, ESOF, Fog Lights, Stabilizer Package, Tow Command System, Upfitter Switches, Aluminum Wheels, Cab Steps & Super Liner bedliner,Fumoto Valve, Air Lift Air Springs & Smart Air. Traded
2013 F250 SD XLT Reg Cab 4x4 Pale Adobe 6.7L PSD, 3.31Elock, AT, Tow Command, Upfitter Switches, Rear Camera, Aluminum Service Body,
stewcon is offline   Reply With Quote
Old 01-24-2013, 08:41 PM   #2 (permalink)
Resistor needed as per Ford upfitter SEIC instructions, see page 13-14 of the SEIC/PTO install book
~Wolf
'12 F550 Tux Black Lariat Supercab 186" WB , 4x4 6.7, 19.5GVW
13k lb hooklift, Cramaro auto tarp, Insta-chain automatic tire chains, Boss 9' SD plow, Atomic led cab marker/strobe
Custom~ fabbed rear bumper, tarp gantry, rear warning led setup, SEIC & rear strobe control panel (in the drivers side powerpoint trim)
And more to come
'99 F350 XLT CC LB 4x4 dually 7.3, Dents build character 408,000ish miles on the clock (2nd motor)
'93 Exploder Sport, 5.0 swap, 4r70w+Baumann TCS, Atlas 2 T-case 3.8:1 twin stick, Narrowed D44 '79 f150 solid axle swap, bunch o other junk...
'69 Ford rust bucket, err Bronco, "resto"/mods in the planning stages
Wolf451 is offline   Reply With Quote
Old 01-24-2013, 09:28 PM   #3 (permalink)
Resistor only costs about 15 cents.
2003 f350 fx4 6.o powerstroke
1997 f450 7.3 diesel
2012 f550 6.7 diesel
maxpayne is offline   Reply With Quote
Old 01-24-2013, 11:31 PM   #4 (permalink)
I'm surprised nobody makes a plug and play setup.
Richx350 is offline   Reply With Quote
Old 01-25-2013, 04:11 PM   #5 (permalink)
My Photos: (6)
Wolf451, thanks for the information. Is this book (SECI/PTO) availble, and where?
Richx350, that would be great if they did. Make it a lot easier. On my '05 6.0 it was simple but now it sounds a little more troublesome.
Thanks for all the replies.
Old 01-25-2013, 04:30 PM   #6 (permalink)
I looked and could not find one, so I built one for about $20 worth of parts.
Google ford body builders web site for the wiring diagrams.
2011 F350 Lariat DRW 6.7L
25' PJ Flatbed Equipment Trailer
2005 XLT F250 6.0L(Wife's truck)
2005 Bobcat T300
gtstang462002 is offline   Reply With Quote
Old 01-25-2013, 06:53 PM   #7 (permalink)
My Photos: (6)
Thanks gstang462002, that's what I was looking for.
Old 01-26-2013, 02:34 AM   #8 (permalink)
https://www.fleet.ford.com/truckbbas.../maintoc.html# Here ya go, Its in there somewhere.
~Wolf
And more to come
Old 01-28-2013, 07:38 AM   #9 (permalink)
lincster's Avatar
My Photos: (24)
Why do you "have" to use a resistor? Is something going to burn up if you don't? I'm not buying that one. My 2006 didn't have a resistor and worked just fine for 7 years.
2012 F350 4X4 Dually, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline   Reply With Quote
Old 01-28-2013, 09:53 AM   #10 (permalink)
The resistor value dictates the high idle speed. Different values will give you different RPMs. It's possible to put in a potentiometer and have it variable.
I don't know what no resister would do, but the lower the resistance, the higher the idle speed. According to the chart, 680 ohms would be 3,000 RPM
Hopeless Diamond is offline   Reply With Quote
Old 01-28-2013, 10:24 AM   #11 (permalink)
I think the newer SEIC looks for the resistance (voltage drop) before it will activate.
And here is where I put my SEIC knob, center off switch (stationary-off-live) and on/off light.
ETA: Switch, button and 4 leds on the left are for the rear warning light controls
~Wolf
And more to come
Old 01-28-2013, 11:25 AM   #12 (permalink)
That looks sharp, is that 12v power point a factory point on the '12? In my '11 that is a useless cubbyhole that holds nothing when you step on the gas. I put hidden switches in there for my hide-away strobes, complete with a dimmer switch that I never use and a pattern select button that I never use(I like the options and it was just as easy to do the hookups now rather than later). All of my aux switches are used up for various warning lights hence the reason i built a control box to be independent from everything else.
2005 Bobcat T300
Old 01-28-2013, 11:28 AM   #13 (permalink)
It just will not work with no resistor. To make the potentiometer work you will need a 50K ohm potentiomenter and a 680 ohm resistor to make the values work for the full RPM range.
2005 Bobcat T300
Old 02-18-2013, 10:36 PM   #14 (permalink)
Willie77's Avatar
Re: seic hookup
I have been reviewing a few posts about the high idle mod and i think I have a general understanding of it. But, i do have one question regarding using the high idle mod with the remote start. Most installations listed on here use one of the upfitter switches for power. . But since the up fitter switches dont get power until the key is turned on, the high idle cannot be set during a remote start. But if one were to get power from a constant 12v source, rather than the up fitter switch, would it be possible to remote start the truck with the seic on? Assuming the park brake was set
I am a huge fan of the cleanliness and simplicity of Wolf's install shown above. Could you share any part numbers for the switches and light you installed?
Sent from my ASUS Transformer Pad TF700T using AutoGuide.Com Free App
Current Truck:
'12 F250 6.7 Lariat, S/C SB 4wd,
Dark Blue Pearl with Sterling Grey accent
3.55 rear, FX4 Package, Upfitter Switches
Weatherguard Toolbox, cab rack, 8-strobe Whelen miniedge, Husky mudflaps.
Still waiting on the ventvisors, bugshield, and a few other ideas.
Former:
'03 F350 6.0L
300,000+ miles stock.Original turbo, head gaskets, EGR valve/cooler and oil cooler.
Supposedly the "first of the worst" 6.0's
Great Truck - Never let me down.
Willie77 is online now   Reply With Quote
Old 02-20-2013, 03:51 PM   #15 (permalink)
My Photos: (6)
Can I use the upfitter #3 that is a 10 amp circuit or do I need to use #4 that is a 15 amp circuit? Just like to save the heavier circuits for future use.
Carl
