Tranny Filter Tech - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 04-18-2013, 07:18 PM Thread Starter
Tranny Filter Tech
I read this article in Trailer Life magazine last fall and I thought it was quite fascinating. After having read it, my plan was to put an extra filter on the transmission as per the article. I'll post a couple quotes here:
On a new truck, it’s important to get the filter on right away to eliminate Type 1 debris and catch the Type II break-in material. On a used truck, you can install the filter at any time.
between the built-in Type 1 and Type II contaminants from break-in, the average new transmission will generate 75 percent of its lifetime contaminants in the first 5,000 miles. [...] Either you need to change that fluid early to get the contaminants out or start filtering better early.
I was wondering what you all's thoughts are on this?
-abe
abed'nego is offline
post #2 of 5 (permalink) Old 04-18-2013, 10:10 PM
Mark Kovalsky's Avatar
My Photos: (6)
My thoughts is that the SAE article that they quote is from 1998. That's a long time ago.
In 2008 Ford changed the TorqShift internal filter to a filter that is better than the Magnefine. The external filter was eliminated because it was no longer needed.
Adding a cooler line filter to one of these newer transmissions will just increase restriction and reduce cooling.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 04-18-2013, 10:31 PM Thread Starter
No doubt that a filter would be a bit of a restriction, but if sized properly the pressure drop, and therefore flow reduction, would be minimized and within spec.
But based on the article, and taking into consideration expertise given your previous employment, would you recommend swapping out the filter after the first 3K - 5K miles?
post #4 of 5 (permalink) Old 04-18-2013, 11:12 PM
My Photos: (6)
No, I would not.
As for the restriction, as long as you're sure it is within spec.
Mark
Former
post #5 of 5 (permalink) Old 04-19-2013, 01:22 AM
In my years of working on automatics or in shops where they are worked I see little that tells me that a filter will fix anything. Parts not hardened, seals that are cut or age harden, cost cutting low quality, or planetary gears that break teeth are not things a filter would impact.
The newest "fuzzy" filters capture and hold wear debris of harmful size well.
I would think that if the wear-in debris is really a concern for you then an early pan drop and filter change is the most cost effective thing you can do that might have a benefit.
Doing this does not introduce the risk of rubber hose for filter dumping the fluid and harming the transmission it was installed to save.
I have noticed a lot of articles in magazines that were short on real knowledge and long on "I need to come up with something for this month's column" or "I need to sell something advertised here".
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 136K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 241K (no engine repairs)
2007 BMW 550i 6MT 146K, Stuff breaking all the time that would last twice as long on a Kia or Hyundai, sad. Drives great though.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
