Transmission issues fixed on the 2012's??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 10-11-2011, 08:37 PM   #1 (permalink)
You guys with 2012 Super Duties having any of the shift flare issues, delays going into reverse, or erratic shifting of any kind that has been reported with the 2011's?
2011 F250 Lariat CC SRW 6.7L PSD
Duraflap Mud Flaps
Firestone Air Bags with Airlift wireless compressor
2011 Jayco Octane T29A Toy Hauler
2004 F250 Lariat CC SRW 6.0L PSD (Traded)
frt2599 is offline   Reply With Quote
Old 10-11-2011, 09:37 PM   #2 (permalink)
No problems so far but I only have 2200 miles.
7.399 is online now   Reply With Quote
Old 10-11-2011, 11:25 PM   #3 (permalink)
No delays going into reverse, however the trans has good days and poor days. Poor I mean not a smooth like my old duramax. This is my first ford in a long time and so maybe my trans is normal. Happy with the truck so far. The truck likes to have a full load and the trans is smooth under full load.
boyeraz is offline   Reply With Quote
Old 10-12-2011, 08:16 AM   #4 (permalink)
So far so good. I'm empty 80% of the time, and even with the box loaded with tools they probably aren't over 500lbs of weight. And the trans shifts great. It's definatly a firm shift but with a solid heavy duty feeling to it. No slipping, missing gears, or any of the other symptoms people are talking about.
InfernoSS is offline   Reply With Quote
Old 10-12-2011, 09:53 AM   #5 (permalink)
What scares me is since the 2012's aren't having the problem.
1. Ford found the problem, but can't justify repairing it properly and hoping the customer keeps past warranty.
2. There was a problem during assembly, on a certain few, maybe as minor as something not torqued to spec and ford cant find.
3. A batch of defective parts were used in job 1 trannies.
Serial Fordicator is offline   Reply With Quote
Old 10-12-2011, 10:38 AM   #6 (permalink)
Someone posted earlier that the 2012 transmissions have a new torque converter, fly wheel, and a bunch of internal part. So lets do the math, Ford designed a new tranny, which cost millions to develop I'm sure, used it for ONE year, then they change a few things. I'm pretty sure they know there is a problem with the 2011's, now they are just trying to patch them together and forget about us.
2011 CC Job 1, Short, XLT, 4X4, 6.7L, 3.55 E-Locker, Forest Green. Build Date 6/2010
vtboy51 is offline   Reply With Quote
Old 10-12-2011, 10:43 AM   #7 (permalink)
Yes but 2011 job 2 transmissions have not popped up yet with the same problems.
Old 10-12-2011, 11:17 AM   #8 (permalink)
I'm pretty sure there have been people posting here with Job 2 trucks with the same problems. And we have definitely had people with job 1 trucks not having the issues. It just proves that the parts used (all of 2011) were not being built with very good precision.
Old 10-12-2011, 12:44 PM   #9 (permalink)
Mine is job 2 , has the latest tsb with solenoids. It still shutters intermittently, have not been able to be verified by dealer. Ford has cut off all communications, including Cory. It looks like there aware, and working on a fix, or don't care and hoping the majority get out of warranty to keep cost down. I am going to hook up a video camera to record this shutter, them look at my options. Maybe Ford will have a fix before this gets out of hand.
2011 F350 6.7 CC Lariat LB SRW 4X4 10/10
2006 F350 6.0 CC Lariat LB SRW 4X4
2004 F250 6.0 CC Lariat SB SRW 4X4
1995 F250 351 CID EC XLT LB SRW 4X4
1978 F150 351 CID SC Ranger SB 4X4
Pipebndr is offline   Reply With Quote
Old 10-12-2011, 12:56 PM   #10 (permalink)
The fix must not be worth the $. Thanks for the heads up
Old 10-12-2011, 02:43 PM   #11 (permalink)
BCR Fordman's Avatar
Just had a 2012 converter installed on mine with a new pump and it seems to be working just fine. I only had a slight shudder problem. Not as bad as some of the video's I've seen recently.
BCR Fordman is offline   Reply With Quote
Old 10-12-2011, 03:09 PM   #12 (permalink)
Mine is a Job 2 and is having issues with it.
harris25 is offline   Reply With Quote
Old 10-12-2011, 04:27 PM   #13 (permalink)
Cobrahauler's Avatar
Mine's a job 1, built right in the middle of the issue timeline, 09/10, 11000 miles, mostly towing, zero issues yet. Yet I say
'11 Platinum white 6.7, two tone 350 Lariat CC SRW. Short bed FX4. TracRac rack system. I can only hope this truck is as good as the 02 was.
02 CC 4X4 Lariat K&N,4" Turbo back, Autometers on A pillar, DP Tuner chip, 20s w/ Nitto Terra Grapplers. Never to the dealer for anything. Traded in on the '11 350.
07 Mustang GT
67 Mustang 289 Coupe
Backdraft Cobra #808 Track car 408CI 500rwhp
07 Jeep Unlimited, 4"lift on 35s
Cobrahauler is offline   Reply With Quote
Old 10-12-2011, 08:10 PM   #14 (permalink)
00buck's Avatar
My Feb 2011 build has zero tranny issues.
Shifts as it should, when it should.
Only 4100 miles on it, so maybe I should also add- so far.
My only gripe is the weak engine breaking.
2011 Silver Crew Lariat 4x4 6.7l w/ B&W Companion hitch & Firestone air bags
2012 Starcraft 278 BHS 5er
2009 Polaris Ranger XP
00buck is offline   Reply With Quote
Old 10-13-2011, 07:11 AM   #15 (permalink)
Supporting Member
There was a new calibration last spring that address's that breaking. Mine got much better it seemed.
2011 F350 Lariat DK.Blue/Silver,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
