Turning with 4 wheel drive engaged - Diesel Forum - TheDieselStop.com
 3Likes
post #1 of 20 (permalink) Old 11-25-2013, 06:57 PM Thread Starter
RAINEY's Avatar
Used my 4x4 today for the first time with the snow that we received. It is normal to have some hop and actually have feedback from the system kind of like you can actually feel the universal joints fighting the turn? I didn't have this feeling as much with my GMC. The truck really felt like it didn't want to turn and the front wanted to slide more than I thought it would. This was at parking lot speeds and turning into my garage.
Thanks,
Jason
Jason
2012 F350 Powerstroke Crew Cab SRW
RAINEY is offline
post #2 of 20 (permalink) Old 11-25-2013, 07:00 PM
Subeditor want to see what it ends up being
Polertyouben is offline
post #3 of 20 (permalink) Old 11-25-2013, 07:01 PM
*subscribed
post #4 of 20 (permalink) Old 11-25-2013, 07:23 PM
klhansen's Avatar
My Photos: (180)
I've never had a 4x4 that didn't crow hop in turns. The tighter the turn, the worse it gets. Absolutely normal.
Your GMC may have had a different system with a differential in the t-case.
), AIS,
regulated return,
klhansen is offline
post #5 of 20 (permalink) Old 11-25-2013, 07:25 PM
Yea but look wat else he talking about
post #6 of 20 (permalink) Old 11-25-2013, 07:28 PM
gearhead1011's Avatar
My Photos: (10)
It's normal. With any 4X4 that locks the transfer case in the tires have to slip or scoot to compensate for the difference in wheel speed when turning. How severe it is will vary with different vehicles due to things like, wheel base, vehicle weight and turning radius.
2012 F250 XLT
6.7 CCSB 4X4 Sterling Grey, B&W Turnover Goosenech Hitch, Air Lift LoadLifter 5000, 50 gallon Transfer Flow replacement tank, Weather Tech mats
gearhead1011 is offline
post #7 of 20 (permalink) Old 11-25-2013, 07:29 PM
Does it have anything to do with snow because I mostly ride mudd
post #8 of 20 (permalink) Old 11-25-2013, 07:33 PM
klhansen's Avatar
My Photos: (180)
What gearhead1011 said.
The traction conditions dictate how bad it will be as well. In slick conditions, it's easier for the tire to slip to eliminate the wind-up in the driveline, so isn't as noticeable.
If the truck has a limited slip rear differential, in slippery conditions, it creates a lot of understeer (not turning where the front wheels point), because both rear wheels are pushing.
Again, it's a normal condition for a 4x4 when locked in. The way to eliminate it is to drop out of 4x4 for slow speed turns.
Couillj likes this.
), AIS,
regulated return,
klhansen is offline
post #9 of 20 (permalink) Old 11-26-2013, 07:50 AM Thread Starter
RAINEY's Avatar
Thanks all. Maybe the GM's feel differently because they don't have the solid front axle.
Jason
RAINEY is offline
post #10 of 20 (permalink) Old 11-26-2013, 08:01 AM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
GM's are different because they have CV (Constant Velocity) joints as opposed to u-joints. They offer a much smoother transition when steering. And they spin 100% of the time due to lack of locking hubs...trade offs.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #11 of 20 (permalink) Old 11-26-2013, 09:52 AM
OR.... Mash the gas pedal and make all four wheels spin & slip. How tight you turn greatly effects this feedback too. The frt wheels are trying to take a much longer path than the rears when turning short but the T-case is locked up solid and forcing both frt & rear tires to spin the same speed. The frt tires are being pushed by the rears, and the rears are probably slipping.
FMC used to put slightly higher gear ratioes in the frt driving axle of 4X4's, like 3.50:1 in frt & 3.55:1 in rear, or 4.09:1 in frt and 4.11:1 in rear to allow the frt axle to "PULL" the rear when driving straight and reduce this pushing/pulling tendency on turns.
Couillj likes this.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #12 of 20 (permalink) Old 11-26-2013, 03:26 PM
Actually when turning the inboard wheels to the turn will turn slower than the outside tires. The outside tires need to cover more ground faster than the inside of the turn tires do.
I don't believe Ford staggers axle ratios anymore (if they even did).
jamesrxx951 is offline
post #13 of 20 (permalink) Old 11-27-2013, 05:09 PM
The difference in distance traveled from side-to-side is LESS than the difference front-to-back. Just look at the tracks your truck leaves on the ground. Longer the wheel base, the greater the difference. And the diff's in the axles compensate for side-to-side variations anyhow, No diff in the T-case so NO compensation frt to back.
And YES Ford did use different ratios. My '78 F150 had 3.55:1 in the 9-inch & 3.50:1 in the Dana 44 frt. My '87 & '96 PSD have the same thing.
Denny
Dr.Evil is offline
post #14 of 20 (permalink) Old 11-27-2013, 05:20 PM
Actually I just measure exact wheel speed. This is a basic check when it comes to AWD issues. 4x4 systems are the same.
post #15 of 20 (permalink) Old 11-28-2013, 08:33 AM
That feedback is a sign that the road surface is not slippery enough to use 4WD, so just put it back in 2WD.
Brian
MC5C is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
