ULTIMATE gear/tire/final drive ratio comparison chart - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 12-18-2010, 12:42 AM Thread Starter
Ok so i decided to make a chart to compare the different standard tire and gear packages. This chart also includes a comparison if you went from standard factory tires sizes up to 34"&35". There are also comparisons with the 2010 super duty and the two other major brands with standard options.
I am basing this on what i feel is the most common trucks. F250/350 SRW Diesel 4X4 Lariat/King Ranch.
Let me know if i messed anything up.
File Type: pdf 2011 Ford Super duty final drive ratio comparison.pdf (140.6 KB, 1272 views)
11 F350 CC/LWB/4x4
Last edited by sleepersilverado; 12-21-2010 at 08:40 PM. Reason: sorry somehow dodge was left out fixed now/ typos 12.21.10
sleepersilverado is offline
post #2 of 11 (permalink) Old 12-18-2010, 11:36 PM
awesome writeup sleeper, it's surprising the difference a couple inches in diameter makes in rpms
2011 F350 King Ranch, oxford white over pale adobe, black interior, fx4,18s, 3.31 gears, shortbed
spook222 is offline
post #3 of 11 (permalink) Old 12-19-2010, 09:33 AM
I have a spread sheet with formulas that I use to figure gear ratios, speed & RPM in each gear along with different tire sizes. Just put in a couple of numbers and it will automatically calculate everything. If anyone's interested?
08 F250 6.4l CC SB (87K Miles), 2011 F350 ordered.
02 GMC 6.6l CC SB (376K Miles), Traded for 2011 LML
Maxtorque is offline
post #4 of 11 (permalink) Old 12-19-2010, 12:22 PM
Dieseldawg2010's Avatar
very usefull sleeper
On Order 2011 6.7L KR CC 4x4
For Sale 2004 6.0L Lariat CC 4x4 White, 10" DHR lift, 38" MT on Black 20" MotoMetals, ATS Head studs, EGR DELETE PIPE, 4.56 gears w/ Lockers, IDP SCT Tunes, Banks Intercooler, Rear Camera, DVD with 3 screens
Dieseldawg2010 is offline
post #5 of 11 (permalink) Old 12-20-2010, 12:14 AM
WIS-key's Avatar
Great info, thanks for doing this.
2011 F250 :[==]: Lariat, Ultimate, CC, SB, PSD, 4x4, 3.31 EL, Tuxedo Black/Adobe, Painted Grill Bezel, Truxedo Deuce, Line-X
WIS-key is offline
post #6 of 11 (permalink) Old 12-20-2010, 07:33 PM Thread Starter
With all the questions about 3.31's, tire sizes, and me having the same questions i decided to do this. That being said i find that comparing the 3.31's w/ 35's vs. the 2010 6.4 and the other two major brands interesting. There has been debate about having 3.31's and going to a larger tire. Looking at the final drive ratio the shorter gear does not look so bad on paper.
11 F350 CC/LWB/4x4
post #7 of 11 (permalink) Old 12-21-2010, 06:08 AM
Jassman's Avatar
thanks for the info..it helps.. I have the 325 60 R20's on stock rims w/3.55's. Top left of your page reads 62 vs 65 .. but I knew what you were getting at. Thanks Jeff
2015 F350 LWB CC 3.55 Platinum on order
2012 F150 FX4 w appearance package
2011 F350 LWB CC 3.55's GPS Lariat. my truck
2010 F150 FX4 5.4 3.73's
2008 F350 LWB CC 6.4 dually. 3.73's
2007 F350 LWB CC 6.0 Dually, 4:10, ID SCT tunes Xtreme race, Xtreme street, and tow w/agressive brake, MBRP Turbo back cool duals AFE Mega 2 ..
Jassman is offline
post #8 of 11 (permalink) Old 12-21-2010, 08:32 PM Thread Starter
yea there are a few mis numbers. i found one that read 111 rpm's. the numbers started to run together with 3 programs running on one screen.
Fixed few typos
11 F350 CC/LWB/4x4
post #9 of 11 (permalink) Old 01-06-2011, 08:17 PM
I have an 02 f250 4x4 7.3. went from 285-16" to 305-20". does anyone know what the best ratio is? Either way, need to work on rearend.
usmcmike is offline
post #10 of 11 (permalink) Old 01-06-2011, 09:20 PM Thread Starter
depends what you are trying to accomplish. If you are just trying to get back to your original ratio use this site. Gear Calculator
11 F350 CC/LWB/4x4
post #11 of 11 (permalink) Old 01-06-2011, 09:36 PM
Thanks for the site. I'm looking for both power and performance. I pull a 34' travel trailer 8500 lbs.
usmcmike is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
