WAY TOO MUCH DIESEL FUEL IN THE OIL - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 01-16-2013, 05:31 PM   #16 (permalink)
Thank's for all the help.
henry1 is offline   Reply With Quote
Old 01-16-2013, 05:44 PM   #17 (permalink)
Henry,
Next time try sending a sample to Blackstone or any other lab and see if the results change.
When the 6.7 hits 7.79% dilution it should give you a "change oil soon" warning.
At 8.2% it should give you a "oil change required" warning.
You should have seen these before you got to 10% dilution.
Kevin
'13 F150 Ecoboost Screw Platinum 4x4, LineX Premium, Retrax1, Sterling Gray
Purchased 5/26/11... 2011 F250 Lariat CC SWB 6.7, LineX Premium, Retrax Pro.... 53k traded 12/24/12
Stolen 5/15/11... 2002 F250 XLT Sport SC SWB 7.3 304xxx, LineX, Retrax
KJ Smith is online now   Reply With Quote
Old 01-16-2013, 06:26 PM   #18 (permalink)
No warning at all.
Old 01-16-2013, 06:47 PM   #19 (permalink)
Did you ask the lab to re-run your sample? I had to do that once at Polaris because a sample had unusual readings. Otherwise I think your plan is good. Re sample at 12-1500 and see what the dealio is. Perhaps this was an anomaly. It is not a trend until you have more than 1 sample with similar results.
1999 F350 DRW 7.3L
2013 F350 SRW 6.7L
ShumpH15 is offline   Reply With Quote
Old 01-16-2013, 06:52 PM   #20 (permalink)
your absolutely correct. This is the first sample after the oem oil change. It will be interesting to see what happens with the next one.
Old 01-17-2013, 12:04 PM   #21 (permalink)
Originally Posted by KJ Smith View Post
Henry,
I have never sent in a sample and would like to do it. How do I get started? Where do I get a kit and instructions for sending it in?
Thanks!
John
2011 Ford F-350 DRW Lariat Crew Cab 4x4 (8' Bed 3.73, Oxford White, Pale Adobe Accent, 6.7L, 10K GVWR, Lariat Ultimate Package, Tailgate Step, Universal Garage Door Opener, Upfitter switches, Navigation, Preferred Equipment Package)
Born: 6/15/2010 - Cost At Birth: $59,540 - Purchased: 7/17/2010
Mods: Engine Block Heater, LineX, Firestone Rear Airbags, Air Lift Wireless Compressor, LockPick, UpFitter Switches, Bed Lights, Torza Top Tri-Fold, Ultimate-EDP Alarm, Door Seal Mod.
John Hagen is offline   Reply With Quote
Old 01-17-2013, 12:41 PM   #22 (permalink)
Blackstone is the easiest to get a kit from
Blackstone Labs
I prefer Polaris because of the way BS does fuel dilution
Polaris Testing Kits
1999 F350 DRW 7.3L
2013 F350 SRW 6.7L
Old 01-19-2013, 06:50 AM   #23 (permalink)
nod
I have read about locking out gears several times but don't have a clue on how to accomplish that. Anyone????
Thanx, nod
2012 F250 Super Duty Lariat 6.7 powerstroke
nod is offline   Reply With Quote
Old 01-19-2013, 07:02 AM   #24 (permalink)
senix's Avatar
Thanx, nod
It will be in the owners manual. I am not sure of the procedure.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is online now   Reply With Quote
Old 01-19-2013, 09:32 AM   #25 (permalink)
Painted Horse's Avatar
Locking out gears, just means touching the +/- button on your stalk and turning off that gear. If you are in 6th, press the "-" button and it will lock out 6th and truck will only run 1st thru 5th gear. Repeat again "-" and you will now be limited to 1-4th gear.
If you move the shifter from "Drive" to "M" then the +/- will chose the exact gear that you will use.
11 F350 CC Lariat SRW LWB Tuxedo Black
B&W turnover ball
http://www.fuelly.com/sig-us/59436.png
Painted Horse is offline   Reply With Quote
