6.7L Power Stroke Engine and DrivetrainDiscussion of the 6.7L Power Stroke diesel engine and drivetrain in the 2011-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
What did ford do with the 6.7 they couldnt do with the 6.4?
The reason I am asking is some of the techs here might know why ford needed an all new block to get done what they did over the 6.4. does the .3 make that much diff? Or is it just so revolutionarally diff that nothing has been seen like this before.
My Diesels-
09 F250 loaded lariat 4X4 Spartan with all deletes
97 F250 XL 4x4 PSD 5spd
09 kubota m59
03 MF 4345 4x4 cab/air Sirius/radio 1070 loader
Not a Ford Tech but here goes. The 6.4 is a Navistar motor, designed buy Navistar. Ford can’t use the exact design, I'm sure patient infringements would apply to some degree, they may be able to use some of it depends on how much input Ford had on it to begin with. It has nothing to do with CCc/CIs although 19 more CIs means about 19 More HP all said and done.
2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, DP Tuner, 6.0 IC mod, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 310,000 miles!!
05 White XL 6.0 Reg Cab 4X4 140,500 miles!! (That has never seen the inside of a Garage)
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 125,651 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
The engines are very different. Just to point out a few areas: High pressure common rail fuel injection, turbo design, inversed airflow through heads, much better cooling to compensate for higher EGTs, much leaner air/fuel mixture
11 F350 SRW PSD CC 4X4 Long Bed Lariat Ult
2011 Forest River XLR Toy Hauler 39 Feet, 14K lbs.
06 PSD CC 4X4 Shorty Lariat Loaded (sold)
Need to be more specific?
Because it actually was navistars motor,not truely fords..like the 6.7 is.
Well...yes..if they REALLY wanted to get down to it, they could do reverse flow,common rail.yada yada yad...on the 6.4
I believe they wanted a diesel,that was strong,had a lot of room for potential
as in IT IS cheaper to make a REALLY really good design first,then be able to use that platform and build off from it for 10yrs..plus lot less headaches and navistar has given ford headaches,along with the public. Let alone Ford will have a bigger bottom line, the public will be happy with a good motor...FINALLY!!!!
Something that can go along with change as EPA sticks there head further up everybodies *^%,reliable,good MPG,strong,Something to Finally live up to the Ford name..this sums it up right here... it can be around for many years to compete with dodge/gm
The new block for to save on weight and its stronger....they probably got future plans for that block HP/TQ With CGI you can go a lot further on parimeters,than with cast.
NO motor is revolutionary! They just build on it... Still has 8 rods,8 pistons,One crank,2 heads....just some have better components than others (some have 3,4,6 rods,etc)
Reason: Language, next time a point
I wonder if Ford will be selling crate diesels for hotrodders anytime soon? I imagine that a light weight, high HP platform like this could be the new Big Block of the 21st century. We have already seen some diesel swaps into cars for the Duramax but not too many done for the International motors. The 6.7 may be different.
2002 Excursion Diesel-Stock owned 3 years 203k miles
Planning upgrades with the following order: durability, milage, power: 203 thermostat, Cat ELC, AIS delete, DieselSite engine and intercooler boots,
2002 VW Golf TDI-Nearly stock +taller 5th gear, LSD, 50+MPG, owned since new, 205k miles
I am 6'5" so the Golf is know as the clown car
one thing that does worry me about the 6.7 is the aluminum heads. i know they have been around in europe for awhile, but it could be a potential weak point. i sure hope not though.
2006 F350 4X4 6.0L Lariat Crew Cab FX4 SRW
Edge Insight with EGT probe
Autometer Fuel Pressure Gauge / ITP Adapter Line
DieselSite Coolant Filter
Amsoil EaBp 100 ByPass Filter
Ford Fuel Pressure Blue Spring Kit
ITP HFCM Brass Drain Plug
Fumoto oil drain valve
born 10/2005, in service 8/2006
bought by me Jan 27th 2010 with 54K miles from first owner; Bill, RIP.
I have aluminum heads on my VW TDI and the motor has been flawless for nearly 9 years now and 177k miles. I wouldn't give much concern about that.
The EGR trickery, reverse flow heads and turbo heat soaking make me somewhat concerned out of the list of diesel wizardry that I have read/seen so far.
Heat soak is something like putting on an arctic cold weather suit in the tropics. You do not get overheated right away but after a while you get really uncomfortable but you can still function, if you can drink enough water things keep going but are at the limit of their abilities. Things like that tuna sandwich in your pocket go bad and at some point you start to shut down piece by piece.
With the turbo and exhaust manifolds tucked into the valley like they are and covered by all that other stuff, a person wonders if they will build up with heat on a hard pull and also cook everything around them.
I think Ford went in house so they could have an engine designed for pickups not medium duty trucks, so they could make running changes without having to "negotiate" with an out side vendor. The 6.4 and 6.7 are both V8 piston diesels, however, from their construction to their emission controls they are different. Just as the chevy 6.5 and the chevy duramax were different when the duramax was introduced.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0
'06 40' prairie schooner 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'85 F7000 mechanic service, 3208na CAT
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
I belive this is one of the reasons for the dual coolant/radiator loops
Yep. What he said!
the dmax heads had a few problems early on, but very reliable now....10 years of time tested reliability.
mercedes have been using aluminum heads on diesels for almost 30 years. not without problems of course, but those problems usually showed up after 150,000 miles.
i d say it s the way to go ! !
'12 gmc sierra slt cc, lb, duramax, carbon blk outside, blk leather inside.
'11 e350 super cargo,ingot silver, v10.
'09 mazda6i grand touring, black cherry,blk leather.
'77 450SL benz in the family since new.
'91 350sdl turbo diesel benz
'10 MAZDA 6i, DAUGHTERS RIDE
'90 560sel benz. what a pos.
