3.55 axle ratio available soon - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Ordering Information
1999-2007 Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 08-01-2007, 12:01 AM   #1 (permalink)
SmokeyWren's Avatar
My Photos: (44)
https://www.fleet.ford.com/truckBBAS...atsnew2008.pdf
Rear axle ratio (late availability after Job 2 begins)
3.55 axle ratio will be optional with 17" or 18" tires/wheels on SRW 6.4L with automatic tranny and limited slip.
So you guys that had 3.55 ratio in your OBS pickups and thought it had enough oomph for your needs, it will soon be available again. My feeling is if you rarely gross more than about 16,000 pounds GCW, and rarely tow in hills or mountains, then the 3.55 ratio would be just what the doctor ordered.
SmokeyWren is offline
Old 08-01-2007, 12:10 AM   #2 (permalink)
Re: 3.55 axle ratio available soon
I believe that is strongly due to the cost of fuel. And Ford should continue that option across the line including duallys.
Tom
02 CC XLT Dually 4x2, PSD w/6 spd, White w/Med Flint 40/20/40, TTT Mirrors, 4.10 L/S, PCM=AEB4, Receiver, Cab Steps, Homelink X Visor, Husky F&R Mud Flaps, AIS Ford Filter, WD Pyro & Boost in A-pillar, Line-X, Hutch Tank Mod, Pre-Pump Racor 645R30, 4" Banks Monster Exhaust, Mag-Hytec Diff Cover, Amsoil in Tranny & Diff.
Bye-bye 99 diesel-sucking automatic!!!
tomshep is offline
Old 08-01-2007, 01:24 AM   #3 (permalink)
My Photos: (9)
i would like to see the 450 with atleast the 4.10 if not the 3.73, with out a decrease in gcwr, i want the 33k that the 4.88 offers with the 4.30 im content with ~45 up a 6% if it means a couple better mpg when empty. id even live with the 3.73 and a 26k if it was offered. im trying to decide witch route to go as im not inteseted in 4.88 trying to see if i can downsize the trailer we're looking to haul, right about 20,500-21,000 if i could lose a few thousand pounds i would jump on the 4.30
BS Math 2009
BS Biology 2009
PhD Math - 3 areas of study: Applied Mathematics & Mathematical Physics, Differential Equations, Algebra 2013
My favorite toy: Core i7 920@3.8ghz in Azza Hurrican 2000, liquid cooled cpu, Asus P6x58D-Premium motherboard on a shelf replaced with MSI Big Bang X Power x58, EVGA GTX 295s quad sli on a shelf replaced with 3 EVGA GTX 580 Hydro Copper 2 FTW tri SLI, 128GB SATA III Crucial Real SSD, Western Digital 500GB 7200rpm HD for storage, 12GB of ram@1600Mhz, 1100w power supply
http://www.youtube.com/watch?v=VLK6GPMZmi0
http://www.speedtest.net/result/1577784346.png
2005 F350 cc, sb, Lariat, chip, 4" turbo back straight pipe 6" tip, outlook monitor, two tone blue and silver funtional ram air hood, 35x12.50x18 BFG MT KM2, Rancho RS9000XL with My Ride, ARB front and rear lockers.
1941 Willys Americar Coupe
2007 Mazdaspeed 6
2009 Jeep Wrangler Sahara
2012 Ford Focus SEL Sterling Grey
jgoff78 is offline
Old 08-01-2007, 08:01 AM   #4 (permalink)
George C's Avatar
It sounds like the 20" rubber has a longer rolling distance than the others, therefore it's not available.
So, I imagine my truck will reflect about the same gearing as a 17" or 18" equipped truck with 3:55 rears.
Personally, I thought the 4:10 gears were perfect in my DRW.
I do more in-town driving than anything else, so a slight reduction in gearing gave me that light truck feel.
We'll see.. Maybe I'll like it.
My 2008 F-350
KEM 345 tuned
2011 Chevy Silverado
2010 Chevy Tahoe
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 08-01-2007, 08:25 AM   #5 (permalink)
skidmarks's Avatar
I feel the same.
2011 F350 XLT SC srw 4x4 Pearl blue
2008 F350 Lariat CC DRW 4X4
2003 F250 XLT SC 4X2
2003.5 RAM 3500 Laramie CC DRW 4X4
1997 RAM 2500 SC Laramie SRW 4X4
1996 F250 Lariat 4X4
1989 F250 Lariat SRW 4X2
All diesels
All 8' beds
I don't have the time or memory to list all the gassers I've owned.
skidmarks is offline
Old 08-01-2007, 08:49 AM   #6 (permalink)
George C's Avatar
I think they would be offering a lot more if they added the 4:10 to the SRW option list.
That gearing is perfect IMHO..
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
Old 08-01-2007, 10:02 AM   #7 (permalink)
My '05 CTD had 4.10 gears. Sure was a hot rod off the line, but turned 2300 rpm at 70 mph.
My '06 CTD has 3.73 gears. A little more sluggish off the line, but only turns about 1900-2000 rpm at 70 mph. Gets about 2 mpg better than the '05.
I pull 8000-10,000 lbs. MPGs start to die after 2000 rpm, so I try to keep the engine at around 1800 rpm. Nets out to about 68 mph. Pretty slow when you are in a 75 mph speed zone. 3.55's would let me run 70-75 mph but keep rpms in the 1600-1700 range.
BTW - Did anyone else notice in the E-350 and F-53 section that the TorqShift no longer has an external filter? The filter is not internal with a 36,000 miles OCI.
jschira is offline
Old 08-01-2007, 10:20 AM   #8 (permalink)
CaptSkup's Avatar
While I can live with the 4.88's in my truck since the primary purpose is towing heavy, I would really like to have a two speed rear axle. Something I could have had with a F-650. One speed for unloaded driving, second gear for towing. Life than would be perfect. Could the offering of the 3.55 be a result of upcoming CAFE standards for all vehicles, including our precious heavy pickup trucks.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 08-01-2007, 12:34 PM   #9 (permalink)
I see some other changes that were not mentioned before such as new ignition switch, front air dam on 4x4 trucks. I would have liked the chrome package, my KR is kinda monotone, needs a little bump up. I want to see the exhaust chrome and the mirror caps. May be cheap to add on later as well as the tow hooks. The backup camera would be cool if you hook up a lot to regular trailers.
What I'm really looking for and still isn't available is a bluetooth setup for the nav system, not a mickeymouse aftermarket gadget. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Starting the first of the year, the great State of CA will no longer allow handheld phone use and I refuse to wear one of those ear mounted, dorky, blue light flashing gizmos. [img]/ubbthreads/images/graemlins/depressed.gif[/img]
2008 F350 SRW SB KR almost all options including moonroof, nav, etc. Ordered May 14, received July 4, 2007.
F350 4x4 CC SWB SRW 2003.25 6.0/Auto, FX4, Lariat, Toreador Red/Arizona Tan, Bench Seats, Moonroof, etc. Ordered Nov.6, 2002. Received Jan 30, 2003. Pulling 1992 Alfa 34' 12200GVWR with Pulliam SuperGlide. Retrax. 86000 miles and counting. Traded, July 4, 2007
kalalp is offline
Old 08-01-2007, 12:47 PM   #10 (permalink)
George C's Avatar
As far as I'm concerned, the Federal Government needs to OUTLAW all cell phone activity while driving, period.
Hopefully, it won't take many more senseless and needless deaths before legislation is introduced.
Yeah, I'm ready to get flamed, but I also ride a motorcycle, and I'm kinda tired of almost getting killed each and every day by some kid chatting it up..
I think you can appreciate that....
Everybody's talking and driving on a cell phone these days, even the freggin cops.. Nice example guys, but not a surprise..
Just a couple of weeks ago and not far from me, 5 young and beautiful highschool grads were killed in a head on when the kid who was driving was texting. She hit a semi right in the kisser, and not much was left for their parents to gather up..
Aside from my rant, I'm very pleased with the way things worked out for me. The Job 2 updates were worth the extra wait. The Chrome Package makes the truck look totally different and updated from the Job 1 trucks, and man, does it look good!
Looks like an easy mod to make for those who like it..
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
Old 08-01-2007, 03:38 PM   #11 (permalink)
My Photos: (5)
It sure would be nice if someone made the link to the "What's New for 2008" guide sticky in the ordering forum. It would sure help those who are contemplating ordering Job 2 trucks.
I remember constantly posting the link before, when new users had questions.
And I agree, the only option missing at this point is the bluetooth for handsfree cell operation. I read the Sync option would be available on all Fords, but who knows when.
Have a Nice Day.
kude
kude is offline
Old 08-04-2007, 01:08 PM   #12 (permalink)
Supporting Member
How soon? Sept.? How would we find out? The 18in 275/70/18 that comes stock with F350 SWD is taller or smaller in dia then the 16in. tire I have now on my 02 350? If the 18 is taller I can live with the 3.73's.
2011 F350 Lariat DK.Blue/Silver,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline
Old 08-04-2007, 07:42 PM   #13 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Ask and ye shall receive. Did you notice the new sticky at the top of this forum? [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 08-04-2007, 07:59 PM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (44)
I don't have a clue. But in other years the "late availability" items showed up in the order guide two or three months later.
The LT265/75R16 A/S on the '02 F-350 SRW was 655 tire revs/mile.
The 275/70R18 with A/T tread on the new F-350 SRW is taller at 629 tire revs/mile.
655 minus 629 = 4 percent.
3.73 minus 4 percent = 3.58
So assuming you have hot-rodded your 7.3L so it has as much power and torque as the new 6.4L, then the new truck with 275/70R18 tires and 3.73 ratio will "feel like" your current truck with stock tires and 3.58 ratio.
If you go for the 3.55 ratio in the new truck, it will "feel like" your truck with a 3.41 rear end. Them legs are gettin' pretty long!
And George, if you're still reading this, your 20" tires are just a hair shorter than 35s. They're 605 revs/mile, or 7.6 percent difference in effective rear axle ratio compared to stock tires back in '04 and earlier. So an '08 with 3.73 with 20" tires will "feel like" a 3.45 rear end in the '04 with stock tires. The 3.55 ratio available soon would mean your '08 with 20" tires might look good in the parking lot of the country club, but it wouldn't be worth a hoot for dragging a heavy trailer over the Adirondacks. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Old 08-04-2007, 10:46 PM   #15 (permalink)
George C's Avatar
Great info....
That's why I love the 4:10 rears Smokey...
With my style of driving, which is mostly intown, the lower gears suit me better.
We'll see, I'm not expecting this truck to tow as well as my 03' DRW.
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
