4whl ABS - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Ordering Information
1999-2007 Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 03-19-2000, 10:59 PM   #1 (permalink)
4whl ABS
I ordered a 2000 350 cc swb 4x4 xlt with the 4whl ABS and all terrain tires. Dealer called last week to tell me the truck would arrive 3-22-00. I was then told that the truck that was coming in did not have the ABS or the A/T tire option because of a ordering mix up. My question is is the 4whl ABS that important of an option, if so sould I make the dealer order a new truck?
Thanks,
Bronco
Bronco is offline
Old 03-19-2000, 11:19 PM   #2 (permalink)
Re: 4whl ABS
If I understand the literature and previous posts, the "4-wheel" ABS available on the 250/350 series is not a true 4-channel system. Rather, the ABS unit controls the 2 front wheels individually and the rear wheels as a set. Which, IMHO, is better than just the rear-wheel ABS. I'm sure I'll get corrected if I'm wrong and there are definately going to be other opinions.
That said...
We ordered it on ours because 1) ABS saved our lives (no doubt) in our Honda Accord and 2) its hard enough stopping a truck under control, let alone one w/ the weight of a PSD in it.
If it were me, I'd be asking for the truck I ordered.
On order: 00 F350 4WD C/C SWB PSD 6spd
For sale: 93 F150 4WD S/C SWB 302 Auto
HighPlainsDrifter is offline
Old 03-20-2000, 12:54 AM   #3 (permalink)
Re: 4whl ABS
I thought Ford had made 4-wheel ABS standard on XLTs and Lariats for 2000. Maybe not. Anyway, I'd check the order number and get the truck you ordered. It is their problem. "Ordering mixup" doesn't mean it is your problem.
Jim
2000 F-350 Lariat SC PSD 4x4 SRW LB camper/tow trashbag hook
Rimrocky is offline
Old 03-20-2000, 03:17 AM   #4 (permalink)
Re: 4whl ABS
Sounds like the dealer is giving you a truck that was already on the way or that was on a "dealer trade". Stick to your guns and make them deliver YOUR truck. For what you are spending, you'd better get what you want!
4 wheel ABS works great!
2000 F350 White XLT CC 4X4 SRW LWB PSD 6spd, front and rear KRG pipe replacements (and more to come)...
2000 F350 XLT CC 4X4 SRW LWB PSD 6spd, 4" custom lift on BFG 35s, Ranch Hand front to back, Rhino lined, Warn M12000, Amsoil in the driveline, Delo in the block, Dynomax exhaust, Mag-Hytec rear cover, ATS housing, EVO (and more to come)...
wolffman is offline
Old 03-20-2000, 03:31 AM   #5 (permalink)
Re: 4whl ABS
read the sticker if it has 4w abs and not the tires thats not bad. but if you realy wanted 4w abs and its not there thats there fault not yours. get the truck you want its costting you enough.and thats the fastest truck i have seen built in a yr.so its most likly one close to what you want or they found one ck out all the order #`s
STEPHEN 350 4X4 SILVER XLT TINTED WINDOWS AUTO BURLWOOD DASH FORD BED LINER BANKS AIR FILTER POWER/PKG COMP/TEMP MIRROR PINSTRIPED SPOT LIGHT LUND/VISER BFG 295`S Fisher plow my truck
[This message has been edited by stephen (edited 03-20-2000).]
STEPHEN 350 4X4 SILVER XLT TINTED WINDOWS AUTO BURLWOOD DASH & a burl wood AIC cover,heated mirrors with turn inder FORD BED LINER BANKS AIR FILTER POWER/PKG COMP/TEMP MIRROR PINSTRIPED SPOT LIGHT LUND/VISER BFG 295`S Fisher plow my truck
Check Out My Burl Wood AIC Cover!
stephen is offline
Old 03-20-2000, 08:18 AM   #6 (permalink)
Re: 4whl ABS
The service dept should be able to add the abs to this truck at no cost to you.
I think that you should really check the order number to ensure the truck is really the one you ordered
03 F350 Lariat Fx4 SC LB DRW 6.0 PSD Torqshift,Leather w/butt warmers.Wood grain
A-pillars, Pyro,Boost,Trans isspro gauges
00 F250 4X4 SC PSD SOLD
Sundowner 8012 4 horse LQ trailer,
4 Fine Tennesse Walking Horses, 7 Fainting goats
http://community.webshots.com/user/buckraker
muckraker is offline
Old 03-20-2000, 09:31 AM   #7 (permalink)
Re: 4whl ABS
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Rimrocky:
I thought Ford had made 4-wheel ABS standard on XLTs and Lariats for 2000. Maybe not.<HR></BLOCKQUOTE>
Jim, as I recall, 4 wheel ABS is standard on Lariat and optional on the XLT.
00 250 SD SC 4x4 PSD auto, Bright Amber
AHSA, USDF, RMDS, USPSA (Life), NRA, EPCSO Volunteer
00 250 XLT SD SC 4x4 PSD auto, Bright Amber
USEF, USDF, RMDS, USPSA (Life), EPCSO Volunteer
So many toys... so little money... :-)
Koakey is offline
Old 03-20-2000, 02:58 PM   #8 (permalink)
Re: 4whl ABS
Thanks for all of the feedback,I was told by the salesman that the 4whl ABS had to come for the factory and could not be installed by the dealer.
So what is the deal, am I getting the run around on this?!
Bronco is offline
Old 03-20-2000, 08:28 PM   #9 (permalink)
Re: 4whl ABS
4 Wheel ABS is NOT standard on the y2k Superduty in the XL or XLT trim level. It must be ordered seperately. I doubt the dealer would add it as it would be quite costly.
2000 White F250 XLT SC LB 4x4 PSD AUTOMATIC ESOF ABS
NC_PSD is offline
Old 03-21-2000, 01:35 AM   #10 (permalink)
Re: 4whl ABS
Yup, Yer right. I stand corrected. 4 wheel ABS is optional on XL and XLTs.
Jim
Rimrocky is offline
