Re: Any Ideas on which Differential ratio 4.30 or 4.88
I'm still undecided on the diff ratio. I am gettting the F-550 with the Payload upgrade to 19,000 Lbs
The payload upgrade pkg is available only with the 4.88 rear end ratio.
So you have to compromise:
17,500 GVWR with 4.30 ratio, or
19,000 GVWR with 4.88 ratio
If your truck weighs 18k without a trailer, and you don't usually tow a trailer, then I'd probably go with the 4.30 rear end and without the ungraded payload pkg.
500 pounds over the GVWR is no sin. And the 4.30 ratio would be better except in steep hills.
