Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Ordering Information
Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 02-17-2003, 01:49 AM   #1 (permalink)
camper package, 6.0 F350
I've ordered an F350 Lariat CC SRW 4x2 LB 6.0L auto, but it's not too late for me to change the options chosen. I'll be pulling a 13,000 lb, 35 ft 5th wheel. Do I need the camper package? I assumed it was for camper shells and I didn't order it (or the heavy duty suspension), but I notice that many contributors here have them. How does it affect the ride quality, loaded and unloaded? Thanks.
2003 F-350 Lariat, dob 3/6/03, 6.0L auto, CC, 4x2, SRW, LB, white/parchment, 3.73LS, capt seats, 6CD, adj pedals, chrome steps, roof lights, heated TT mirrors, reverse sensors, Line-X, X-Monitor, Pullrite hitch, Prodigy controller, Ride-rite air bags, tool box, mud flaps, wheel well skirts.
2003 Carriage Cameo LXI F34CK3 5th wheel, triple slides, fireplace, 2 A/C, R21 insulation, Mor-Ryde suspension, Honda EU2000i generator, Motosat Datastorm mobile satellite Internet/TV receiver, Trailair pin box.
dminz is offline
Old 02-17-2003, 08:50 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: camper package, 6.0 F350
The camper pkg has 3 parts:
[*] Heavier front suspension - unless the computer selected the heaviest available front suspension without the camper pkg.
[*] Rear stabilizer bar - anti-sway bar, or simply a sway bar.
[*] Certificate that allows you to haul a (very light) slide-in camper.
On your truck, the camper pkg probably will not increase the front GAWR. CrewCab longbed 4x2 PSDs will get the heaviest-duty coil springs Ford makes for the twin I-beam front suspension, with or without any suspension pkg. At least that was true when I ordered mine. I didn't order any suspension options and mine came with the heaviest coil springs Ford made at the time.
If your 5er grosses 13,000 pounds on the road, then your tow vehicle is going to be overloaded by about a thousand pounds over the GCWR of the tow vehicle, and a few hundred pounds over the GVWR of the tow vehicle. You need an F-450 to tow that much trailer without being overloaded.
But when loaded for bear, you'll enjoy the ride of the rig. The camper pkg will add a rear sway bar, which you'll need for your overloaded tow vehicle. And it won't affect the unloaded ride, since you'll probably get exactly the same front and rear GAWR as the same truck without the camper pkg.
There are two reasons to order the camper pkg on an SRW. You need a good stiff rear sway bar, and that's probably about as cheap as you can add one aftermarket. Plus if things change down the road and you decide to mount a slide-in camper in the truck, you'll void the factory warranty unless you have the camper pkg.
I don't have it on mine, but I haven't needed the rear sway bar with my 7,500-pound 5er. But it will cost you $136 invoice price to add it to yours by ordering the camper pkg, so I'd recommend it unless you can add a Helwig or other good aftermarket brand of sway bar for less than $136.
SmokeyWren is online now
Old 02-17-2003, 09:40 AM   #3 (permalink)
GLM
Might wanna check but I think the rear stabilizer is only on the F250 and not the F350. May be wrong but think that is what the spec sheet that I was looking at stated.
Gary
F350 XLT SC DRW Long Bed, Sport Pkg (Cloth Chairs w/console), Oxford White, 6.0 w/5 speed auto, Camper pkg, Security grp, Adj gas/brake pdl, TT mirrors, Tlr Rec Hitch, Prodigy controller, Reese 20K hitch
VIN C81680
2500 miles and GOIN' strong
GLM is offline
Old 02-17-2003, 11:35 AM   #4 (permalink)
Dminz,
Cochise here. It should not be too late to alter your order unless it has been "Locked-In" by the factory. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Click on address for quick connection cwillis@planetford59.com
Cochise Willis
Humble, Texas Good Ole' USA
Call me @ 281-319-9644 Fax me @ 281-319-9635
800-299-8791 X 9644
[url=http://www.planetford59.com]
Cochise is offline
Old 02-17-2003, 11:54 AM   #5 (permalink)
My Photos: (14)
The camper package does come with the bar on the 350. Its on mine.
I would recommend getting the camper package for yours.
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
YODA is offline
Old 02-17-2003, 11:00 PM   #6 (permalink)
I bought my 350 and didn't even thank or know about the camper pkg. Until I hit the diesel stop! So I am here to say the 2000 F350 has the big sway bar up front and another one over the rear axle which is big as well.
Thanks for your time
Outdoors1
2000 F350 xlt 4x2 sc,lb all stock
outdoors1 is offline
Old 02-22-2003, 05:34 PM   #7 (permalink)
I just took delivery on my 6.0 F350 and it does not have a front steering stabilizer can this be added from aftermarket? If so who would you suggest. And is it needed for non-off road driving?
<font color="blue">2003 F-350 CC, 4X4 Lariat "LE"</font>SWB, ESOF, DWR 6.0L 5-spd Auto thru 4:10 Ltd Slip, Delphi XM Satelite Radio, Captains with 40/20/40 rear bench, Adj. Pdls, Astro LE Shell, J&J Custom Rear Mud Flaps, General LT235 85 R16 OWL tires. Brake Smart brake Controller. Transflow 70 Gal. cross bed tank. Kelderman Air Suspension front/rear, Di Pricol guages on A Piller, DPPI 4" cat back exhaust, Harpooned tank, Putco Grill, AFE Pro 7 Intake, Fumoto Drain valve, Mag Hytec trans pan, BKG7. 27.10 Reflash <font color="blue">Build date 1/26/2003 Indianapolis </font>
[Pics]
mkspear is offline
