Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Ordering Information
Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 06-18-2002, 01:20 PM   #1 (permalink)
Dual Alternators
Uder what circumstances would ordering the dual alternator option make sense?
rhathawy is offline
Old 06-18-2002, 01:58 PM   #2 (permalink)
Re: Dual Alternators
If you run a lot of 12V equipment in or on your truck, it might make sense.
Like, if you have an Excursion with a power inverter installed! Except for no apparent reason, you can't order the dual alternators on an Excursion, only on the Superduties, sigh...
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
frobozz is offline
Old 06-18-2002, 05:25 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
4x4 and you know you're going to install a big electric winch. Or a huge "million-candlepower" light bar. [img]/ubbthreads/images/icons/wink.gif[/img] Or a big invertor that you'll use to run big electric tools such as half-inch drills, grinders, etc. Heavy-duty power liftgate?
Maybe a wrecker where you might have all the above. [img]/ubbthreads/images/icons/cool.gif[/img]
If you need dual altenators, you also need the auxiliary idle control kit (APCM or AIC) with its charge-protect circuit, so don't order one without the other.
I don't have any of that sorta high-draw electrical stuff, so I don't need a second altenator. But YMMV. [img]/ubbthreads/images/icons/cool.gif[/img]
SmokeyWren is offline
Old 06-19-2002, 01:27 PM   #4 (permalink)
bbs
They started putting these in for emergency vehicles (esp. ambulances) since they kept burning out alternators, and the aftermarket mods adding bigger alternators caused problems. This arrangement (one primary, the other lazy, with the computer switching which is which every time it is re-started) is a slick setup and has solved all of those problems.
That said, you would need one heck of a continuous 12v load to require the dual alternator setup. For momentary use - on the PSD's you have two batteries that can supplement. The only reason I could think of a civilian needing them is a 12v sander running continuously + lots of electric over hydraulic plow usage + one heck of a lot of inefficient warning lights.
-bbs
2002 PSD A/T S/C
bbs is offline
Old 06-20-2002, 04:06 PM   #5 (permalink)
Wouldn't you need a dual if you were to pull a "5th" Wheel Camper?
2003 King Ranch F350, 6.0L PSD, Estate Green..... My Baby's birthday is 11/25/02
kcroyals85 is offline
Old 06-20-2002, 06:37 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
</font><blockquote><font class="small">In reply to:</font><hr />
[/ QUOTE ] No. I have one altenator and I've towed my 5er all over the country.
Old 07-17-2002, 03:38 PM   #7 (permalink)
I ordered mine with the Dual Alt option for towing a 5er "just in case". The dealer screwed up and had to put it in as a change order but didnt bill me for it so, for FREE, its a good option.
(after 3 alternators on my "ex-car", a Chevy, I like TWO)
Al
RVpuller is offline
Old 07-24-2002, 09:15 PM   #8 (permalink)
Correct me if I'm wrong but the siingle Alt. on the PSD is smaller than one on a gasser. I beleave it's a 90 amp. If that true and it's only 80% efficient at high temps. Then while a single will work You really would not have to have all that much electricle stuff to max it out. say A/C on max, headlights, wipers, big stereo. and you are getting close. But then again. Many have lived and survived on a single.
Personaly I have the duals. cause you never know what you might want to add a year from now. And if one fails the other will get you home.
TRK4 Work: designer & consultant of emergency apparatus.
My Toy: 2000, F250, PSD, 4X4, XLT, SC, SB, Off Road Pkg, TT Pkg, Dual Alt. AIC, Line-X, Westin Grill/Brush Guard, Nerf Bars, Custom Scotchlite Striping Package, Nice Flashing LED and Strobe Lights LED, LED Tail/Marker Lights, Whelen Alpha12Q, On-Spot Automatic Snow Chains, and 03 Mirror Upgrade.
TRK4 is offline
Old 07-24-2002, 09:35 PM   #9 (permalink)
George C's Avatar
They are 130 amps.
My 2008 F-350
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 07-25-2002, 05:33 PM   #10 (permalink)
mtk
Single is 130A; duals are 110A each.
Moby aka Oxford White 2000 F350 Options: X31 617A Z1 22 99F 446 55R 531 T4R 63T XD1 592 54Y 67B 924 948 86R 433 58K 18L 674 90P 96P. Born 8/29/99; home 9/8/99. Added Ford: Bedliner, Bug Deflector, Mudflaps, & Foglights. B&W Turnover Ball GN hitch. Lowered via TSB 99-14-5; Front X Springs; LUK Clutch; OilGuard Bypass Filter. [DAC3] Michael Kasimirsky
mtk is offline
Old 07-25-2002, 06:01 PM   #11 (permalink)
OT
Michael, you don't need dual alternators ... you are hogging up the 70A 115V and 50A 230V outlet boxes at Summit! LOL!
&lt;note: mtk and I both belong to another BBS where current availability is a topic. :-)&gt;
YamahaRick is offline
Old 07-30-2002, 09:34 AM   #12 (permalink)
Send a message via ICQ to Jamie Contouris
Definately overkill in my opinion. I had my 130 amp tested running everything I have on maximum and could only draw down 65 amps. BUT remember this...if you get a single then you cannot go to duals later without spending an unbelievable amount of money. If by some strange reason you find that you need more power later on your best option to replace the single 130 is an ambulance amp which I think is close to 200 amps. Duals are for the boys who are racing to die with the most toys IMHO.
Jamie Contouris is offline
Old 07-30-2002, 10:13 AM   #13 (permalink)
I think that the redundancy factor makes it worthwhile. If you are 200 miles into, say, Baja California and your alternator croaks, you have another one to get you home.
Sarhog <font color="red">NRA</font> Life Member
2002 <font color="gray">Dark Shadow Gray</font> F250 XLT, Crewcab, <font color="red">PSD</font>, 4x4, auto, shortbed, Transferflow 46 gal replacement tank, ART slotted rotors, ISSPRO TTM, Walker BTM, Bilstein shocks
Autometer Z-series EGT, Boost, & Trans temp guages in A-pillar pod
2003 Thor Tahoe 27TB Fifth wheel Toyhauler
sarhog is offline
Old 07-31-2002, 08:15 AM   #14 (permalink)
Here is something you might consider. www.AURASYSTEMS.COM I don't know about the 8.5KW unit. The 5KW unit you could split the output between 12V and 120VAC. Just a tought especially for those of you that carry a camper.
2004 F350, Lariat, True Blue/Arizona Beige, CC, LWB, 6.0 PSD, Torqshift, FX4, Camper package, captains chairs, power & heated TT mirrors, adjustable pedals, AIC, dual alternaters, power sliding rear window. C-Betr mirrors, ARE K series cap, Bedrug, BFG MT 285/75r16,overhead DVD player, DPPI turboback dual exhaust, gauges, Husky mudflaps, Weather tech vent visors, and Lund bug deflector. Date ordered 12/23/2003. Delivered 2/5/04
http://community.webshots.com/album/122797684QJFiJY
MD-TDC Secretary
ktpauley is offline
Old 08-26-2002, 11:44 PM   #15 (permalink)
mtk
Not according to the Order Guide
130-Amps each
2003.25 , F550 Reg Chassis Cab , XLT , 165" WB , 4X4 , 6.0L , 6-speed , Arizona Beige , 40/20/40 ,Max Traction X6 , LS 4.88 , Security Group , Dual Alt , Dual Fuel Tanks , 6 Way Power Seat , Aux Idle Control .
'99 F-350, PSD, Reg Chassis Cab, XLT, 165"WB, 6-speed, 4X4, 8x12 flatbed.
'00 F-550, PSD, Reg Chassis Cab, XLT, 165"WB, 6-Speed, 4X4, 8X12 flatbed.
beeman is offline
Locate Ford Dealerships to find a new Ford for sale,
