Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Ordering Information
Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 03-02-2007, 01:43 PM   #1 (permalink)
F250 vs. F350
This may be a stupid question, but if I order a F250 4x4 Crew-Cab SWB 6.4L is there a real difference between the F350 with the same equipment, or is it just a GVRW number? I used to be under the impression that the 350 had better axels, stiffer springs, and maybe some other various differences, however I have heard that the only difference is GVRW.
Adam
2008 F250 6.4L 4x4 156" KR CC - "Job 2"
Ordered - 7/26/07, Built - 8/27/07, Purchased - 8/31/07, At Home - 9/5/07
cadamwil is offline
Old 03-02-2007, 02:23 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: F250 vs. F350
For a coupla years around 2001 there was virtually no difference between the F-250 and the F-350 SRW, other than the standard tires and the size of the spacer block in the rear suspension of 4x4s. But the news got out, so Ford put back in some differences.
For the 2007 models (and probably 2008 models too), the big difference is rear spring rating and rear axle rating. Also standard 17" tires and wheels on the F-250 vs. 18" on the F-350 SRW, although 18" and 20" tires are wheels are options on the F-250.
<font class="small">Code:</font><hr /><pre>
F-250 F-350 SRW
tires LT265/70R17 3,195 pounds LT275/70R18 3,640 pounds
wheels 17x7.5" 3,195 pounds 18x8" 3,525 pounds
rear main springs 6,100 pounds 7,000 pounds
rear axle 6,200 pounds 7,280 pounds
</pre><hr />
SmokeyWren is offline
Old 03-02-2007, 04:23 PM   #3 (permalink)
Re: F250 vs. F350
smokey..... where did you get that infomation from? Are there any other differences that you know of? Are the rear axles totally different on the 250 vs. 350? Or is that rating taken from the load capacity of the tires?
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 03-02-2007, 07:38 PM   #4 (permalink)
My Photos: (6)
Re: F250 vs. F350
Axles on the 350srw have a slightly larger diameter and more splines. Uses the same housing though.
2007 F350 CC Lariat FX4 6.0PSD SRW SB
Super08 is offline
Old 03-02-2007, 08:08 PM   #5 (permalink)
Re: F250 vs. F350
Do all the F350's get overload springs or just the "camper" or "heavy service suspension" packages?
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
Old 03-02-2007, 11:00 PM   #6 (permalink)
My Photos: (6)
Re: F250 vs. F350
From 05 or 06 and up all 350s come with the aux springs standard. The 250's only get them with the pkgs you mention and well as the stabilizer pkg.
Super08 is offline
Old 03-02-2007, 11:24 PM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: F250 vs. F350
Ford Truck Source Book. Every dealership has at least one copy, and big dealers have several copies.
Not that I know of.
Yes. They are the same basic design (Ford design with 10.5" ring gear) and they are both made in the same plant (Ford Axle Plant in Sterling, MI). But they have different specs. The actual axle shaft for the F-250 is 1.36" minor diameter spline and 1.50" major diameter spline and 35 splines. The shaft for the F-350 SRW is 1.50". 1.57" and 37 splines.
Yes, the Ford engineers must be in a conspiracy to use F-350 SRW axles under F-250s, because that somehow cheats the F-250 owners. [img]/ubbthreads/images/graemlins/wink.gif[/img] The problem with that conspiracy theory is that any third grader can count the splines and tell you that they are different. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 03-03-2007, 12:46 AM   #8 (permalink)
Re: F250 vs. F350
I do not know about the spec, but I bought an '08 F350. It rides better than my '04 F250. My guess is the longer rear leaf springs.
'08 F350 PSD King Ranch 4X4 with every option but rear DVD. (had to have sunroof)
AR50 is offline
Old 03-03-2007, 09:59 AM   #9 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: F250 vs. F350
According to the 2004 Ford Truck Source Book and the preliminary version of the 2008 Ford Truck Source Book, the 2004 F-250 and the 2008 F-350 SRW have rear leaf springs of the same length = 58.1". The weight capacity of the rear spring pack changed, but not the overall length.
Old 03-03-2007, 10:04 AM   #10 (permalink)
Re: F250 vs. F350
[/ QUOTE ]My 06 rides better then my 04 did as well and I attributed that to the coil springs that replaced the leafs in the front.
Smokey, I thought Ford's advertising was saying they lengthened the rear leafs on the 08's?
Steve Urban
Semper Fi!
Old 03-03-2007, 01:07 PM   #11 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: F250 vs. F350
May be, but the only specs I've seen says the main leaf is the same length as the previous model's. However, that "preliminary" version of the 2008 Truck Source Book has lots of errors, so maybe that's an error too?
Old 03-04-2007, 01:49 PM   #12 (permalink)
My Photos: (6)
Re: F250 vs. F350
The 08 does have longer rear leafs, seen them in person...
Super08 is offline
Old 03-05-2007, 09:02 PM   #13 (permalink)
Re: F250 vs. F350
I just went from a 2002 F250 XLT LB CC 2 Whl drive to a 2008 F350 XLT CC LB 4x4. I hooked up to my 5th Wheel this afternoon for a test drive. Even though I had just installed a new on-board compressor and AirLifts I left them at the Minimum inflated 5lb pressure on purpose. When I lowered the 5th Whl on the hitch it didn't hardly squat at all. With my F250 I usually ran 80-90 lbs in my air bags to get to level. I did pump the new ones up to 30 lbs for the test drive. When I got out on the level street I stopped and put a level to the trailer overhang and the bubble was perfect. No adjustment required. I have 8-9 inches of clearance between the bed rails and 5th Wheel. I might add, the tow command system is awesome. I never made any stops over 30 MPH but I could really tell a difference over the Prodigy on my 2002 and it was the best controller I ever had, bar none. I can not get over the smooth and quiet ride of this F350 4x4 compared to my previous F250. I believe we have a winner
2008 F350 XLT CC 4x4 SWR LB, V10,Auto,Tow Command, loaded
2008 Cardinal 34QS Fifth Wheel, Thermopane Windows,2d Air Cond, EquaFlex
donpop36 is offline
Old 03-06-2007, 12:07 AM   #14 (permalink)
Re: F250 vs. F350
can anyone tell me the exact price difference between a 250 &amp; 350?
RRose is offline
Old 03-06-2007, 12:57 AM   #15 (permalink)
My Photos: (6)
Re: F250 vs. F350
For 2005 to 2007's srw trucks....Size of the standard wheels (17" vs 18"), rear axles have different diameter &amp; splines, 350 comes standard with rear aux springs, 350 4wd has 4" axle blocks, 250 has 2" rear axle blocks, 350 has different rear shocks (longer) and different carrier bearing mount (lower). Spring rates dependent on options. That's about it.
Super08 is offline
