I just received a copy from my dealer. It is dated 12/01/07.
It relates to the F450.
Front license plate bracket no longer standard. It is now a option and forced in states where required.
Rapid heat now available on manual tranny.
Engine idle shut down is required on 6.4L diesel with auto tranny in the following states: CA,CT,DE,GA,ME,NJ,NY,NC,PA. The number of minutes are not shown. Exemptions need state certification or truck is to be delivered to another state.
Reverse aid sensor not available with engine shutdown feature.
Engine block heater standard in MI,VE,ID,NY,NH.
The high capacity trailer tow package (535) is no longer available. The standard max GCWR for F-450 PU with auto is now 33,000 lbs. The standard max GCWR for F-450 PU with manual tranny remains 27,000.
Winter front grill is now standard and only available in the following states: AK,CO,ID,IA,ME,MI,MT,NH,NY,ND,SD,VT,WI,WY.
JOB 3 ORDER GUIDE UPDATES – Effective on all vehicles built on or after Job 3 (01/02/08 – Subject to change)
<ul>[*]The 60th Anniversary Edition (17A) is now available on XLT SuperCab and Crew Cabs. It includes a two tone exterior paint combination in Black with Dark Shadow Grey lower accent or Dark Shadow Grey with Black lower accent, Chrome billet-style grille, 5" chrome running boards, chrome exhaust tip, chrome tow hooks and chrome pickup bed tie-down hooks, chrome mirror caps, body color front and rear bumpers, accent color wheel lip moldings, and unqiue 60th Anniversary Edition wheel ornaments, box decals and badges. The Medium Stone interior includes Sport Cloth Captain's Chairs, a leather wrapped steering wheel, unique instrument cluster appliqué, 60th Anniversary center console badge, serialization plate, and more. Please see the Packaged Options page for a full list of package contents.[*]Power 4-wheel disc/4-wheel anti-lock brakes with vacuum boost are now standard on SRW with all engines. Power 4-wheel disc/4-wheel anti-lock brakes with hydro-boost are now included on SRW with the Dual Alternators and optional on SRW diesel for fleet only.[*]There have been changes made to the standard and optional axles in the Axle Availability chart. Please review the Axle Availability chart for all axle availability changes.[*]The Front License Plate Bracket is no longer standard. The Front License (153) is available as an option on all trims and is forced in states where required.[*]The Rapid-Heat Supplemental Cab Heater (41A) is now available with manual transmission.[*]The PowerScope™ Trailer Tow Mirrors (54F) are now available on XLT Regular Cab (require the Advanced Security Group).[*]A Winter Front Grille Cover is now standard and only available with the 6.4L diesel engine in the following states: AK, CO, ID, IA, ME, MI, MT, NH, NY, ND, SD, VT, WI, WY.[/list]
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MT765</div><div class="ubbcode-body">Whats with the engine idle shutdown feature? I presume it's supposed to help with emissions, but why do they need to?</div></div>
From what I have heard, the Job #3 diesel powered vehicles in green states will be programmed to shut down automatically after idling over 5 minutes. If a truck has the PTO provision, and it's hooked up, the program will allow the truck to idle for 15 minutes.
On Edit: I think this is only for vehicles OVER 14k GVWR. I'll double check and post back.
<<<<<<<<<<<<&l t;<<<<<<<<<<<< <<
Ho stupid can these dumb ass engineers get? Apparently there is no limit on stupidity.
Say you are working for the power company, whether on the lines or cutting downed trees off the lines.
You are freezing and wet. You go to your truck to get warm.
And the damn thing will not run long enough to get warm, much less warm you.
Hunters, cattlemen, all sorts of people need for their truck to run until they turn it off.
You are working a wreck and a volunteer fireman. You need lights. It cuts off the engine after 5 minutes?
I can not believe what this country is coming to.
A nation of engineering geniuses with zero common sense.
CSSJR
If we do not wish to lose our freedom, we must learn to tolerate our
neighbor's right to freedom even though he might express that freedom
in a manner we consider to be eccentric.
That package has two things I sure could have used! The supplemental cab heater with a manual transmission, and that front grille cover (std. for AK).
Rats!
Sold: 1999 White Lariat CC SB F-250. Sold to next-door neighbor in 2001....received final payment 2007! Still going strong at 198Kmiles as of Dec'07
Sold: 2001 Bright Amber Lariat CC LB F-250 with 4 million candlepower of LightForce lights in the bow. Line-X bedliner. Dual alternator. Clearance lights. Glass-tite cap. 250-gallon auxiliary tank for trips to the Lesser 48. 70-gallon auxiliary for trips around Alaska. Rec'd Dec'07: '08 ForestGreen/Gold F-350 CC LB. Handshaker, as always, Rear stabilizer, rear static video, rear step, dual alternators. B&W turnover ball on its way; soon to be Line-X'd. LightForces on their way.
Alaska Ranger what no grill cover? was that because oaf the order state? or the ship sate...im in viscon and got the winter cover!, helps keep the airfinter from getting iced up in a heavy snow...and i geuss that was why they gave it out...from the 'broadcast secrvice message i read.
~ Mike
2008 BLACK F350 XLT RC SRW 4x4, 6.4, Auto,3.73ls, ManualTransferCase,PTC-Heater. Pic's She is Sweet...
DORA recieved:9/14/07 || ReceiptDate:9/14/07 || SerializeDate:11/01/07 || SegmentDate:11/01/07 || SequenceDate:11/10/07 || BlendDate:11/13/2007 || GesitmatedBuildWeek: 12/10 || ProducedDate:11/21/07 || GateRelease:11/21/07 || ShipDate:11/24/07 || ArrivalDate:11/30/07 || SoldDate:11/30/07 ||
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Alaska Ranger</div><div class="ubbcode-body">Any insight on this, Bobby? </div></div>
Being that the vehicle was registered to "Alaska" we should be able to get a hold of it. Let me do some checking.
