6.7 on natural gas conversion - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
Old 02-21-2013, 12:38 AM   #1 (permalink)
has any one seen theses kits,my local city has converted a new 6,7to natural gas and he told me it was a beast.it went from 14mpg to 30mpg on natural gas.it must be pretty good thing.cause they are planning on converting every vehicle in there fleet.does anybody know anything about this?
12superduty is offline   Reply With Quote Quick reply to this message
Old 02-21-2013, 07:15 AM   #2 (permalink)
I have a buddy who does these conversions on smaller F150s and Ranger fleet trucks. He says it becomes profitable for the companies if they put on 30k miles a year or more, and have a 50% tax credit. Also you need to have a decent area for natural gas pumps. The storage tank is pretty big as well.
8mpg is offline   Reply With Quote Quick reply to this message
Old 02-21-2013, 08:44 AM   #3 (permalink)
You sure it was a 6.7 and not a 6.2 gasser? I've only heard of it being done to the 6.2. I wouldn't think it'd be possible on a 6.7 unless it was just a fuel supplement like propane.
Natural gas has a lot less energy than gasoline so I wouldn't believe the 30mpg claim. That may just be a cost equivalent.
2014F450 is offline   Reply With Quote Quick reply to this message
Old 02-21-2013, 02:45 PM   #4 (permalink)
it is the 6.7.i seen it with my own eyes.they also have a f650 diesel that they have put it on also.
Old 02-21-2013, 03:19 PM   #5 (permalink)
ViperKiller's Avatar
when you say "14mpg to 30mpg" I assume you mean the equivalent of 30mpg since natural gas is not measured in gallons.
either way.... I doubt 30mpg equivalent.
2012 F-350 KR 6.7, CCSB 4x4, Carli 4.5" Pin Top 2.5, prog leaf packs, 1" blocks, long travel airbags, AirLift WirelessAir, 5gal OBA, Amp steps, B&W Hitch, BakFlip F1, Kenwood DNX-9990, JL 700/5, BA Comp, 2-PGold 10", Rigid Ind 20" light bar, 295/65-20 Toyo M/Ts on OEM wheels.
Sold - 2005 F-250 Lariat 6.0 Crew, SB, 6 Speed, 4x4, Wedgewood/Tan
2008 Hydra-Sport 23 Bay Bolt w/ Etec 250
2003 Sonic Blue Cobra 666rwhp 600rwtq,
1997 Jeep Wrangler B3.3T Cummins, NSG370 6 speed, Ford 8.8 rear, Dana 44 front, 37x12.50 PitBull Rockers
ViperKiller is offline   Reply With Quote Quick reply to this message
Old 03-01-2013, 01:03 PM   #6 (permalink)
GGE- Gas Gallon Equivalent.
GGE Calculated for Gasoline in US Gallons at 114000 BTU per Gallon
Fuel - Liquid, US Gallons GGE GGE % BTU/Gal
Gasoline (base)[3] 1.0000 100.00% 114,000
Diesel #2[5] 0.8800 113.64% 129,500
Biodiesel (B100)[5] 0.9600 104.17% 118,300
Bio Diesel (B20)[5] 0.9000 111.11% 127,250
Liq natural gas (LNG)[5] 1.5362 65.10% 75,000
Liq petroleum gas(LPG)[5] 1.3500 74.04% 84,300
GGE calculated on Non-Liquid Fuels
Fuel - Non Liquid GGE GGE % BTU/unit
Gasoline (base)[3] 1.0000 100.00% 114,000 BTU/gal
Comp nat gas(CNG)[5] 126.67 cu ft 114,003 BTU/126.67 cu ft
(####s pulled from Wikipedia, so I cannot attest to their accuracy.)
Gasoline engines can run dedicated CNG, diesel engines must run dual fuel to achieve ignition. Normal ratios are anywhere from 20%D80%CNG to 35%D65%CNG.
The only problem with the CNG conversion is the DEF and emission systems. While on CNG, DEF is consumed at twice the rate compared to 100% diesel. For the dual fuel system to function properly, the DEF must be turned off with a tuner, which voids warranty. (I have spoken with a Service Manager of a stealership who said he has already converted his 6.7 Scorpion to DNG. I did not see it with my own eyes. I guess he would be the one to make the call on warranty work, so he is in the clear? To back up 12superduty, the Service Manager also claimed a jump in MPG from 20mpg on deisel to 37mpg on DNG. The DNG conversion company I am using is also claiming similar number on their,already converted, 6.6 Duramax[s] and 6.7 Cummins.) Note: I may have gotten the size of the Cummins wrong. I do know it is a Cummins pre-DEF, so it may not be the 6.7. I am not a Dodge guy.
I have heard talks of increased horsepower and torque along with the increased MPG on DNG. I am skeptical. We shall see soon.
Regarding the warranty: The conversion company I am using has a petition in with the EPA and Ford. If the EPA says its cool to circumvent the DEF and emissions systems, Ford will allow conversions on their diesels without voiding the warranty. The EPA needs to be convinced DNG burns cleaner then diesel. (So I am told by the conversion company owner.)
Regarding the MPG increases: There are some funny numbers floating around. There are different ways to extrapolate the MPG, similar to differing account methods. I just hope the MPG increase numbers are not coming from accounting methods similar to what our federal government uses, if you know what I mean.
Last edited by GAZ69OK; 03-01-2013 at 01:12 PM. Reason: glaring grammatical errors
GAZ69OK is offline   Reply With Quote Quick reply to this message
Old 03-01-2013, 04:11 PM   #7 (permalink)
So nobody has a name of this conversion company? Website?
Old 03-15-2013, 11:32 AM   #8 (permalink)
drwoodchopper's Avatar
Air stumbled upon this thread. I run CNG on my 7.3. It is not a true conversion, you are still running some diesel and not straight natural gas.....you don't have a spark plug. I regularly get over 30mpg's on the diesel and 16-20 on the CNG. The reason it is a beast is because you are adding more fuel when you really step on it. I would think you would use less DEF because the CNG burns cleaner and you are using less diesel. My oil stays cleaner longer by way of blackstone analysis. I love the system on my 7.3 and have thought about doing it to my wife's 6.7.
1997 F350 CC4X4 150K superclean truck Beans 6 pos chip! IDM mod, Pyro, Boost and Trans Autometers over mirror. Oil and Water temp in hand built "hump cubby" 4" straight pipe! . Ford V-10 trans cooler, Tymar Intake, 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline in front of a BTS. WOP QSSB turbo e-fuel conversion and a custom CNG system. Wifes ride 2011 F350CCSWB mostly stock. My Youtube vid. http://www.youtube.com/watch?v=fdXy-bV6Zks
drwoodchopper is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
