Rotella oil help - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
 3Likes
post #1 of 17 (permalink) Old 02-23-2017, 01:57 AM Thread Starter
Skylor's Avatar
Rotella oil help
Manual says 10w30... I live in Alaska so it gets cold and stays cold. Will that oil hold up in the cold or am I better off just running a 5w40 full syn.
Also from what I understand 10w30 is a synthetic "blend"...
Skylor is offline
post #2 of 17 (permalink) Old 02-23-2017, 04:46 AM
I would run 0w30/0w40 or 5w40 per manual for your extreme temperatures.
Larry
larrgh is offline
post #3 of 17 (permalink) Old 02-23-2017, 07:52 AM
ArcticDriver's Avatar
It would be advantageous to run a full synthetic 5W-40 such as Rotella T6.
For that matter, switching all of your fluids to 100% synthetic would be a wise practice.
Especially if you are making trips north.
Finally a great snowmachine season, eh?
EDIT: Rotella does have a 0W-40 Full Synthetic Diesel rated oil but I have only seen it Canada and its not cheap.
2000 F-250 4x4 SC SB 7.3 PSD w/4R100. 160,000 miles.
NOS Black CPS. Rebuilt Fuel bowl w/gold spring, 6.0 Cooler, Walker BTM, Stancor GPR, AIH Delete, ScanGauge II, AIC, 2002 Headlights, Bilstein 4600, Marinco Mod, Cupholder Upgrade, B&W Turnover Ball, Michelin LTX
2002 F-250 4x4 CC SB 7.3 PSD w/4R100. 160,000 miles.
NOS Black CPS. ScanGauge-II, Bilstein 5100, Marinco Mod, B&W Turnover Ball
ArcticDriver is offline
post #4 of 17 (permalink) Old 02-23-2017, 09:52 AM
2015_PSD's Avatar
If you are regularly seeing temperatures to the left of the red line (taken from the diesel supplement) I would run a xW-40 or xW-30 and call it good. You are correct that most 10W-30 oils are synthetic blends.
2015 Tuxedo Black F-250 Platinum (FX4)
Currently running Chevron Delo 400 LE 5W-40 (CJ-4) oil and CQ Blue 84151 (WIX) oil filter
All Stock except for a few accessories:
- Rhino Spray-In Bedliner
- Ford Splashguard/Mudflaps
- Husky Rear Wheelwell Liners
- Bull Ring retractable tie downs
- Leer 700 Bed Cap
- Mag-Hytec Rear Axle Cover
- Mag-Hytec Front Axle Cover
- OEM Rear Sway Bar
- All interior & exterior LEDs including bed
2015_PSD is offline
post #5 of 17 (permalink) Old 02-23-2017, 02:47 PM Thread Starter
Skylor's Avatar
Thanks for the info guys. Ya I'm leaning towards doing a 5w40 for all year long to make it easy on myself. I suppose I could run a 10w30 for summer use but I've always been on the wagon of using a full synthetic.
ArcticDriver and 2015_PSD like this.
Skylor is offline
post #6 of 17 (permalink) Old 02-24-2017, 01:50 AM
Azrael15's Avatar
I'm living in Fairbanks, we saw -50 here a time or two this winter. I'm running full synthetic 5W-40. No issues with starting in my 2012.
Phillippeterson likes this.
Azrael15 is offline
post #7 of 17 (permalink) Old 03-09-2017, 07:09 AM
yes 0w40 or 5w40 will work well for you....and u can leave it in for the summer too, no worries there.
Chrome ash tray with extra LED light!
Blacked out rear view mirror
Badazz sticker on bumper
3.5" x 10" exhaust tip.....painted BLACK!!!
One floormat...hope to get a Wethertek one someday!
Lots of really cool black stuff! Yes I'm a rebel!
TWO pairs of BLACK Driving gloves (made from GENUINE Saskatchewan seal skin)
08F350 is offline
post #8 of 17 (permalink) Old 04-20-2017, 09:21 AM
I've run this lots too. Not sure if it's available in Alaska though.
Mobil Delvac 1 ESP 0W-40
Mobil Delvac 1?*ESP 0W-40 | Heavy Duty Engine Oils | Mobil? Canada
08F350 is offline
post #9 of 17 (permalink) Old 04-21-2017, 06:16 AM
I see the 0W-40 weights in Canada regularly but its seldom an on the shelf item in the Great Land.
post #10 of 17 (permalink) Old 04-24-2017, 08:58 AM
JimTJr's Avatar
My Photos: (20)
There is another thread extensively talking about the oils in the regular 6.7 section.. seems Ford has changed their minds on the specifications for the recommended oils,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #11 of 17 (permalink) Old 05-13-2017, 08:07 AM
wpetko's Avatar
My Photos: (17)
Yup. 5-w-40 year round is what I do. 'So easy.
2013 F-350 Lariat 6.7 L PSD Crew Cab Dually, FX4, white platinum metalic tri-coat with black interior, N-Fab step bars, factory spray-in bedliner and 5th wheel hitch, trailer tow package, integrated brake controller, upfitter switches, Sync with My Ford Touch, memory group, remote start, reverse sensing with rear view camera, nav, satillite radio, Weather Tech floor mats, limited slip diff, moon roof, climate controlled seats, engine block heater and tailgate step.
2014 Lifestyle (formerly Carriage) 5th wheel 38' long with 3 slides & all the goodies.
SOLD: 2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
wpetko is offline
post #12 of 17 (permalink) Old 05-14-2017, 05:14 AM
Mobile Delvac 1 is the real synthetic that's why the poor Point. It's much better than Rotella T6 48 to 50 below zero!!!
- 42 Celsius equals -43.6 Fahrenheit for Rotella T6 5-40
- 45 Celsius equals -49 Fahrenheit four Mobile one Delvac 1 5-40
1914fatboy is offline
post #13 of 17 (permalink) Old 05-14-2017, 06:18 AM
Mobil Delvac-1 is an outstanding Diesel Motor Oil but that does not mean Shell Rotella T6 is not an excellent oil as well (atleast the CJ-4) and, surprisingly, Pour Point is not the most important consideration in extreme cold weather operations
Pour Point:
Shell Rotella T-6 5W/40: -42*C
Mobil Delvac-1 5W-40: -45*C
post #14 of 17 (permalink) Old 05-16-2017, 04:16 PM
Azrael15's Avatar
So just for discussion sake, what is the most important cold weather consideration for motor oil?
Azrael15 is offline
post #15 of 17 (permalink) Old 05-21-2017, 01:32 AM
I read an article that mentioned you should not start an engine at no less than 20 above the poor point so I consider that in Minnesota when I look at purchasing oil it can get to 30 below zero in southern Minnesota or if you're at a motel in Duluth. I currently use Mobil Delvac one 5-40 because it has the poor Point 49 below zero Fahrenheit so technically I can start it at 29 below zero not that I'm going to do that if I can help it ,I also can get my fuel down to about 37 below zero , I also like the oils that will deliver in the summer months trucks are running at 80,000 miles without any problems ,I change at 5,000 miles , I would like to run Mobil Delvac 1 LE 5-30 it has a Poor point of 59.8 below zero Fahrenheit and would be an excellent summer oil semi's running it 80,000 I will have to settle for the 5-40 at $27 a gallon 5-30s hard to find I would think the zero30s and zero40s would get you way down into the basement Poor point, I only put on five or 6000 a year so if I had to I would get Amsoil 5-30 3,000 if I had to, and run it all year The price wouldn't affect me at one oil change , whatever you can fine in your area could be a whole different ballgame hope this helps a little !!!
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
