5th Wheel Hitch with Bed Mat - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 1Likes
  • 1 Post By _Tomahawk_
post #1 of 12 (permalink) Old 08-31-2010, 06:49 PM Thread Starter
This is something I have wanted to do since I got my 5er.
Have the bed mat in the truck while the hitch is in place,
but I didn't want to cut large rectangles in the mat to fit
over the bed rails of my old hitch.
So when I installed the Reese Elite hitch the first time I
noticed there was about a 3/8" gap between the bottom
of the hitch legs and the truck bed.
All you need to do is measure from the front of the bed
and the sides of the bed where the center of the attachment
points are for the hitch, place the bed mat into the bed and
transfer the attachment point locations.
Then cut 3" squares or circles to clear the pucks.
Now my coolers etc. do not wander around while I'm driving
down the road.
Just cut the holes in the bed mat.
Dee Zee 86881 bed mat from Jegs - $61.99
Dee Zee 86881 Dee Zee Heavy Weight Custom Truck Bed Mats
Install the hitch!
No more taking out the hitch, putting in the bed mat......
_Tomahawk_ is offline
post #2 of 12 (permalink) Old 08-31-2010, 08:26 PM
senix's Avatar
what is the rating on the hitch that comes from ford?
Right now I have the signature series 18K slider that is the same type. It is suppose to work with a kit to change the pucks.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 12 (permalink) Old 08-31-2010, 09:40 PM
equidoc's Avatar
Tomahawk,
I did the same for my gooseneck. With the ball and anchors removed, I can reinsert the plastic plugs, so the holes don't get full of crap.
I bought a 2008-2010 deezee mat, which fits ok, but the bump out for the fuel filler is bigger on the 11, so it doesn't fit perfectly in the Left corner.
2011 f-350 Lariat, 6.7l, SRW, LB, CC, 4x4, 3:55 e-locking diff (play truck)
2008 f-150 XLT CC, 5.4l, 4x4 (work truck)
SOLD--1996 f-250 XL, 7.3l, 4x4, 5 speed manual, 4:10 rear, as stock as the day I drove it off the lot
SOLD--1995 f-150 XL 4x2, 5 speed manual, 4.9l straight 6
Junked 1989 Ranger 2.9l v-6.
equidoc is offline
post #4 of 12 (permalink) Old 09-01-2010, 05:16 AM Thread Starter
Senix,
I'm not sure about the rating on the Ford hitch.
While I was waiting and waiting for my truck
to be delivered, I picked up one of the older,
and cheaper Elite series hitches and the adapter kit.
The kit was simple to install.
Are you thinking about getting an '11?
post #5 of 12 (permalink) Old 09-01-2010, 05:22 AM
senix's Avatar
Originally Posted by _Tomahawk_ View Post
Senix,
Thinking..sort of. My dealer e-mailed me asked if I wanted to trade up. Shot me a window sticker of a decked out one of course. Commerical line had it all.
So I asked what he would give me. I looked mine up on KBB. I think I could pull about 30-35K from mine.
Don't think I will hear back.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #6 of 12 (permalink) Old 09-01-2010, 06:19 AM
Trimble1's Avatar
That was a great idea, looks nice too. Good job.
Jim
2011 F350 Lariat CC LB SRW FX4
Fifth wheel option, 3:55 elocker
'09 Keystone Everest 345S
Trimble1 is offline
post #7 of 12 (permalink) Old 09-08-2010, 04:35 PM
The Ford hitch has a 25K rating.
dubblegee is offline
post #8 of 12 (permalink) Old 09-08-2010, 04:37 PM
Tomahawk, mat looks good with the hitch, did you have any clearance issues with the mat under the hitch?
post #9 of 12 (permalink) Old 09-08-2010, 04:57 PM
dsroka80504's Avatar
Senix - If you want auction prices for your truck, let me know and I can look up your exact rig at the auction. More than likely, will be a better idea of what you can "expect" than KBB. Many times trades are overinflated in KBB because of people being upsidedown in cars. Auction or Black Book will give you real world what the dealer could buy your truck for. Let me know.
2011 F350, CC, SB, Lariat Ultimate, Chrome Package, 4x4, FX4, White Platinum, 6.7L (SOLD)
2001 F-250 CC Lariat, LB, 4x4. 205K and Traded in
1996 F-250 XLT Regular Cab, 4x4, 187K. Bartered for construction work.
2010 Cougar 32RLB 5th Wheel - Traded in 1/22/11
2011 Road Warrior 30C Titanium Edition (SOLD)
dsroka80504 is offline
post #10 of 12 (permalink) Old 09-09-2010, 06:50 PM Thread Starter
About 1/16", it's a perfect fit.
bear1 likes this.
post #11 of 12 (permalink) Old 01-22-2017, 10:03 AM
I have the Square Reese adapter that fits in the puck holes and then the Reese hitch sits on top of it. My question is how big of hole should I cut in my bed rug?
2004 f250 4x4 sd cc
bear1 is offline
post #12 of 12 (permalink) Old 01-22-2017, 11:47 AM
I would measure the outside diameter of the metal pucks that come through the bed floor that have the large plastic ring snapped on it. I would start with the size opening and adjust the hole size from there.
You can always go larger but not smaller on the holes you cut. With small holes at first, you can also reshape the holes in case you miss cut one.
If i were to install a mat, I would do it the same way you use to cut gaskets from gasket paper.
I would remove the small plastic plug in each of the 5 pucks. Then lay the mat in the bed and center it. If needed, use some weights to hold in place. Then take a rubber mallet and tap each of the 5 pucks to transfer an imprint of them to the bed mat. Remove mat and cut the openings. Install mat and check for adjustments need to the 5 openings. Try to install the hitch in the 4 pucks and see if adjustments need to be made for it. If all ok go get beer. If not, scratch head and contemplate adjustments while you drink beer buddy hands to you.
Larry
larrgh is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
