Hi,
I want to add a fuse to the passenger compartment fuse panel for a dash cam, I want to power with key on (otherwise I could drain the battery. Looking in the owners manual I see a layout of the fuses (see attachment) I bought a add a fuse at an auto parts store but just looking for advice which fuse to tap into. I suspect 10 Amp circuit should be fine. Just for easy access for me I was looking for a circuit below fuse 40. Any ideas / thoughts would be welcome. See signature block for truck information.
Note: I didn't want to plug into the cig outlet direct because I wanted to hide / keep clean the wiring.
I added the fuse section of the owners manual.
