I added the factory style backup camera I haven't been able to find much were anyone did this other then on the F150s. I was able to find most of the diagrams I needed from here.
09 rear view camera - Page 18 - Ford F150 Forum - Community of Ford Truck Fans
I was putting this in my 2011 F250 XL regular cab long box. My pickup had zero wiring to the mirror which somewhat simplified it and also meant I had none of the needed wiring.
What I used
Ford Mirror with Monitor mine came off ebay a takeoff from an expidition with a 6" pigtail $125 on ebay
11 Tailgate handle with Camera $65 from tasca parts
11 Tailgate Camera $275 tasca parts
16/3 wire I used a 25ft 16/3 cold weather extension cord
16/4 wire 4ft roughly
4 pin connector I used a 4 pin trailer connector
misc connectors, zipties tape ect(I used all connectors with the built on shrink rap)
Starting in the back I cut the harness on the camera open hooked the 16/4 to that end you need switched power, ground, and video + and - I skipped the shielding wire and my picture looks great. Then run the 16/4 down through the tailgate out the hole just to the right side of the center of the tailgate and down around under the box and put your 4pin connector on.
Now take the 16/3 wire and splice one end into the trailer connector you need the middle wire which is backup and figure out the ground and switched power also. Then run that over to were your connector from the tailgate is. Cut the out jacket open leave the wire that was hooked to the backup signal alone and cut the ones that are power and ground. Hook those to the appropriate spots on the connector and then use the other side of the same wires and hook them to the connector for your video + and -. Now run that wire along the frame and into the cab up the corner post along the front of the headliner to the mirror.
Here is were if you already have a 10pin mirror connector it will get more complicated and also easier then my installation. You'll have to cut all the wires from your 10pin connector and wire them into the appropriate spots on the new 16pin and hook in the 3 wires you just brought to the appropriate spots also. In my case I had nothing so I ran another 2 strand wire hooking a switched power from the bundle behind the data port near the park brake to the in my case yellow/orange wire or in EB it says it can be white/blue and wired the ground to the metal frame under the dash.
I also hooked the reverse wire up through a relay so I can turn the camera on with a up fitter switch also using directions from here http://www.thedieselstop.com/forums/f55/backup-camera-idea-210757/
I'm including all the diagrams I used to figure this out and a real simple one of what I did. The colors might not match they didn't in my case but the pins did.
What I used
