AirBag - Suspension Components - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #1 of 7 (permalink) Old 01-29-2017, 08:05 PM Thread Starter
hd883chopper's Avatar
Greetings fellow SuperDooties
So I've recently upgraded from a 2012 F250 to a 2014 F350 Dually, great truck and pretty darn good deal I think. It came with a Firestone load leveling airbag kit. I'm new to these airbags and fiddled some with it, but unfamiliar with this set up so I'm extra cautious. Hoping ya'll could educate me on a few items.
I've located the PSI gauge in the truck with 2 pressure switches, one for left rear and one for right rear. Also located the air reservoir for the system, the small motor (connected to aux switch in cab) and the air inlet at the rear of the truck.
1. Silly question I'm sure but what is the motor for? Is this an onboard air compressor possibly? If I air up the system at the tail of the truck, that fills the reservoir right? Then if I go into the truck cab and push the switches on the PSI gauge, that allows the air to go from the reservoir to the bags themselves and I can visually see the rear of the truck rise. So...if it is an air compressor, I suppose its so I can add air to the reservoir independently? Meaning without outside compressor assistance? Or I guess air my tires if need be. What do ya'll think?
2. Probably another goofy question but when I bleed the air from the airbags by using the switch in the cab, does the air bleed out or transfer back to the reservoir for future use? I wasn't sure if by bleeding air and essentially lowering the rear, I would be forced to use an outside compressor to refill the reservoir and give me the option to raise it up again later.
3. Is there ususually an air filter associated with these systems? Found some references to it online but no hard evidence on what it looks like or location. If there is one, I'm assuming these need to be changed or inspected regularly right?
I appreciate any info ya'll have for an air newbie!
Thanks,
Hd883chopper
Current: 2014 F350 4X4 Platinum Dually 6.7 Powerstroke
Previous: 2012 F250 4X4 Lariat FX4 Fleetside 6.7 Powerstroke
Previous: 2005 Excursion 4X4 Limited V10 Gasser
hd883chopper is offline
post #2 of 7 (permalink) Old 01-30-2017, 04:58 AM
Googs's Avatar
Yes that is an onboard compressor , probably ARB . Some compressors have their own air receiver , yours has a separate receiver.
As soon as you activate the toggle switch to the compressor inside the cab you'll have air filling the receiver.
Yes you could use the air from the receiver to inflate your tyres, only if you have an additional air fitting in line that's not being used for anything else.
When you bleed the air from the Air Bags with the on board switch the air is bleed out the back of the control switch inside the cab.
Not sure about your compressor but most ARB onboard compressors have a light duty air filter (if that's what you choose to call it) It's just a plastic cover to stop the big stuff from entering the compressor motor.
https://www.arb.com.au/products/arb-compressors/
ID:	104138   Click image for larger version
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R Turbo, WW2, Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, Foil delete.
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks,MAG-HYTEC diff covers, MAG-HYTEC Deep pan trans cover,Hornblaster Train horns, Chassis mount transmission filter, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is online now
post #3 of 7 (permalink) Old 01-30-2017, 10:37 PM Thread Starter
Thanks Googs. I appreciate the info. So I guess I have a choice whether to air up the reservoir from the inlet at the rear of the truck or use the little air compressor. Nice option.
Any maintenance necessary on a set up like this? Other than monitoring any leaks of course.
Thanks for the help
post #4 of 7 (permalink) Old 01-31-2017, 08:43 PM
Googs's Avatar
A piece of felt or some filter media in the plastic filter housing would cut down on dust entering the compressor motor. ( not to thick)
I have water traps/regulators fitted to the outlets of my set up , just to keep the moisture out of what ever I'm inflating or dusting down.
I have a larger air compressor on board with a 5 gallon receiver (100% duty) that i use to inflate the complete set of tyres from the truck and the camper.
Not knowing your set up or seeing it i would be a little sceptical about inflating all your tyres at the one time with an ARB type compressor.
This type of compressor is mainly used for diff locks / air ride bags, but in saying that you can still top up your tyres every now and again.
There's suppose to be a pressure switch on the compressor, It's meant to turn the compressor off if the pressure gets too high, make sure this is there.
Here's the onboard compressor/water traps /regulators in my truck.
ID:	104226   Click image for larger version
Name:	Fr water trap.jpg
ID:	104234   Click image for larger version
Name:	Front water trap.jpg
Googs is online now
post #5 of 7 (permalink) Old 02-01-2017, 05:29 PM Thread Starter
That's a nice little setup you have there. Thanks for sharing the pics!
hd
post #6 of 7 (permalink) Old 02-06-2017, 01:17 AM
NYB
Googs's truck is so badazz, it makes my truck feel like a Wells Fargo chuck wagon, only without the money in the back, and with fewer horses in the front.
NYB is offline
post #7 of 7 (permalink) Old 02-08-2017, 12:16 AM Thread Starter
LOL - yea there's a lot of really cool rigs on this site. Maybe one day I'll catch up
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
