Aux tank for 2012 F250 - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #1 of 2 (permalink) Old 04-24-2013, 07:36 AM Thread Starter
Has anyone installed aux tank with gravity feed for 2012 F250?
Looking under truck from fuel cap to tank the line is both solid and rubber going into tank. I am assuming one would tap into the flexible rubber hose section with the RDS kit rather than cutting into solid pipe.
Their isn't much clearance (maybe 1" or so" between line and truck body.
Is this enough for the valve that comes in the RDS install kit?
antiqueman is offline
post #2 of 2 (permalink) Old 04-24-2013, 03:09 PM
FTG-05's Avatar
My Photos: (25)
RDS Aluminum doesn't show anything newer than the 2011 Ford, at least the way I read their description over on NT and at the RDS site.
Give them a call and see what they say: Contact RDS I've called/e-mailed before and always had pretty good customer service.
From my own install, 1" *doesn't appear* to be enough, you might have to cut the hardline an inch or so.
Good luck!
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
