Block Heater Bumper Plug Upgrade - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 4Likes
post #1 of 32 (permalink) Old 04-07-2013, 04:54 PM Thread Starter
Thought the OEM Block Heater Plug looked pretty Cheezy on a $62k truck. I purchased one of these for my battery charger outlet for my Cobalt boat. So I decided to try and install one for the Block Heater on my new KR. Takes less than 30 minutes to install and bought the Plug on Amazon.com and was about $18. It is made by Marinco and they are designed for wet conditions so should work well and last for years. Took some photos of install. Easy Peasy, not so Cheezy!
ID:	19641   Click image for larger version
ID:	19649   Click image for larger version
ID:	19657   Click image for larger version
ID:	19665   Click image for larger version
2012 F350 PSD 4X4 CC SWB KING RANCH, PLATINUM WHITE/PALE ADOBE..........MORE TO COME
2011 F350 PSD 4X4 CC SWB KING RANCH, GOLDEN BRONZE /PALE ADOBE, PIAA,RIGID 20 LED, READY LIFT LEVEL KIT, FRONT RECIEVER, LEER HARD TONNEAU.............SOLD, had an offer I couldn't refuse!
99.5 F350 PSD 4X4 CC LWB DRW,BANKS STINGER,GO-RHINO,PIAA,RHINOLINER,CARBON DASH,REMOTE STARTALARM,SKYJACKER 4 LIFT,HADLEY AIR HORNS,LEER SHELL,ALL REDLINE SYNTHETICS.........Gone but not Forgotten!
Tedster is offline
post #2 of 32 (permalink) Old 04-07-2013, 06:29 PM
jriltex's Avatar
Nicely done! Saves crawling around on your knees in the dark looking for the plug!
2011 F-350 Lariat FX4 Crewcab, SRW, LB Two-Tone Golden Bronze Metallic/Pale Adobe Metallic, Adobe Leather Interior, 6.7L, 3.55 elocker, 20" Michelin LT275/65R20E Tires, 11500# GVWR, Lariat Ultimate Package, 5th Wheel Prep Pkg, Engine Block Heater, ARE Tonneau Cover, Tailgate Step, Universal Garage Door Opener, Upfitter switches, Navigation Radio, Ranchhand Bumpers front and rear, Ford Vent Visors
jriltex is offline
post #3 of 32 (permalink) Old 04-07-2013, 08:27 PM
mithrilux's Avatar
Clean and nice - well done!
2012 F350 Lariat SRW CC 4X4
mithrilux is offline
post #4 of 32 (permalink) Old 04-07-2013, 08:53 PM Thread Starter
It has a a water-tight rubber sleeve on that is not shown as well. Here's another photo of factory plug pulled through the bumper hole I cut out.
Here is some more pics and search this title on Ebay for some more pics of the product and you can order as well, even though I got mine on Amazon.com
EBay title;
MARINCO 15A/125VAC Twist-Lock , Shore Power, Waterproof Panel Mount Plug
ID:	19697   Click image for larger version
Tedster is offline
post #5 of 32 (permalink) Old 04-07-2013, 10:14 PM
tickedoff36's Avatar
SWEET! i might try that on mine. is it the whole wire assem? or just the end to waterproof??
1999.5 F350 SRW 7.3 6spd; 243k miles no mods
new timing cover
K&N air filter
replaced injectors
replaced HPOP (reman)
replaced PCMx2 & idm
OTHER TRUCK
1976 F350 FB DUELLY
390 W/MANUAL TRANNY
2 WD 4BBL
tickedoff36 is offline
post #6 of 32 (permalink) Old 04-07-2013, 10:42 PM Thread Starter
Just pull the existing block heater wire through the hole in bumper, you will need to undo a few mounting clips to allow enough slack, Then cut the old plug end off the wire and strip the 3 wires so about 3/8" copper wire is exposed. Green (ground), Black, and White wires correspond to same colors screws on the Marinco receptacle.
The rubber boot slides over to seal receptacle, then tighten with supplied lock-ring on inside of bumper. I used the supplied screws by drilling 7/64 holes for added security and strength.
ID:	19713   Click image for larger version
ID:	19721   Click image for larger version
Tedster is offline
post #7 of 32 (permalink) Old 04-08-2013, 09:04 AM
Willie77's Avatar
Ted,
That's a great set up. Clean install. Nice work.
I totally agree that for the price of our trucks, there should be a more permanent, heavy duty connection for the block heater.
I will be pulling the bumpers to de-chrome and paint to match very soon, and I will be adding this plug, or similar for sure.
Sent from AutoGuide.com Free App
Current Truck:
2016 F350 Lariat CCLB 4wd
Blue Jeans with Magnetic Accent
LOADED!!!
Former:
'12 F250 6.7 Lariat, S/C SB 4wd,
Dark Blue Pearl with Sterling Grey accent
3.55 rear, FX4 Package, Upfitter Switches
Weatherguard Toolbox, cab rack, 8-strobe Whelen miniedge, Husky mudflaps.
'03 F350 6.0L 300,000+ miles stock.
Original turbo, head gaskets, EGR valve/cooler and oil cooler. Supposedly the "first of the worst" 6.0's
Great Truck - Never let me down.
Willie77 is offline
post #8 of 32 (permalink) Old 04-09-2013, 09:58 PM
mithrilux's Avatar
Perhaps a silly question: what did you use to cut through the bumper?
post #9 of 32 (permalink) Old 04-10-2013, 10:42 AM
In the first thread it looks like he used a hole saw, on a cordless drill.
2011 F350 KR,6.7, SRW, 172, FX4, 3.55 ELD, Dual Alternators, Camper Package, Tuxedo Black,
I didnt need the Nav package- my wife tells me where to go and when to turn
trails2004 is offline
post #10 of 32 (permalink) Old 04-10-2013, 06:21 PM
HaulinCamp's Avatar
LOL, I'd have to mount mine on the rear bumper so it would disconnect when I drive off!
I keep looking for a magnetic breakaway cord but no luck.
Eric
meteor56 likes this.
2011 F-350 King Ranch
HaulinCamp is offline
post #11 of 32 (permalink) Old 04-10-2013, 07:21 PM
Eric
Here ya go, auto unplug.
EcoVantage Catalog: Auto Eject WP
But I think for the price I'll keep the extension cord hanging over the side mirror to keep from forgetting to unplug it...
~Wolf
'12 F550 Tux Black Lariat Supercab 186" WB , 4x4 6.7, 19.5GVW
13k lb hooklift, Cramaro auto tarp, Insta-chain automatic tire chains, Boss 9' SD plow, Atomic led cab marker/strobe
Custom~ fabbed rear bumper, tarp gantry, rear warning led setup, SEIC & rear strobe control panel (in the drivers side powerpoint trim)
And more to come
'99 F350 XLT CC LB 4x4 dually 7.3, Dents build character
408,000ish miles on the clock (2nd motor)
'93 Exploder Sport, 5.0 swap, 4r70w+Baumann TCS, Atlas 2 T-case 3.8:1 twin stick, Narrowed D44 '79 f150 solid axle swap, bunch o other junk...
'69 Ford rust bucket, err Bronco, "resto"/mods in the planning stages
Wolf451 is offline
post #12 of 32 (permalink) Old 04-11-2013, 12:17 PM Thread Starter
I think I used a 1-7/8 (one and 7/8 inch) hole saw to cut out bumper hole, I located it low in case I want to put one above it either for a battery charger or a female outlet for a 120v inverter.
I used both the factory lock-ring and drilled for the 3 mounting screws and this is rock solid. I believe an extension cord will easily pop out should you forget to unplug as long as extension cord has a stop or has been tied down.
If you wanted add a Red 120v warning light on the A pillar when plugged in, just add $10 and 15 minutes.
Tedster is offline
post #13 of 32 (permalink) Old 04-24-2013, 09:35 AM
My Photos: (9)
Not being picky, but did you paint the bare edges of the freshly drilled paint. Salt will do wonders, and I'll bet in a year or two, cancer will set in behind the paint. Could you have integrated it into the grille somewhere? I'm thinking about mounting mine behind the license plate and making the plate flip down. Out of sight.
Sent from AutoGuide.com App
Smokewagun is offline
post #14 of 32 (permalink) Old 04-26-2013, 08:25 AM Thread Starter
Yeah, was thinking the same thing. Will paint the bare edges with Clear fingernail polish. Also picked up a 120V red LED pilot lamp, will test it when plugged in to be a cord reminder. Want to place on the A pillar at eye level.
Tedster is offline
post #15 of 32 (permalink) Old 04-26-2013, 09:32 AM
drcampbell's Avatar
My Photos: (32)
Zinc galvanizing primer or chemical rust neutralizer will work a lot better than a paint- or lacquer-based primer.
In the electrical trade, this connecter is called an "inlet". (counterpart of "outlet") There is a wide variety of inlets available and you might be able to save some money shopping at electrical suppliers vs. the RV & boat world.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
