Block Heater Bumper Plug Upgrade - Page 2 - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 4Likes
post #16 of 32 (permalink) Old 04-26-2013, 11:24 AM Thread Starter
I thought $16.99 including shipping to my front door was pretty reasonable. (Amazon.com) I've used Clear fingernail polish on a number of things for rust protection with good results. Easy to use as you just paint it on with the cap brush.
2012 F350 PSD 4X4 CC SWB KING RANCH, PLATINUM WHITE/PALE ADOBE..........MORE TO COME
2011 F350 PSD 4X4 CC SWB KING RANCH, GOLDEN BRONZE /PALE ADOBE, PIAA,RIGID 20 LED, READY LIFT LEVEL KIT, FRONT RECIEVER, LEER HARD TONNEAU.............SOLD, had an offer I couldn't refuse!
99.5 F350 PSD 4X4 CC LWB DRW,BANKS STINGER,GO-RHINO,PIAA,RHINOLINER,CARBON DASH,REMOTE STARTALARM,SKYJACKER 4 LIFT,HADLEY AIR HORNS,LEER SHELL,ALL REDLINE SYNTHETICS.........Gone but not Forgotten!
Tedster is offline
post #17 of 32 (permalink) Old 06-02-2013, 07:26 PM
sbrennan007's Avatar
Will it pop out easy enough if you had to pull the bumper off?
2013 BMW X5 M Sport
2011 BMW 335i M Sport Convertible
sbrennan007 is offline
post #18 of 32 (permalink) Old 06-20-2013, 07:02 PM
CarlT100's Avatar
A good idea and very nice work. Thanks for the tip; I will do this install.
11 F-450 Lariat, Platinum White, 6.7, 4X4, crew cab, tow package. Weekend Warrior toyhauler, fifth wheel, 40'. Flatbed, gooseneck, 30'.
2000 F-350 dually, PSD 7.3 L, 4X4 - Sold
1992 F-350 dually, non-turbo, 4X4 - Sold
Retired US Army
CarlT100 is offline
post #19 of 32 (permalink) Old 03-02-2014, 10:41 PM
It would be nice if Ford did something tasteful and put the plug behind the F250 emblem, making it on a hinge and work as a door. That would be a real "Sneaky Pete" type thing that would have a real WOW factor.
I know, I know, Dream on....
2002 F250 XLT, white over gray, Ext. cab, 7.3 PSD, Auto, 4X4, 42,000 original miles. 4" Diamond Eye exhaust w/ dual mufflers, Tony Wildman 6 position tuner, drilled & slotted rotors..
SOLD - 2014 Ford F250 Lariat, Ruby Red, Crew Cab, 6.7, 4X4,
RJC2 is offline
post #20 of 32 (permalink) Old 03-22-2014, 08:23 AM
I agree. It would be like the "good old days" (whenever those were) when they used to do things like gas caps behind tail lights etc..
2011 F-350 Lariat Ultimate pkg. SRW, C.C., LWB, 4x4, 3.55 ELD
2010 Montana Mountaineer 345 DBQ (5th)
PerryB is offline
post #21 of 32 (permalink) Old 03-22-2014, 10:37 AM
drcampbell's Avatar
My Photos: (32)
Filler caps were moved from the rear to the side to reduce the risk of spilling & igniting the entire fuel load during a rear-end collision. My nostalgia doesn't extend to two vehicles (and their occupants) burning to the ground after a relatively minor crash.
Under the contemporary FMVSS, spilling more than one liter of fuel is one of the ways to fail a crash test.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
post #22 of 32 (permalink) Old 04-01-2014, 07:16 PM
Holy crap, we were talking about hiding the block heater plug behind the Ford oval. I analogized it to the old gas cap/tail light and you had to come up with THAT?
PerryB is offline
post #23 of 32 (permalink) Old 04-04-2014, 06:10 AM
Option B
I've seen a write-up where the plug was installed in the wall of the fog light. It's not so obvious, but the same or similar water tight plug was used.
I'd considered Option B but my stock cable has a plastic clip that attaches to the tow hook, so I'm fine with that.
Helpful info:
brmccolley is offline
post #24 of 32 (permalink) Old 01-28-2015, 02:19 PM
I've thought about the fog light surround as an ideal location for this plug. Wonder if it'd fit there???
93-331-29psi is offline
post #25 of 32 (permalink) Old 03-16-2015, 04:12 AM
Eric, mounting on the rear is a very good idea, but for a reason that you might not think of.
In park, the transmission does not circulate any oil, so letting a rig warm up does the transmission oil no good. The toughest (highest pressure) function of an auto transmission is reverse. If you back into the space where you plug in, you start put going forward, not in reverse. this does not matter if it isn'the very cold very often and for months on end, but if you live in minus 40 country (both F and C degrees are -40), you will find that a lot of transmissions rap out at only 100k, and most of them have torn oUT reverse.
That is one mighty fine install.
JohnD333 is offline
post #26 of 32 (permalink) Old 09-28-2016, 03:21 PM
bogeyman's Avatar
On a related note, having just acquired (picking it up later today) a "new-to-me" 2015, F-350, I am assuming that although the engine has the block heater built in, I will have to purchase the necessary heater cord from Ford? (this was the case for my 2006 F-250).
Does anyone know the part number off-hand?
'15 F350 Lariat (Platinum). FX4, Shortbed...
bogeyman is offline
post #27 of 32 (permalink) Old 09-28-2016, 03:50 PM
2015_PSD's Avatar
BC3Z-6A051-A is the block heater element if you do not already have it installed and BC3Z-6B018-H is the power cable. Check for your power cable--mine was tucked up pretty far behind the bumper and so I bought one that is now a spare.
bogeyman likes this.
2015 Tuxedo Black F-250 Platinum (FX4)
Currently running Rotella T6 (CJ-4) oil and CQ Blue 84151 (WIX) oil filter
All Stock except for a few accessories:
- Rhino Spray-In Bedliner
- Ford Splashguard/Mudflaps
- Husky Rear Wheelwell Liners
- Bull Ring retractable tie downs
- Leer 700 Bed Cap
- Mag-Hytec Rear Axle Cover
- Mag-Hytec Front Axle Cover
- OEM Rear Sway Bar
- All interior & exterior LEDs including bed
2015_PSD is offline
post #28 of 32 (permalink) Old 11-15-2016, 04:41 PM
bogeyman's Avatar
Thanks for those numbers.
Turned out I didn't need them - truck has the heater & came with the cord tuck away. I did the same mod to my old F-250, and I'll probably be doing the same to this one.
bogeyman is offline
post #29 of 32 (permalink) Old 12-09-2016, 06:36 PM
Block Heater
I really liked the solution that was posted to this page. However, I have a Ranch Hand bumper on the front. Nothing to really drill thru because I didn't want to go through the diamond plate. So I came up with this solution. I ordered a light rack mount that would hold the receptacle. I wasn't able to use the supply rubber mounts so I took some tool box drawer liner in between the clamps. It worked great and is very secure. Additionally I didn't want to cut the OEM cord so I butchered a new extension cord and made the pigtail. I plan on getting one of those extension cord protectors to sandwich the pigtail and OEM cord from the weather. Here are some pictures. (Sorry the pictures are upside down. They are ok on my computer)
ID:	102609   Click image for larger version
ID:	102617   Click image for larger version
ID:	102625   Click image for larger version
Last edited by John Hefner Sr.; 12-09-2016 at 06:39 PM. Reason: tried rotating pictures
John Hefner Sr. is offline
post #30 of 32 (permalink) Old 12-26-2016, 05:12 PM
hef,
that looks nice upside down and right side up!
cheers,
doc
navyrad8r is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
