Cargo lights - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #1 of 9 (permalink) Old 12-31-2012, 12:03 PM Thread Starter
rforsythe's Avatar
Cargo lights
Anyone tried these out yet? Recon 26417 Universal Cargo Area Bed Rail Light Kit | TruckandWinch.com
Considering putting some in, but also thinking they could be useful as lower side lighting on the 5th wheel if I run it back from the upfitter switch.
Just wondering if people like them and what the cord length/connectors are like, since there are no photos of that on the site.
rforsythe is offline
post #2 of 9 (permalink) Old 12-31-2012, 07:41 PM
madsonp's Avatar
I'm going to put some of these in mine, I'm going to mount them on top of the window frames of the side windows on my topper, but you could mount them under the bed rail also. What I like about them is you can cut them to length.WFLS-x-BK series Weatherproof High Power LED Flexible Light Strip - Black Circuit | LED Strips | LED Light Strips & Bars | Super Bright LEDs I'm going to wire them up to one of these that'll be mounted to the topper door so when the doors open the light's will come on automatically http://www.radioshack.com/product/in...ductId=2419297
madsonp is offline
post #3 of 9 (permalink) Old 01-01-2013, 02:05 PM
I looked at those when I wanted bed lights, thought they were too pricey.
I ended up using two 18" strip LEDs that I bought from a motorcycle vender at the NYC bike show, $18 each.
They are adhesive backed. I stuck 2 of them to a 1/2" piece aluminun angle and then stuck that up under the bed rail.
Put a switch in a small box by the tailgate to operate it. I pull power form a power supply I already have in the tool box.
The two strips on one side light up the entire bed fairly well.
Thanks,
Duane
porthole is offline
post #4 of 9 (permalink) Old 01-02-2013, 01:15 PM Thread Starter
rforsythe's Avatar
Nice! Thanks for the info.
post #5 of 9 (permalink) Old 01-04-2013, 09:40 AM
HaulinCamp's Avatar
Santa brought me these sweet lights ($60) with 8 lights (4 lights for each side of the bed):
8pc Truck Bed LED Lighting Kit
These look brighter to the eye in person then the video can show.
Eric
2011 F-350 King Ranch
HaulinCamp is offline
post #6 of 9 (permalink) Old 01-05-2013, 09:54 PM
madsonp's Avatar
Originally Posted by madsonp View Post
I'm going to put some of these in mine, I'm going to mount them on top of the window frames of the side windows on my topper, but you could mount them under the bed rail also. What I like about them is you can cut them to length.WFLS-x-BK series Weatherproof High Power LED Flexible Light Strip - Black Circuit | LED Strips | LED Light Strips & Bars | Super Bright LEDs I'm going to wire them up to one of these that'll be mounted to the topper door so when the doors open the light's will come on automatically Directed 8600 Magnetic Micro Switch : Micro Switches | RadioShack.com
I got them installed today, they look great and the switch works real good.
madsonp is offline
post #7 of 9 (permalink) Old 01-06-2013, 04:45 AM
I installed something similar on my father's F350, I used "5m 3528 smd 300 led" strip sourced from ebay (usa shipper) for under $20, added some 22 awg red/black "zip cord" wiring (soldering required) and with the one 5 meter roll added light to the 8' bed in two 30" runs per side and two 2'(ish) per side under the crew cab's doors for puddle lights.
Measurements may be off in my head, so measure it out if you try to duplicate this...
Tied the wiring in for both the bed and puddle lamps to the running board light plug on the frame rail.
If I remember to I'll get some photos of the light if anyone wants to see.
~Wolf
'12 F550 Tux Black Lariat Supercab 186" WB , 4x4 6.7, 19.5GVW
13k lb hooklift, Cramaro auto tarp, Insta-chain automatic tire chains, Boss 9' SD plow, Atomic led cab marker/strobe
Custom~ fabbed rear bumper, tarp gantry, rear warning led setup, SEIC & rear strobe control panel (in the drivers side powerpoint trim)
And more to come
'99 F350 XLT CC LB 4x4 dually 7.3, Dents build character
408,000ish miles on the clock (2nd motor)
'93 Exploder Sport, 5.0 swap, 4r70w+Baumann TCS, Atlas 2 T-case 3.8:1 twin stick, Narrowed D44 '79 f150 solid axle swap, bunch o other junk...
'69 Ford rust bucket, err Bronco, "resto"/mods in the planning stages
Wolf451 is offline
post #8 of 9 (permalink) Old 01-07-2013, 12:22 AM
Steve Campbell's Avatar
Had the recon lights installed a couple weeks back they work great especially under the retrax cover I have they are wired to come on with the interior lights
2012 F250 Lariat 6.7 Golden Bronze 4X4, MBRP Filter Back Duals, Alpine INE-Z928HD, Focal Amp and Speakers and a ton of Dyno Mat, RetraxPro, Clifford Alarm Recon smoked marker/clearance lights, HID Headlights, Rigid D2 Driving Lights (in fog location), Bilstein 5160 shocks,Hellwig Big Wig Sway Bar, Pro Comp 2 Inch Nitro Leveling Kit, Fuel 22" Maverick Wheels , Nitto 325/50R22 Terra Grappler, Westin Bull Bar
Protected by H&K
USP and friends
2006 Hummer H2
(traded for
diesel hope never to go back to the dark side (gas)
2005 F250SD SB 4X4 6.0 Harley Edition (traded)
2003 7.3 F350 DRW 4X4 (traded)
2001 7.3 F250 4X4 (traded)
Steve Campbell is offline
post #9 of 9 (permalink) Old 01-08-2013, 05:35 PM
Eric
Those look real good.
07 F-250 Harely 8 inch fabtech, 38 inch toyo's, 20 inch wheels, traction bars, air bags, 4 place gauge pod, bullydog triple dog, 5 inch exhaust, amp steps and more to come.
08 F-450 4.30 Gears, SCT Livewire with Custom Tunes, AFE Intake, DPF Delete, 5 Inch Exhaust, 8 Inch Fabtech with Bilstiens, 22' Wheels with 37' Toyo M/T, Amp Steps.
11 F-450 Amp steps, hid's, H&S, 5' exhaust, full delete, recons, and............
carter99 is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
