Ford's Remote Access in Sleep Mode - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #1 of 1 (permalink) Old 01-24-2017, 05:36 AM Thread Starter
If your Ford Remote Access is stuck in sleep mode and will not exit, you will need to call the help line for Tech Support, Ford Key 1 800 367 3539 (I forget the option but was the last one #4 or #5).
I understand this was a recent problem Ford/AudioVox experienced with the Remote Access modules. I had it happen to one of my vehicles about the time I was going to sell both modules. I removed the modules and even switched the module to my other vehicle, but to no avail.
I called Ford Key, this is the help number for Remote Access. I was put through to AudioVox tech support. They were able to send a signal to my vehicle and wake it up. Worked fine after the wake up signal from them.
Suggest you do the same if you are having this problem.
Larry
larrgh is online now
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
