Thinking of the afe intake with a dry pro7 filter and a DPF-back pipe with muffler, no programming. Thoughts on if there would be mpg improvements? Trying to gain some mpg back with ssr's installed, lost approx 1.5mpg with bigger tires and lugs. It just looks awesome with them! Thx.
2013 f450 plat white lariat, k&n intake w/dryfilter wrap, Magnaflow DPF-back 5" system, 235/80-17 nitto dura grapplers, tonneau cover, Ford DVD system to sedate kids, on board air and bags.
Total cost will be around $800 installed for intake and exhaust. Even a .5mpg improvement is almost 20 miles a tank. If I can gain 1-2mpg I would be happy for sure. I love the ssr's
you'll definitely be wasting your money on the air intake. it's been proven that the stock intake flows enough air far in excess of the horsepower a chipped motor is capable of producing.
the exhaust...maybe...but it would be minimal. you're really not removing that much restriction by taking out the muffler. The real restriction is the cat and the dpf...but to remove that you've got to get a tuner to reprogram the computer
keep in mind...you tamper with emissions equipment, you're dacing with danger on keeping your warranty.
Jourdan
2011 F250 King Ranch FX4, 6.7L with all the options
SOLD: 2002 F250 Lariat 4x4, 7.3L
DIY Intake, Zoodad, 4 inch exhaust turbo to tip, DP Tuner F5 (no start, stock, high idle, 60hp tow, 80hp econo, 120 hp race), Isspro Gauges: egt, boost, tranny (thank you girlfriend!:hail), Dieselsite Coolant Filter, AIH Delete, HPX Line, in-tank & pre-pump mods, FPR shimmed to 70 psi, Hawk Brake Pads and Powerslot Rotors, Dieselsite WW, Rhino Bedliner, 285/75 Goodyear Wrangler Silent Armors, Trailer Tow Mirrors, Bilstein Shocks, 203* T-Stat, Dieselsite Billet T-Stat Housing, Door Seal Mod, Fumoto Oil Drain Valve, Passport 9500i hardwired in w/ smartcord, A toolbox full of goodies and a few other things here and there:sly
No way I'm tampering with the emissions, I don't want to deal with that. I did another run on the highway again, comparing tires and mpg returns. 235/70-17 winter tires, 31.9" tall, were 15.8-16.0mpg, 35/10.50-17 ssr swampers were 14.4mpg, 285/75-17 nitto terra grapplers, 33.86" tall, 14.7mpg. That really surprised me. I might do a dpf back and intake anyway, just to see. Tune not important, has gobs of power anyway.
I'm wanting to say the last time I did the math, that IF I spent $1,000 on a programmer + intake and IF I could gain +2mpg (which is a lot) I would have to fill up 71 times gaining 2mpg /tank to even break even on the money I spent.
...and you aren't guaranteed any mileage gains
2011 F350 CC DRW FX4 Tuxedo Black on Black
2011 Heartland Landmark Key Largo 5'r
2007 F350 CC SRW FX4 Outlaw Lariat "Johnny Cash" Edition Black on Black
2008 Mercedes GL450 Loaded (Wifes Car) Black
Agreed, but my calculations are a bit different as are costs for fuel, regardless It really isn't the savings, much like spending huge bucks on led and fluorescent lighting at home, it's just to use less.
By adding a intake and DPF back exhaust, the maximum MPG improvement that you "could" achieve will be statistically unresolvable.
i.e. if your mods produce a .10 MPG improvement (which is generous IMO) you will have that much fluctuation in your MPG from other variables (such as seasonal climate changes, quality of fuel, driving characteristics, etc)
I would like to see one of our 6.7s put on a engine dyno, holding all the other factors constant, to see what efficiency an intake and DPF back exhaust would actually produce.
Even then, I think the error in the testing equipment would be greater than any realizable gain.
Sorry, i'm a little cynical towards the aftermarket vendors claims of "increased MPG" based on biased and statistically indeterminate data.
2012 F-350 KR 6.7, Crew, SB, 4x4, 3.55 E-lock, Golden Bronze/Adobe
Line-ex, B&W Hitch, BakFlip F1, Kenwood 9990, Rigid Ind 20" E series light bar
Sold - 2005 F-250 Lariat 6.0 Crew, SB, 6 Speed, 4x4, Wedgewood/Tan
2003 Sonic Blue Cobra 666rwhp 600rwtq,
1997 Jeep Wrangler B3.3T Cummins, NSG370 6 speed, Ford 8.8 rear, Dana 44 front, 37x12.50 PitBull Rockers
2008 Hydra-Sport 23 Bay Bolt w/ Etec 250
Something to think about. I don't see any mention of correcting for speedometer error for the tire size change. The speedometer and odometer are going to be off because of the tire size change. There is roughly a 6.5% difference in the tire size which means the odometer and fuel economy is going to be off by 6.5%. The way I figure it the actual MPG if you allow for a 6.5% odometer error you are actually getting about 15.4 with the bigger tires. So you have only lost about 1/2 MPG for the increased drag and gear ratio change for those tires.
VERY good point. I completely forgot about this. If you really want to calibrate it correctly, you'd have to go and get the computer reprogrammed (which a dealer might be able to do?) or buy a little add on that compensates for it.
Your mileage might not have suffered as much as you think?
Jourdan
I have calibrated for all tire sizes, and verified with GPS.
Earlier in the post, several people mentioned possibly installing a DPF back exhaust.
Is there any possibility that the installation of the aftermarket exhaust, even tho it is DPF back, would/could void the warranty? Could the dual tip w/ cooling cut-outs be considered emissions, and thus removing it could void the warranty?
Current Truck:
'12 F250 6.7 Lariat, S/C SB 4wd,
Dark Blue Pearl with Sterling Grey accent
3.55 rear, FX4 Package, Upfitter Switches
Weatherguard Toolbox, cab rack, 8-strobe Whelen miniedge, Husky mudflaps.
Still waiting on the ventvisors, bugshield, and a few other ideas.
Former:
'03 F350 6.0L
300,000+ miles stock.Original turbo, head gaskets, EGR valve/cooler and oil cooler.
Supposedly the "first of the worst" 6.0's
Great Truck - Never let me down.
It depends on your dealer. The dual tip with the cooling cutouts is considered at least in the 6.4 owners manual a "functioning" part of the DPF system. I'll leave that to you to think about, but if it's called "functioning", chances are that if the dealer isn't easy going that it could void the warranty.....chances are that it would affect the DPF in slight ways.
Ty (Dukey)
I may be the average teenage Farmer/Rancher, but everything done to my trucks I did myself!
2006 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, IPR Research Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 w/ Custom Tunes from Matt @ Gearhead, Air Lift Load Lifter 5,000s w/ On Board Compressor System~~
Early 2004 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008 F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
JUST SOLD>>400,000 MILES!!!~~1999 F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
