Light Bar wiring to high beams 2016 350 diesel - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 1Likes
  • 1 Post By klhansen
post #1 of 3 (permalink) Old 02-10-2017, 02:48 PM Thread Starter
Hello, I'm new to this page. Could anyone explain the procedure to wire my light bar to my high beams on my 16 ,350 diesel ford,I believe the wire for high beams is black and green together. Just wondering if someone could give me a simple set up and explanation as I don't know what I'm doing.
2016 super duty is offline
post #2 of 3 (permalink) Old 02-10-2017, 08:18 PM
yan7gin's Avatar
I'm not sure what is the law where you are from but here in Canada you can't use any auxiliary light on the road. light bar are for Off road only. I have a body that did the same (wire is light bar to the high beams) and the fine wasn't pretty and follow by a VI (vehicle inspection)
I would suggest to wire the light to a auxiliary switch and use it as need
F350 2002 7.3
auto,4" lift, 37/13.5/16 open country, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, HPX, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 3 (permalink) Old 02-10-2017, 09:03 PM
klhansen's Avatar
My Photos: (180)
You could easily wire the light bar from a power source thru a relay with and use the high beam voltage to trigger the relay, turning on the light bar when high beams are used. Also put a control switch between the high beam wire and the relay coil so you can turn the signal off. You could also use a three position switch (on-off-on) and bring a power source to one side of the switch and out the common to the light bar relay.
Here's a sketch on how I ran my aux backup lights. They are either off (center switch position), on with backup lamps (lower switch position) or on (upper switch position.)
But as Yan said, please follow the laws where you are. The HID lights that scatter light all over the place even in low beam are bad enough. Blinding other drivers is never a good idea.
yan7gin likes this.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
