LockPick - Page 2 - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #16 of 23 (permalink) Old 01-05-2017, 01:00 PM
Originally Posted by larrgh View Post
No, It does not do anything like a programmer. I have used them with the brick radio and with the sony radio. After removal, there was no sign of it ever being used.
Great, thanks for the info.
2016 CCLB 6.7 Platinum SRW
jjmstang is offline
post #17 of 23 (permalink) Old 01-09-2017, 08:41 PM
Anyone put a lock pick in a 2015? Also can you play a movie or stream a video app from your phone to the trucks nav screen with it? That would be pretty sweet with all the apps to watch TV on your phone.
15Platinum is offline
post #18 of 23 (permalink) Old 01-13-2017, 08:53 PM
I have one in a 2016..same radio as the 2015. The ability to play DVDs with the factory radio went away in 2011 I believe. It will not play a DVD. You can play one on portable player and pipe it into the old school VGA cables in the dash cubby…but it does not look very good on the screen. The lock pick will let you use all features of the system while in motion.
2016 F350 KING RANCH DRW, 4X4, RUBY RED/CARIBOU, 3.73'S, LOADED, TUNED, ARE FLAT BED COVER, SPRAY IN LINER, 2.5" RANCHO FRONT LIFT, 3" REAR LIFT, RANCHO 9000 XL'S, 255/80/17 BFG MUD TERRAINS, EBC BRAKES, RADIO LOCKPICK, FRONT LIGHT BAR AND REAR FLUSH MOUNT LED'S.
COBRAJET is offline
post #19 of 23 (permalink) Old 01-13-2017, 09:00 PM
2012 was the last year of the "brick" radio and DVD's. 2013 and newer only play cd's.
Larry
larrgh is offline
post #20 of 23 (permalink) Old 01-28-2017, 10:08 PM
Cobrajet - What options does the Lock Pick unlock for you? We just picked up a 2015 F-350 yesterday and haven't really had time to go through everything yet so was just curious as to what doors it will open up. Thanks for the info
No Lag is offline
post #21 of 23 (permalink) Old 02-05-2017, 09:19 AM
There are many GPS options that do not work when a vehicle is moving. The lock pick allows those to be used when the vehicle is moving.
COBRAJET is offline
post #22 of 23 (permalink) Old 02-05-2017, 01:44 PM
Many of the options not available via buttons on the radio are available via voice commands. I have found for one person and no passenger and not needing additional cameras, the LockPick is not needed.I found it to be an expense I could not justify and sold them not long after I purchased them while I could still get most of my money back. I have had all 3 versions. I had one on the 2011 F350 with the brick radio, the 2013-2016 version and the WIFI version for the 2013-2016.
The 2011 version was the most useful since the "brick" radio had a DVD player in it. A passenger could have watched a DVD. The 2013 and newer radios are CD only.
Larry
larrgh is offline
post #23 of 23 (permalink) Old 02-08-2017, 12:16 AM
Okay, good information to have, I will save the money for other things. Thanks for the input guys!
2015 F-350 6.7L Lariat-Crew Cab-Short Bed-Bronze Fire.
Retrax tonneau cover
No Lag is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
