My HID Projector Retrofit - Page 2 - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #16 of 40 (permalink) Old 12-17-2010, 07:47 PM Thread Starter
VTX
The $950 includes labor.
In these trucks the low and high beam use the same bulb, so the retrofit is for both. The way it works is there is a solenoid in the headlight housing and there is a cutoff shield in there that cuts the beam off above a certain height when you have the low beams on. When you turn the high beams on the solenoid activates and moves the shield out of the way so you illuminate everything.
I'll post up some pictures soon. Heading out to take some shots here in a little bit.
As far as how hard it is, I don't really know since I didn't do it myself. I just did the wire harness and that was easy.
2011 F-350 Lariat Ultimate, Golden Bronze Two-Tone, CC, SB, 6.7L, 4x4, FX4, 20" Wheels, 3.55 E-locker
VTX is offline
post #17 of 40 (permalink) Old 12-17-2010, 09:14 PM
Is there any light on the dash telling you that there is a lamp out? I did a retrofit like this on my 2004 dodge. The "lamp out" light was always on because the ballasts were powered through relays from the battery. I also needed a 55 watt load always on the line to keep the power on. It was a pain!
BusTruck is offline
post #18 of 40 (permalink) Old 12-17-2010, 09:33 PM Thread Starter
VTX
No, I haven't seen anything like that. When I had just one bulb in and not the other it would make a strange noise when I turned the lights on, but that's it.
The way this wire harness is set up everything is routed to the lights the same way as the stock ones, so everything seems to function normal.
VTX is offline
post #19 of 40 (permalink) Old 12-18-2010, 08:52 AM Thread Starter
VTX
Here are some pictures I took last night. I don't think the pictures of the front of the truck do it justice, but the ones through the windshield give a good idea of how good the light output is.
Here is low beam, you can see where the cutoff shield gives the beam a sharp cutoff above a certain point so you aren't blinding other drivers. There is also a little "jog" up and to the right so with low beams you still illuminate a little higher on the right side of the road:
Here is high beam output. The shield moves and then everything above is now illuminated. This is a big difference from stock where I could hardly see a difference between lows and highs.
Front of truck with low beams:
Front with high beams. In real life I see a much bigger difference between the two for some reason, but the photos don't seem to quite do it justice:
VTX is offline
post #20 of 40 (permalink) Old 12-18-2010, 09:42 AM
very nice, i have 55w hids in my stock headlights and 35w in my fogs and i get the occasional flash from oncoming drivers.
so i bought the recon projector units and installed my hid kit in there and was sorely disappointed. i didnt know there were projectors for halogen bulbs and projectors for hid bulbs. if i knew that from the beginning i would have just sent my stock units to lightwerkz or your place.
now im stuck with these stupid recon units lol. but my buddy has a pair of audi projectors that i will retrofit into my recon units. shouldnt be that big of a deal since they use the cheaper grey butyl sealant rather than fords infamous black adhesive and since there are projectors there already i just need to fasten the new ones in.
yours looks really good and shows the effect a good set of projectors can have on driver safety on the road. i do alot of driving and thats very important.
09 F350 SRW- H&S Mini Maxx with KEM 7 tune card, AFE 4" dpf/doc delete, AFE PG7 drop in soon to be S&B CAI, and some other exterior/interior work
06 F350 SRW- IDP Livewire tuned, studded, CAI, 4" DP to empty, Sinister EGR Delete, 6.4 Banjos & Blue spring, New: oem turbo, ficm, oil cooler etc...
02 2500HD- Hypertech programmed, true duals, AEM CAI
Frndinalowplace is offline
post #21 of 40 (permalink) Old 12-18-2010, 09:44 AM
fdny136's Avatar
waiting on my kit now.this project is next on my list.thanks for the pics truck looks great
2017 f250 4x4 6.7 carli 2.5 leveling , Bilstein shocks
fdny136 is offline
post #22 of 40 (permalink) Old 12-22-2010, 08:31 PM
That is sweet! I wonder if the TL projectors would fit.....
sledhead1 is offline
post #23 of 40 (permalink) Old 12-23-2010, 08:11 AM Thread Starter
VTX
I would think so. There is a lot of room in these headlight housings. I may be wrong, but I think the FX-R's are based on the TL projectors as well. Matt at TRS could say for sure.
VTX is offline
post #24 of 40 (permalink) Old 12-23-2010, 11:04 PM
fdny136's Avatar
mine are done 35w 4300 cap bulbs in fogs and h13 bixenon projector retrofit in my headlamps .purchased from retrofit solutions llc , modified and installed by me.couldnt be happier
fdny136 is offline
post #25 of 40 (permalink) Old 12-24-2010, 09:06 AM Thread Starter
VTX
Where did you get the bulbs for the fogs? I'd like to get some 4300k bulbs for my fogs, since they no longer match the headlights.
Show us some pictures when you get a chance! Thanks!
VTX is offline
post #26 of 40 (permalink) Old 12-28-2010, 05:12 PM
fdny136's Avatar
my headlamp projectors and capped 4300k fogs are from retrosolutions
ID:	9430   Click image for larger version
ID:	9431   Click image for larger version
fdny136 is offline
post #27 of 40 (permalink) Old 12-29-2010, 07:59 AM
how did you guys mount them on the back of the housing? did you fiberglass them in? any pics, im gonna try audi proj on my 09 units possibly.
post #28 of 40 (permalink) Old 12-29-2010, 08:15 AM Thread Starter
VTX
I don't know how Black Flames Customs did it. When I looked at the back of the housing it looked stock, except that I could see the back of the projector housing sticking through the rubber boot where you would normally plug the bulb into. It looked very clean.
If you're going to do it yourself I'd google the HID Planet forum and read there. Lots of guys doing their own retrofits on that site.
VTX is offline
post #29 of 40 (permalink) Old 12-29-2010, 10:57 AM
fdny136's Avatar
the projector has a threaded barrel which mounts passes thru the existing bulb opening.I used retros large projectors and they fit well in the housing
fdny136 is offline
post #30 of 40 (permalink) Old 12-29-2010, 11:18 AM Thread Starter
VTX
Looks really nice fdny! I like the angel eyes. I considered doing those, but in the end decided not to. But looking at yours I kind of wish I did!
VTX is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
