S&S Div HighBeam/Fog Light Mod - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > '11-Up Upgrades and Aftermarket
'11-Up Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
Old 01-04-2013, 06:05 AM   #1 (permalink)
broome101's Avatar
Does anyone know if the S&S Div Mod for High Beams and Fog Lights works on the 2011-2013 year models. I had doen it on my 2005 worked perfect not sure beofre tear into it same electrical configurations there or not.
S&S Diversified
2013 KR, F350,6.2L,4x4,CC, LB
broome101 is offline   Reply With Quote
Old 01-04-2013, 07:57 PM   #2 (permalink)
madsonp's Avatar
Can you explain what this mod is?
madsonp is offline   Reply With Quote
Old 01-05-2013, 01:16 PM   #3 (permalink)
broome101's Avatar
Makes it where fog lights and high beams work at the same time. The link above was at time for 2002 and up had done it on my 05 which worked perfect. Not sure if works on 2011 and above which is the question for those that have already dove into this type of mod or Electrical issue
Old 01-06-2013, 10:34 AM   #4 (permalink)
madsonp's Avatar
Got it, let me know if you get this figured out, I'd like to do that on my 2012.
Old 01-06-2013, 01:24 PM   #5 (permalink)
broome101's Avatar
well tore into it today, it will not work the same as that connection is no longer used on the newer style models
Old 01-17-2013, 09:47 PM   #6 (permalink)
I hooked up my fog lights to my #1 upfitter switch. I use them for daylight running lights as well as on country roads with my high beams. They help me spot the deer in the ditches.
2012 F350 XLT CC SRW 4x4 LB 6.7
2008 Cardinal 34QS Fifth Wheel, Thermopane Windows,2d Air Cond, EquaFlex
donpop36 is offline   Reply With Quote
