2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, DP Tuner, 6.0 IC mod, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 310,000 miles!!
05 White XL 6.0 Reg Cab 4X4 140,500 miles!! (That has never seen the inside of a Garage)
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 125,651 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
Yeah, on that big a truck a 16.5 seems like the right match. A W8000 would be way too small (always needs a doubled line and snatch block), a 10K would be marginal.
If you're really going to depend on it for pulling...especially pulling your truck when stuck...it needs to have a pulling capacity of 1 1/2 to 2 times the weight of your truck. A 8000 pound truck needs a min. 12K. This is a case where bigger is better!
95 F350, 7.3 PSD, CC, ZF5 speed, 4x4, Dually, Autometer EGT, Boost and Engine Temp Gauges, DP and 4 inch exhaust, Tymar Intake, CPR Fuel System, Adrenaline HPOP
85 Ranger, 302, ZF5 speed, Klune-V, Dana 20, Explorer front and rear diffs, 35 inch TSLs, ARBs, Superwinch
Great information, all - thanks. The winch would be for use, not looks. I've got hilly acreage in the Smokies and getting stuck is always a real possibility. I just wanna get unstuck!
I agree 2x the vehicle weight plus some chump. No sense messing with anything less. Now then .. have you considered the strength of your other recovery gear? Like pulleys ( at least 2 snatch blocks), clevis pins, maybe an anchor strap and then either graded chain or another rated tow strap? just considerations for a recovery kit. Most important, get a wire rope guard in case that thing breaks.. you don't need that thing coming back at ya with enough force to cut you in half.
I do all this with my Jeep. I am part of a recovery team.. actually go out and have fun but also carry the gear to recover the team.
2010 F-450 King Ranch (loaded)
Alpenlite Portofino RL36
Reese 24K Sig Series fifthwheel hitch
Reese 30K Sig Series gooseneck hitch
Aerotank 65 gallon tool/tank box ( on timer)
Eclipse AVN726E Nav
Im gonna try and call Warn in the morning and see if they have a mount ready for the 11's. They should as the trucks I have seen in the press that have had winch's was all warn stuff... I need to order a Transformer system for mine..
11' SD CC F350 6.7L FX4
White Platinum Tri-coat
Lariat Ultimate Pkg
IDP Torq2
Warn GenII winch mount
2" Autospring leveling kit
35/12.50/20 Toyo M/T's
Real Rancho shocks w/dual steering stabilzers
6k HID Headlights/Fogs
Adj.High Idle mod
08' SD CC 6.4L 4x4 (Sold)
06' SD CC 6.0L 4x4 (traded)
Have you guys considered or have used synthetic winch line and is it made for 15-16k winches? Reason I ask is I have a Ramsey 15k with steel line on it and was gonna put on a custom receiver plate for front and rear usage....not on sig truck now as I don't need it for DD. Thinking synthetic would reduce weight significantly and would not need 3 men and a boy to hook up...any thoughts or links for synthetic would be cool.
thanks,
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler. http://community.webshots.com/user/jcart44
Synthetics like blue steel are great for these winches. Using a rated synthetic rope has the advantage of being lighter, actually stronger than its steel counterpart designed for a certain size winch and they also add an element of safety as when this rope gives it falls away as opposed to wire memory and the machete sling. Under those circumstances the wire rope is quite dangerous.
I am considering the synthetic rope with the hawsey aluminum fairlead myself. First its the front JKS ACOS for ther Jeep.
Eclipse AVN726E Nav
Many people in my 4WD club use it. Like NEVERSWEAT7 said it's lighter and will drop to the ground if it breaks. Just have to watch out when you winch that it doesn't run across rocks or sharp edges. Cost a little more, last time I was checking into it, a few years ago, it was around $1.75 per foot
There was a very tricked out 2011 F250 done in Dewalt colors at the SEMA show in Las Vegas. The winch set up on that truck was a Warn and it had a custom front bumper that accommodates the winch, a compressor on top of the winch and two quick connects for the transmission PTO offerred as an option on the 2011 Super Duty diesels. I looked at the Warn website for the bumper but nothing for 2011 models was available. When I get my 2011 Super Duty in a couple of months, I'd:ford like to get the bumper, winch and PTO set up I saw on the Dewalt truck at the SEMA show. Does anyone known if Warn, or others, are working on front bumpers for the 2011 Super Duty? Warn are you out there and listening? BTW, good pictures of the Dewalt truck and front winch set up are available on line. Go to the SEMA show and you'll find them.
