Just saw a 2011 rolling down the highway - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > '11-Up General Questions
'11-Up General Questions General questions related to 2011-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-13-2010, 12:02 PM   #1 (permalink)
SFC1984's Avatar
Absolutely shocked the hell out of me too since they weren't supposed to be showing up till spring.
This wasn't a work truck either. It was going the opposite way of me, but looked like an F350 long bed SRW 4x4 King Ranch. My only reasoning for it being a 350 is because we don't see too many 250 long beds around here. It was the Dark Copper and Pueblo Gold two tone and had the painted grille shell and chrome bars inbetween. It happened pretty fast, but that new grille is unmistakable!
I'm guess with that set up it was more than likely equipped with the 6.7. My only guess was it was a demo for the local Ford house. I had just passed by there when I saw it. Damn, what a beautiful truck! I might have to stop by there and see if it is indeed their demo. I have a salesman friend there that is real cool and always gets his hands on the new demos to drive first.
SFC1984 is offline
Old 01-14-2010, 02:33 PM   #2 (permalink)
StanMI's Avatar
I thought I saw one a couple of weeks ago on I-96 West bound here in MI. It was very close to the (now closed) Wixom plant. It was a ways away so I can't be sure. What drew my eye was the new Diesel badge on the driver door. Going that fast and in the other direction I can't be sure.
2008 F350 Lariat CC Black two tone and darn near everything else.
StanMI is offline
Old 01-14-2010, 03:22 PM   #3 (permalink)
SFC1984's Avatar
Funny you mention that. With everything else I recognized about the truck, the one thing I don't remember seeing was that honking diesel badge on the door. Maybe it was the Boss V8 instead.
SFC1984 is offline
Old 01-14-2010, 04:00 PM   #4 (permalink)
FMTRVT's Avatar
My Photos: (16)
Pre Production prototypes should be ironing out final details at various test routes across the country.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 01-14-2010, 05:11 PM   #5 (permalink)
HarleyD250's Avatar
Are the 2011 Motors rumoured to be any better?
HarleyD250 is offline
Old 01-14-2010, 06:03 PM   #6 (permalink)
Supporting Member
my03psd's Avatar
They're rumoured to be much better, we'll wait and see.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 01-14-2010, 11:20 PM   #7 (permalink)
you are right halliurton has something like 200 trucks for "real world" testing in northern states i have a local guy here who was down there for halliurton and said wow very nice truck
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 01-17-2010, 05:48 PM   #8 (permalink)
That's the same thing they told us after 1/3 of our 6.0 truck were down all the time. I'll believe it when the proof is out there.
Florida Power and light also has some.
The problem is that they don't actually test these trucks like they should. They need to give some of us chassis cab guys some trucks to beat on and see how they last.
MonteCarlo31 is offline
Old 01-17-2010, 05:56 PM   #9 (permalink)
dsroka80504's Avatar
You might want to check your facts. Just spent a few hours talking with the ford powertrain engineers at the Detroit auto show. This is the most widely tested motor they have ever launched. It has spent over a year in Alaska and Arizona desert in all sorts of extreme environments around the clock. That doesn't even begin to address the lab testing on extreme temperatures that are far beyond what the truck will ever see. I am not going to run through all the things he shared. But this motor has been 3-4 years in the making.
2011 F350, CC, SB, Lariat Ultimate, Chrome Package, 4x4, FX4, White Platinum, 6.7L
2001 F-250 CC Lariat, LB, 4x4. 205K and Traded in
1996 F-250 XLT Regular Cab, 4x4, 187K. Bartered for construction work.
2010 Cougar 32RLB 5th Wheel - Traded in 1/22/11
2011 Road Warrior 30C Titanium Edition
dsroka80504 is offline
Old 01-17-2010, 07:53 PM   #10 (permalink)
Show me ONE JUST ONE 6.7 chassis cab being tested in the field. That's all I'm asking. FL&P only has pickups for testing. When ford spoke with us about a test mule they stated "we don't test with chassis cabs". It's their deal. I'm not saying they don't test it but, it's not the same. Try having a guy crank his truck up at 5:30 am (outside temp is 80* humidity is 95%), drives to work, 19,500 lbs loaded with a work body and crane/boom. Goes to the jobsite, it's now say 6 or 7 am, temps climbing to 100*s and 90% humidity. Truck is running at high idle with the PTO engaged running the boom for 4 or 5 hours, still hot, Tech takes 30 min lunch, is he gonna shut the A/C off? nope. Now it's about 3 or 4 PM (when the economy is good sometimes it 6 or 7 or even later into the night), tech packs up tools, folds up boom, shuts PTO off and heads for home but first he's got to run through sugar sand, mud and muck for 3 or 4 miles 4 low, 1st or 2nd gear (6.4 and 6.0 can't turn the 19.5s over in 4 high which is needed to clean the treads and keep traction). Keep in mind the trans is still hot from the PTO running. Now he's on the highway in a few more miles running 75+ mph back to his house. I can bet that every time he's on the go peddle it's 100% throttle to at least 50 mph.
Do you understand my point to testing with chassis cabs? Just look at the halliburton 6.0 Ford shows, Crew Cab 4x4 with a service body and tandem axle gooseneck. That's the way testing should be conducted. You can not simulate that work in a lab.
Old 01-17-2010, 09:01 PM   #11 (permalink)
Yeah, seems like a walk in the park to me quite honestly. Much harder than running a motor to 1200 degrees and supercooling it. Must hard than running it for 24 hours straight wide open in the desert. Much harder than an entire winter in Anchorage at 30 below. The new tranny comes with a PTO built in, so I am guessing it is a safe bet that it has been tested.
I for one couldn't care less how they perform in those extreme conditions and neither could Ford, Chevy or GM. I don't need/want a truck that can survive that, know why? It would cost 200K. Know why they don't make airplanes with giant parachutes? Cost. Same here. You test for the 95% population, which isn't even close to what you mention. Find me a GM or Dodge person that does, and I will gladly eat and entire truck with no salt. HAHA
Old 01-19-2010, 09:30 PM   #12 (permalink)
Did I miss grammar school here? What are you last three sentences supposed to mean?
Old 01-20-2010, 12:49 AM   #13 (permalink)
Pretty simple. Ford, GM and Dodge couldn't care less what 1% of the population does with their trucks, nor should they. The other 99% of us don't want to subsidize building a truck for that minority, that would increase the cost of it 20%. Same reason why they killed the standard shift, nobody buys it and it isn't worth making it for the few extra trucks they would sell. Cheaper to send those buyers a $20 bill and tell them to buy a Chev or Dodge. Basic economics. The cost of the R&D, separate assembly line, along with everything else invovled with adding another option don't warrant it. Kind of like offering a 12" lift kit. Sure, some people would buy it, but all of the buyers they push away not having it don't make up for the cost of offering it.
Old 01-20-2010, 06:12 PM   #14 (permalink)
Well put dsroka!
97 PSD 4x4 Reg. Cab. 155k 4:10. Upgraded E4OD - Straight pipe - Dp-Tuner F6 Chip - Stage II DIY Injectors - AFE DIY Cold Air Intake - 3" Downpipe - Auto Meter Triple Pillar Ultra Lite Gauges - EBPV Delete - Modified Pedistal - Remote Start - DIY E-Fuel - 6.0L Intercooler
fordtough97 is offline
Old 01-21-2010, 10:18 PM   #15 (permalink)
test schmest!! they always test their stuff. pretty hard too. and in the first 1/2 to 2 years of production it always has some sort of update, change, improvement etc.
1%?? what?? more than one percent have trucks in sub zero temps. same for 100 plus desert temps. and i do want it to hold up in those conditions. this way my weather will be "a walk in the park"
this truck is destin for problems, i just know it. and fixing it will be a nightmare.
08 f450 KR 4X4, no roof, no tv, everything else
05 KZ New Vision 41ft toy hauler
03 harley roadking classic
03 honda rubicon
05 bombardier DS650
http://i5.tinypic.com/4ue76eq.jpg
6SPDMANUAL is offline
