Motorcraft Diesel Exhaust Fluid (DEF - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > '11-Up General Questions
'11-Up General Questions General questions related to 2011-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-25-2010, 08:22 PM   #1 (permalink)
TousleyParts's Avatar
Here ya go
Lots of info on the Urea exhaust fluid
There is not a huge markup on this stuff, so its best just to buy local on this one
Just a little FYI (hopefully someone has not posted it yet)
Part Number
Package Size
Dispenser
PM-27-1G
1-gallon Bottle
Fast fill, no spill nozzle
PM-27-J
2.5-gallon Jug
PM-27-D
55-gallon Drum
Available from Rotunda
PM-27-T
275-gallon Tote
WHAT IS DEF?
A non-hazardous clear fluid (67% deionized water / 33% chemically pure Urea) that is injected into the diesel exhaust system to reduce NOx emissions.
WHY DEF?
  • Required for the 2011 model year F-Super Duty 6.7L Ford diesel to meet 2010 EPA emission regulations
  • For use with competitive make vehicles using a SCR (selective catalytic reduction) system
  • The majority of diesel (light and heavy duty) manufacturers will use DEF to meet the new requirements
DISPENSING EQUIPMENT
  • 1-gallon bottles and 2.5-gallon jugs come with a fast fill, no spill, nozzle supplied with each package.
  • 55-gallon drums and 275-gallon totes will require specialized pumping equipment offered by Rotunda.
ROTUNDA DEF DISPENSING EQUIPMENT OFFERINGS
Description
256-00167
DEF 55 Gallon Drum Dispensing System – Electric
256-00168
Dispensing System - Electric
FAQ
Why use Motorcraft DEF?
Motorcraft DEF is API certified meeting ISO22241 which is the only fluid approved and recommended by Ford Motor Company. Inferior product may result in costly damage to the SCR system. System damage as a result of inferior fluid is not eligible for warranty reimbursement.
How is the vehicle filled with DEF?
The fluid is supplied through a fill port located next to the diesel fuel fill port; it has a blue cap clearly marked for diesel exhaust fluid.
What is the capacity of the vehicle DEF tank?
The DEF tanks have a five to six gallon tank capacity, depending on the vehicle configuration.
How frequently will DEF need to be replenished?
The system is designed to last approximately 7,500 miles between fill ups, coinciding with the oil & filter change interval. However depending on customer use, replenishment may need to occur more frequently.
Is there a DEF tank level gauge?
The vehicle instrument cluster will provide indication of fluid level in the DEF tank, as well as provide warning messages when the DEF is low and needs to be refilled.
Can the vehicle be operated without DEF?
The vehicle will not operate properly without DEF. When the vehicle DEF monitoring system detects no DEF is available, the vehicle initially goes into a speed limiting mode and then progresses into an idle only mode.
How should DEF inventory be stored?
DEF should be stored out of direct sunlight in temperatures between 23F and 86F (-5C and 30C)
  • Freezing point is 12F (-11C)
  • Prolonged storage at higher temperatures will cause DEF to breakdown reducing shelf life
    • Storing DEF at 86F reduces shelf life to approximately 12 months
Can DEF freeze in the vehicle?
Yes. However, Ford Motor Company vehicles have a tank and line heater to ensure the vehicle operates in extremely cold climates.
We are Autonation Ford of White Bear Lake selling all OEM Ford parts 10% over dealer cost (formally Tousley)
Please PM me for any price requests
Call us at 1-800-328-9552 OR check out our website www.tousleyfordparts.com Be sure to mention this website for the good discount.
TousleyParts is offline   Reply With Quote
Old 01-26-2010, 06:17 AM   #2 (permalink)
Phil G.'s Avatar
Thank you for the info. It's good to know what it's 67% water so the stuff should be really cheap....probably about the same price as windshield washer fluid.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4.Viper VX790 Alarm/RS w/motion sensor, WD pillar Guages,Touchscreen CarPC in custom console w/ AutoEnginuity,Parrot Handsfree Blueooth,2 Infinity Amps (611A & 7541A) Alpine PXA-H701 Processor, Infinity 6010CS 6.5" components up front and Infiniti Kappa 62.7i 6.5" 2-way in rear doors, 12" RD Sonance Sub, Ranger CB w/ dual Wilson 2000's, 100gal polished alum fuel tank, 5th hitch, Rapid Hitch aluminum TT hitch, Bremen full glass running boards, painted mirrors, grille, door handles,valence,wiper arms,mount. Westin Bull Bar w/LightForce 140's
Phil G. is offline   Reply With Quote
Old 01-26-2010, 08:01 AM   #3 (permalink)
Its a little pricier than windsheild washer fluid. I think list is somewhere around $9/gal, but a little cheaper if you by a whole drum
At least it sounds like the 6 gallon tank will last a while (about 7500 miles)
Old 01-26-2010, 12:09 PM   #4 (permalink)
Phil G.'s Avatar
Does this replace the active DPF filter? If so it's worth every penny!
Old 01-26-2010, 09:05 PM   #5 (permalink)
Parts Jimmy's Avatar
It will still have a DPF also. I am not real happy with Ford's pricing. I believe that most truck stops will have it at the diesel pump soon forcing it to be priced like fuel is.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights, C-Betr Mirrors
2004 Mustang GT
Parts Jimmy is offline   Reply With Quote
Old 01-26-2010, 10:35 PM   #6 (permalink)
I bought 2-2 gallon (4 gallons total) jugs of DEF at the local Hino dealer a week or so ago for the whopping sum of $17.83.
jasonmt is offline   Reply With Quote
Old 01-26-2010, 10:43 PM   #7 (permalink)
That sounds a little more like reality...
Not too far down the road from me is one of the first truck stops in the US to get a DEF pump and it was $2.79 a gallon the last time I stopped by. At $9 a gallon from the dealer that is going to be a hard sell. Then again $9 a gallon is a far cry from the ~$30 a QUART laboratory grade DEF that is being used in the test vehicles...
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline   Reply With Quote
Old 01-27-2010, 07:02 AM   #8 (permalink)
Phil G.'s Avatar
Sound slike antifreeze. I can buy the red Texaco Extended life for $10 jug or pay $30 for the Ford Gold.
Old 01-27-2010, 06:16 PM   #9 (permalink)
The funny part is that Ford/Volvo/Mack/Daimler Trucks/Hino etc. are all getting their DEF from Terra Environmental Technologies Inc. but I am sure someone is going to come on here telling people that the Motorcraft stuff is "better"...
Old 01-28-2010, 07:57 PM   #10 (permalink)
yes they are the company their main plant that makes it is a company subsidiary out of medicine hat (cant remember the name ) it is the worlds largest producer of urea product it supplied 92% of world market this was told to us in a freightliner course they had a tech from the manufacturer there they even make it for mercedes
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline   Reply With Quote
Old 01-28-2010, 08:38 PM   #11 (permalink)
$30 for a gallon of VC-7-B? I sell it in $12-$13 range. Where are you shopping?
2004 Mustang GT
Old 01-29-2010, 07:37 AM   #12 (permalink)
Phil G.'s Avatar
That's what my dealer in Brockville, Ontario wants for it. Parts are definitely cheaper on your side of the border. Thats why I pick up oil filters and cetane boost when I am in Indiana. I have to say though that my dealer treats me very well. My truck has a minor puking problem and they have been giving me the antifreeze since last summer until I get the truck back into them to try to figure it out again. Thay have given me 4 or 5 jugs of it so thats the best price of all!
Old 02-17-2010, 12:41 PM   #13 (permalink)
Agco is claiming it will cost the equivalent of a gallon of diesel fuel at there stores and most should be stocking it by now as they have quite a few tractors out with it now.
ndmtnsledder is offline   Reply With Quote
Old 02-24-2010, 11:22 PM   #14 (permalink)
blueoval4ever's Avatar
What will keep someone from just putting deionized water in the tank? Is there a sensor to check for the presence of Urea?
blueoval4ever is offline   Reply With Quote
Old 02-24-2010, 11:28 PM   #15 (permalink)
If I remember right there are pre and post SCR NOx sensors and if the computer does not see a acceptable reduction in NOx it will let you know that you have issues...
