New F350 SuperDuty - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > '11-Up General Questions
'11-Up General Questions General questions related to 2011-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-16-2013, 12:03 PM   #1 (permalink)
New F350 SuperDuty
I'm looking at purchasing a new F350 SuperDuty for work & personal use from our Ford Dealers Commercial Truck Center. Would like the diesel, but can't afford it right now so here's what I'm thinking:
2013 Oxford White F350 XL
6.2L gas standard cab, long bed
3.73 or 4.30 gears w/ rear electronic locker
FX4 4x4 package
10,000 GVWR package
Heavy service front springs package
Power equipment group
Roof clearance lights
Trailer brake controller
17" 5 spoke cast-Aluminum wheels
4x4 electronic shift on the fly
HD 40/20/40 vinly front seats
Several questions...
1. The vast majority come w/ 3.73 gears, but they offer a few w/ 4.30 gears. Most of the driving will be w/o pulling anything, but it will pull some weight occasionally. Should I opt for the 4.30 (there's no additional charge) or stick w/ the 3.73s? Any idea what gas mileage will be for either gear ratio?
2. What axles, trans, & t-case does this truck come with? Are they any good?
3. Finally... MSRP on this truck is ~ $37,180 what should I be able to get it for OTD? They're giving me the 'ole rebate run-around...
coolbrze is offline   Reply With Quote
Old 01-16-2013, 12:15 PM   #2 (permalink)
badbart's Avatar
My guess is you'll be lucky to get 15 mpg with the 3.73's. Most guys I know that have gas 3/4 tons usually get around 12-14 mpg highway, less in city driving.
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 limited slip, K&N Air Filter, MBRP 4" Turbo back w/muffler, Edge programmer, Billet torque converter, Monster tranny cooler.
2004 Cadillac CTS V 5.7 LS6, Tremec 6 speed,
K&N Cold Air, Magnaflow Exhaust, MSD Ignition,
LS7 clutch, Getrag 3:73 posi-trac, 377 RWHP
badbart is offline   Reply With Quote
Old 01-16-2013, 12:20 PM   #3 (permalink)
Supporting Member
Coolbrz,
I don't have experience with the gassers but do have a couple comments for you:
1) The 3.73 should be all you need with the 6 spd tranny Ford is using now, I would think 4.30s would kill you MPG.
2). Unless your hanging a snow plow off the front, with a gas engine I would think the Heavy service front spring package would make the ride awful rough.
Tim in Central Florida
2012 F350 CC SB Lariat Tuxedo Black w/RollnLock bed cover
2012 F350 CC Cab/Chassis with 9' Knapheid tool box
2006 F250 CC Lariat with ARE construction cap
2007 F350 CC Lariat with 8' Knapheid tool box
2006 E350 Extended Cargo Van
2005 F350 CC King Ranch with ARE construction cap
2005 E350 Extended Cargo Van
2004 E350 Extended Cargo Van
And, sorry to mention on this forum
Two 2012 Nissan NV3500 High Roof cargo vans
Cell1Diesels is offline   Reply With Quote
Old 01-16-2013, 12:20 PM   #4 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
1. I'd get the 3.73s personally. I am not sure of on the mileage of a gasser haven't owned and probably will never own a gas truck where diesel is an option.
2. Dana 40 and 60 axles i think. No clue on the transfer case. You can get the only transmission available which is the new 6 speed automatic.
3. Get hold of one the site sponsors a lot of guys say nothing but good things and how much they've saved.
I hope this helped a little bit.
Sent from my iPhone using AutoGuide.com App
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline   Reply With Quote
Old 01-16-2013, 04:06 PM   #5 (permalink)
I'm getting 14mpg mixed driving empty with 4.30's in a '13 4x4 CC SB gasser. Drive like an old woman & keep it under 60 mph and you could prolly do better. Don't be afraid to get the lower gear, the mileage difference is going to be small.
Dana super 60 axle up front. Sterling 10.5 full floating in the rear, unless you're thinking DRW. Then it's a Dana 80.
G-Dub
bryyce62 is offline   Reply With Quote
