'11-Up General QuestionsGeneral questions related to 2011-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Heater fans seems to have stopped functioning. Doesn't work in auto or manual mode. Temps are around 30* and passengers are freezing and letting me know about it
Anyone else had this issue? It seems to put out heat and thermostat functions but no blower output. Would be damn nice to have a voltmeter at least in this $50k POS but the headlights are bright and nav cluster seems ok
Should I look at fuses or is this likely internal electronics? Any help appreciated and I look to give local shop and Ford a piece of my mind as soon as they open this morning!
Current Fleet -
2011 F350 CC,SWB,SRW,6.7 Lariat on 20s
2006 F350 CC,LWB,SRW,6.0 Lariat ~130K
2002 F250 SC,LWB,SRW,7.3 Lariat ~175K
1996 F350 7.3 300K and still going strong
1984 F250 6.9 - pretty much dead
1978 F250 400 - oldie but a goodie
1978 F150 400
1962 F100 292
2011 F250 CC Lariat Ultimate, Royal Red/Pale Adobe, 18" wheels, 3.31 locker, 172"WB factory Nav/Sync,etc.
Also have a 1997 F450 7.3 XLT with 14' box, Hypertech programmer
1987 F350 6.9 Banks Sidewinder, 12' box
Still going at 200K+
Traded:08 F250 CC 4x4 Lariat, 172"WB
Traded:01 F350 CC 4x4 Lariat, 172"WB
Be sure to check (or shuffle) the heater fan relay as well. If you don't have a way to check the relay, swap the heater fan relay out with another of the same type in the fuse box just to be sure it is not the relay causing the problem (and saves spending $$ on a relay if its not the problem)
~Wolf
'12 F550 Tux Black Lariat Supercab 186" WB , 4x4 6.7, 19.5GVW
13k lb hooklift, Cramaro auto tarp, Insta-chain automatic tire chains, Boss 9' SD plow, Atomic led cab marker/strobe
Custom~ fabbed rear bumper, tarp gantry, rear warning led setup, SEIC & rear strobe control panel (in the drivers side powerpoint trim)
And more to come
'99 F350 XLT CC LB 4x4 dually 7.3, Dents build character 408,000ish miles on the clock (2nd motor)
'93 Exploder Sport, 5.0 swap, 4r70w+Baumann TCS, Atlas 2 T-case 3.8:1 twin stick, Narrowed D44 '79 f150 solid axle swap, bunch o other junk...
'69 Ford rust bucket, err Bronco, "resto"/mods in the planning stages
These trucks use modules to control the fan speed. In fact there are two modules involved regarding the fan. On virtually all of the newer Super Duties I have repaired an inoperative blower were caused by the Blower Motor Speed Control module and one where the motor had failed. Unfortunately this is not something you can go shaking relays and smacking the dash or probing with a volt meter to fix. It does require a scan tool and knowledge of what to test and where...
If you want to kill some time while waiting for the Ford dealer to open you can check fuses #23 and #50 in the Battery Junction Box and fuse #46 in the Smart Junction Box.
__________________ . Ford Master Diesel Technician Diesel Technician Society Diesel Mentor Directory
This last summer while crossing the desert I had no air from the fan motor. After stopping at a Rest Stop and restarting all was working. I'm guessing it had to do something with the ignition switch. Just something to consider.
'08 F350 Lariat CC 6.4 DRW 4.10 4x4 manual hubs and 62 gal fuel tank.
