REMOTE START CLIMATE OPERATION - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > '11-Up General Questions
'11-Up General Questions General questions related to 2011-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 12-08-2010, 10:46 AM   #1 (permalink)
doczenith1's Avatar
My Photos: (11)
Can any of you current owners clarify what the manual states. In particular my questions are:
1.) Manual mode: It appears that if I leave the climate control in any position other than Auto when I turn the truck off that when I remote start the truck it will come on with with max A/C or floor/defrost and I'm assuming the fan speed I left it on?
2.) Automatic mode: I'm assuming this mode happens when I turn the truck off with the climate control set to automatic. Looks like the way to go if you want the climate controlled seats to activate.
3.) Automatic mode: For cold weather conditions where does the system direct the warm air? I would assume floor/defrost but you never know.
Manual climate control
For hot weather conditions:
• The climate control system will be set to MAX A/C.
For cold weather conditions:
• The climate control system will be set to provide maximum heating
in (floor/defrost) mode.
• Rear defrost/heated mirrors (if equipped) will be activated.
For moderate weather conditions:
• The interior cabin will be heated, cooled or off, based upon the
previous operating state (last ignition-on cycle).
• Rear defrost/heated mirrors (if equipped) will be deactivated.
Automatic climate control
• The interior cabin will be cooled to 72°F (22°C).
• The cooled seats (if equipped) will be set to high.
• The interior cabin will be heated to 72°F (22°C).
• The heated seats (if equipped) will be set to high.
• The interior cabin will be heated, cooled, or off, based upon the
• Heated/cooled seats (if equipped) will be deactivated.
(Yes, I've read the entire manual and all supplements and I don't even have the truck yet )
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
2003 Mustang SVT Cobra, black convertible. - 6/2007
SOLD: 2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010
Link: Fuel Mileage Spreadsheet With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
Link: Rapid-Heat Sup Cab Heater Test Data and Graphs
doczenith1 is offline   Reply With Quote
Old 12-08-2010, 05:43 PM   #2 (permalink)
Its my understanding that in Auto mode, the computer will turn on the appropriate climate and seat settings based on the temp.
2012 F550XL 19,500gvw, Oxford White/Steel interior, 6.7psd, Stainless simuators, Sync, 16Ft Morgan body, Waltco tuckaway 2500 lift gate.
2011 F250 CC Lariat Ultimate, Royal Red/Pale Adobe, 18" wheels, 3.31 locker, 172"WB factory Nav/Sync,etc.
Also have a 1997 F450 7.3 XLT with 14' box, Hypertech programmer
1987 F350 6.9 Banks Sidewinder, 12' box
Still going at 200K+
Traded:08 F250 CC 4x4 Lariat, 172"WB
Traded:01 F350 CC 4x4 Lariat, 172"WB
SCORPIO26 is offline   Reply With Quote
Old 12-08-2010, 10:37 PM   #3 (permalink)
HVAC - DATC (Dual Automatic Temperature Control) System
When the remote start feature is used, the climate control system automatically sets certain parameters in an attempt to achieve a comfortable cabin temperature. These parameters are set based on outside air temperature. During remote start, the outside air temperature is continually evaluated and HVAC system behavior can change if the outside air changes between cold, moderate and warm temperatures.
For cold ambient air temperatures as determined by the HVAC module AUTO mode to request heat:
• the airflow mode is set to FLOOR/DEFROST
• the temperature is set to 72° F (22° C)
• the blower speed is set to AUTO
• the air inlet mode is set to AUTO
• the auxiliary electric heater is enabled if needed (diesel only)
For moderate ambient air temperatures as determined by the HVAC module AUTO mode to request heat or cooling:
• the airflow mode is set to the AUTO
• the temperature is set to the last user setting (Temperature setting is limited to 65° F (18° C) minimum and 85° F (29° C) maximum. If the temperature is set above or below that range, it will use the minimum or maximum value.)
• the blower speed is set to the AUTO
For warm ambient air temperatures as determined by the HVAC module AUTO mode to request cooling:
• the airflow mode is set to AUTO
• the auxiliary electric heater is not enabled (diesel only)
HVAC - EMTC (Electronic Manual Temperature Control)
For cold ambient air temperatures (below 32° F (0° C)):
• the airflow mode is set to FLOOR/DEFROST.
• the temperature is set to full HOT.
• the blower speed is set to HIGH.
• the air inlet mode is set to fresh air.
• the auxiliary electric heater is enabled if needed (diesel only).
For moderate ambient air temperatures (between 32° F (0° C) and 80° F (27° C)):
• the airflow mode is set to the last user setting.
• the temperature is set to the last user setting.
• the blower speed is set to the last user setting.
• the air inlet mode is set to the last user setting.
For warm ambient air temperatures (above 80° F (27° C)):
• the airflow mode is set to MAX A/C.
• the temperature is set to full COOL.
• the air inlet mode is set to RECIRC.
• the auxiliary electric heater is not enabled (diesel only).
HVAC - Auxiliary Electric Heater (DATC and EMTC)
The AHCM (Auxiliary Heater Control Module) activates if all of the following conditions are met:
• The ignition switch is in the RUN/START position
• The engine is operating at greater than 500 rpm
• Any ON mode is selected on the HVAC module
• The temperature setpoint is greater than 80% of the highest setting (EMTC only, DATC uses software algorithm based on interior temp and set point)
• The engine coolant temperature is less than 185° F (85° C)
• No alternator faults have been recorded and alternator is not at full capacity
The AHCM deactivates if any of the following conditions are met:
• The ignition switch is in the OFF or ACC position
• The engine coolant temperature is greater than 185° F (85° C)
• An alternator fault has been detected or the alternator is fully loaded due to external electrical loads
• The engine is operating at less than 500 rpm
• The auxiliary heat request is NO from the HVAC module (EMTC or DATC)
Seats
When the vehicle is started using the remote start feature, the driver/passenger climate controlled seat activates in full heat mode when the outside temperature is less than 32° F (0° C) and full cool mode when outside temperature is greater than 80° F (27° C).
Mirrors
When the vehicle is started using the remote start feature and the outside temperature is less than 32° F (0° C), the heated mirrors will be activated.
Rear Defroster
When the vehicle is started using the remote start feature and the outside temperature is less than 32° F (0° C), the rear defroster will be activated.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline   Reply With Quote
Old 12-09-2010, 01:10 AM   #4 (permalink)
mc5150's Avatar
Originally Posted by PowerStrokeHD View Post
Seats
I live in Alaska and I have yet to notice my heated seats come on when using the remote start. Its been between 0-30 degrees since I bought my truck and i use the remote start every morning. Does my truck have an issue??
Previous: 2008 F350 King Ranch, CC, 6.4L
Current: 2011 F350 Lariat, CC, 6.7L
mc5150 is offline   Reply With Quote
Old 12-09-2010, 06:55 AM   #5 (permalink)
You have to set the climate controls to AUTO for it to work.
Old 12-09-2010, 07:50 AM   #6 (permalink)
Depends... When using remote start the ON lights for the heated seats will NOT be illuminated even if they have been activated. The seats will also return to the previous user setting once the vehicle has been started with the key. These two operational factors have already confused a couple of '11 owners into thinking the seats are not working.
Now if they are simply not working, then yes there is likely a issue...
Old 12-09-2010, 07:29 PM   #7 (permalink)
So the indicator lights for the heat button do not illuminated when in remote start...I was also wondering if mine were working. Last couple of days the temp as been 22f, when I get in after the truck as been remote started and idled for about 5 minutes the seats are stone cold. Also have the climate control set to Auto, guess I will let it sit longer and see if the seats actually warm up.
2011 F250 CC Lariat Fx4 Tuxedo Black
tlew79 is offline   Reply With Quote
Old 12-11-2010, 12:36 PM   #8 (permalink)
doczenith1's Avatar
My Photos: (11)
I don't remember the heated seats in my '02 ever feeling warm to the touch after being on for 5-10 minutes but when sitting in the seats you do start to feel the heat after a minute or so.
Old 12-14-2010, 11:19 PM   #9 (permalink)
Mojoryb's Avatar
Considering that these CGI blocks take for ever to warm up, your only heat during a remote start in a freeze, if you don't have the auxillary, is the seats. I've been in discussions with my dealer here in BC, Canada about the way remote starts used to deal with the climate controls...however you left them, & according to him there are quite a few folks wanting Ford to flash the remote back to the old way. I agree. Also, if I leave the mirrors & the seat on when I shut it down, they do not return to those settings when the key is inserted after a remote start. There's my 2 bits, for it's worth.
Mojoryb is offline   Reply With Quote
