Black truck - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > '11-Up Ordering Information
'11-Up Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 12-07-2012, 08:26 AM   #1 (permalink)
gnxtc2's Avatar
Black truck
Any chance of getting a black truck? Seems like most of the colors have some type of metallic in them. What happened to the days of getting a solid color/
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Punisher Trans with Precision Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan,, Joe Servo IDM, MAP sensor mod, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, Jonathan Jones Tunes, CJC Traction blocks, 213K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline   Reply With Quote
Old 12-07-2012, 02:44 PM   #2 (permalink)
Sportscraft's Avatar
Unfortunately solid black is gone on the superduties replaced with the new black metallic as you describe. The only way would be is if you can still find and early model 2012 on a dealer lot somewhere or buy a used vehicle that has the black clearcoat. They did a short production of the good old plain black after the earthquake in Japan because they couldn't get ahold of the product to make the metallic paint. I jumped on the bandwagon and traded my 2011 metallic black truck for a 2012 plain black while I had the chance!
2012 F450 Crew Cab DRW, 4.30LS, Lariat Ultimate, FX4, Chrome Package, Snow Plow Prep, 5th wheel prep, LineX Spray In Liner, Cable Lock. Black Clear Coat with Monotone Black Int!
Sportscraft is offline   Reply With Quote
