2013 F350 Gross Vehicle Weight - Diesel Forum - TheDieselStop.com
'11-16 Gas Engines Discussion of the gas engines available in the 2011-Up Super Duty trucks
post #1 of 6 (permalink) Old 03-08-2013, 09:51 PM Thread Starter
I have to purchase my permanent tag for my 2013 F350 4x4 with the 6.2 and the tag office will need to know the gross vehicle weight. I checked the sticker on the inside of the door panel and it states 11,300lbs.
I assume this is the GVW and what the tag office will need, correct?
Judithgap is offline
post #2 of 6 (permalink) Old 03-08-2013, 11:56 PM
That is probably the GVWR, meaning the max weight it's rated to carry. The GVW is most likely the actual weight empty which is another story. Normally the manufacturer provides this info in the MSO before title is applied for. Better find out what number they want, as there will be a 5000LB difference at least. All this info is plainly written in paper when you go to get plates and no need for you to know. F350 with 11,300 GVWR? Well things have gone up,up,up over the years. Mine is 9200.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
post #3 of 6 (permalink) Old 03-09-2013, 08:39 AM
11,300 is the gross vehicle weight rating. You should also have a payload rating sticker on your door (probably around 3000-4000lbs). To find the weight of the truck you can subtract the payload rating from the GVWR.
2014F450 is offline
post #4 of 6 (permalink) Old 03-10-2013, 04:19 PM
Judithgap-
Your one of the first posters I've seen with a 2013. How are you liking your 2013 6.2L so far? Seen in previous posts the 6.2L are getting around 14mpg highway which is not too bad for the big super duty. Just a personal preference, but I've always liked the stance the F350 has over the F250. Nice choice.
wyo2track is offline
post #5 of 6 (permalink) Old 03-11-2013, 08:42 PM Thread Starter
Originally Posted by wyo2track View Post
Judithgap-
So far I love it. Traded an 08 6.4 F250 for it about a month ago (no more regens).
I replaced the factory 275/70/18's with 295/70/18 Nitto Terra Grapplers and really like the look. Truck was ordered with the camper package and 4.30 rearend. Milage is running 14.5 to 15 on the open road and 9.5 to 10.5 around town. Really stout and a lot of power for a gasser.
post #6 of 6 (permalink) Old 03-12-2013, 12:04 AM
Thanks for the info! From the sound of that the F350 must be a real beast with the 6.2 and 4.30's!
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Gas Engines
