6.2 FUEL FILTER CHANGE - Diesel Forum - TheDieselStop.com
'11-16 Gas Engines Discussion of the gas engines available in the 2011-Up Super Duty trucks
post #1 of 9 (permalink) Old 03-16-2012, 04:26 PM Thread Starter
Nix Besser's Avatar
Has anyone change the fuel filter on the 6.2 gasser yet? My machine is coming up on 2 years old in June, right now I just turned 20,000 miles on the clock and am planning on changing the fuel filter. I With all the crap in gas now I want to be pro active on this. Just looking for info on what everyone else is doing.
Nix Besser
...last of the Independents!!!
Nix Besser is offline
post #2 of 9 (permalink) Old 03-16-2012, 09:10 PM
Has the filter been moved to the tank or is it still on the frame.
Looks like its the same inline that has been used for years.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0 stolen 12/31/14
by clifford bledsoe.
'09 Cameo 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'96 IH 7.3 4700LP field mechanic
'84 Bronco II 2.8 4 speed 4X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
post #3 of 9 (permalink) Old 03-17-2012, 09:10 AM Thread Starter
Nix Besser's Avatar
I'm not sure, the owners manual indicates it's in the fuel tank and doesn't need to be changed, but when I look it up it shows a typical inline canister filter. Somebody out there in the forum nust know.
Nix Besser
post #4 of 9 (permalink) Old 03-19-2012, 12:08 PM
It's in the tank, one of those "lifetime" filters. I'm not a fan of the concept but if you wanna change it, you'll have to drop the tank.
Are you questioning the quality of gas based on the on-going shenanigans with the quality of diesel?
2011 F350 Sterling Gray 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, JL HD900/5, JL C5-570's, JL 13TW5, Spl2k box, LC6i converter, Amp steps, Ford Sync Lockpick, Rancho 9000's, Bilstein 7100 stabilizer, leveled w/ 35" Toyo's, 5 Star tuned
Sold - 2000 F250 V10, sc, lb, 6.5in Pro Comp lift, Bilstein 5100's, 37in Toyo M/T's, 17in MT Classic II's, K&N FIPK, 3.5in B&B exhaust, Randy Ellis light bar, 4 - 8in KC 800 Series lights
2000silverbullet is offline
post #5 of 9 (permalink) Old 03-20-2012, 05:00 AM Thread Starter
Nix Besser's Avatar
Thanks, I have also found that the "filter" is not ment to be serviced. DUMB idea by the way.
And yes, I think that the quality of the fuel is the lowest I have ever seen.
Nix Besser
post #6 of 9 (permalink) Old 03-30-2012, 10:22 PM
usmarshls's Avatar
most if not all Fords since 2010 have not had fuel filters "inline". that for gas motors only.... all Diesels still have them.
2014 FORD F-250 CC SB FX4 6.2L 3.73 E-locker, black on Black inside, Blue Jean, NAV, SYNC, window tint, spray in bed liner
Added-
LED projector reverse lights
Factory upfitter switches
rear seat cover "kids are a mess"
LED floor lighting front and rear.
LED lights in bed under rails.
MORE LEDs coming soon.
SOLD
Goodbye my love
2005 F-350 King Ranch FX-4 CC long bed
2in level kit.airade intake with 4micron sock.superchips.sinister coolant filter.blue spring update.ranch hand wrench ready front bumperreplacement. installing glowshift gauges EGT,BOOST,TRANS TEMP,FUEL PSI. with quad gauge pod A-PILLAR.4IN turbo back cat delete
2004 F-250 V-10 -SOLD
1986 F-150 V-8 302CID first year of EFI -SOLD
1984 F-250 V-8 351CID Carb SOLD
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
usmarshls is offline
post #7 of 9 (permalink) Old 03-30-2012, 10:40 PM
chuckster57's Avatar
Ford isn't the only one to stop using a serviceable in-line fuel filter for gasoline vehicles.
Sent from my Autoguide iPhone app
Train Horns:
PM please not visitor message
chuckster57 is offline
post #8 of 9 (permalink) Old 04-04-2012, 12:15 AM
The main fuel filter is the filter on fuel pickup. It has a material that rejects water and of course, all things except some pretty fine stuff. The filter after the pump stops motor particles and everything else. The brush and commutator wear particles are bad news for the injectors and have to be contained. The amount of stuff getting into the non-serviceable filter is reduced so it makes it a filter that lasts the life of the pump. On cars I have experience with that have the lifetime system, filters are not being an issue. If you suspect crappy fuel you need to drop tank and clean it whether it has a serviceable filter or not. If the Ford pickup filter is as good as the others then the truck will quit running before it ingests water if you get a few gallons of water.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears! 2006
F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 141K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100 208K miles
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 247K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #9 of 9 (permalink) Old 04-29-2012, 10:35 PM
biz4two's Avatar
Arrow
Yeah...in tank filter. IMHO...I think it is a good idea...and just one less thing to change. First car that I owned that had the same idea...was back in 2003. Never an issue...and traded in 2010 with 130000...still run like a top.
biz
biz4two is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Gas Engines
