Axle Ratio - 3.73 or 4.30 - Diesel Forum - TheDieselStop.com
'11-16 Gas Engines Discussion of the gas engines available in the 2011-Up Super Duty trucks
post #1 of 16 (permalink) Old 10-09-2010, 08:59 AM Thread Starter
I'm thinking about purchasing a 2011 6.2 F250 and want some input on axle ratios. The truck will be primarily used for commuting and household chores such as Home Depot runs. I might tow a 5,000 # trailer one a year. I plan on eaither leveling with 33"s or possibly installing a 4" lift with 35's. I know the 4.30's would be better for the 35" tires but are they neccessary? Every truck I see on lots around here have 3.73's. Would the 3.73's MPG suffer with the 35's? Any input would be appreciated.
hedgehog is offline
post #2 of 16 (permalink) Old 10-09-2010, 12:28 PM
LTFFNREMTP's Avatar
I would probably go with the 4.30s if you plan on larger tires AND towing, but what is the stock tire size? (as i have no idea) There are times when i wish my truck had 4.10s. But i do think you could probably live with the 3.73s with no problem tho, esp if you pulled mostly highway driving. Stop and go might get thirsty.
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
post #3 of 16 (permalink) Old 10-09-2010, 12:37 PM
Going_Going_Gone's Avatar
Since the mileage with the 3.73s will not be hugely better than the 4.30s, and considering you plan to eventually add larger diameter tires, I myself would go with the 4.30s. You'll probably have to order it as most dealers spec the 3.73s on their stock units. As far as stop and go mileage, I would think that the 4.30 ratio would be a wash as the engine would not have to work as hard to get the beast moving.
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s now gone, but greatly missed
Going_Going_Gone is offline
post #4 of 16 (permalink) Old 10-09-2010, 10:20 PM
Front Runner's Avatar
With what you've described, you'll be better with 4.30's.
2002 Excursion Limited, V10, 4x4, 3.73
2011 F-250, FX4, SOLD
Front Runner is offline
post #5 of 16 (permalink) Old 10-10-2010, 05:00 PM
35"s are only 1" taller than the stock 20s. You can also fit 35s on a stock non-lifted truck. If I were to get a 4" lift i'd get 37s and 4.30s but stock height allows for a harder working truck and is how I keep mine.
Carl Lassiter is offline
post #6 of 16 (permalink) Old 10-10-2010, 06:37 PM
My Photos: (9)
From what I've read, the 4.30's don't really change the mileage worth speaking because the engine is working less - and that's just driving. I'm looking at the 6.2L and will consider the 4.30 first. It seems the new 6-speed is much better with the 4.30's than the last generation trannys.
Smokewagun is offline
post #7 of 16 (permalink) Old 10-10-2010, 08:02 PM
20"s are not avail on 6.2L equipped trucks. I believe the stock tire height is 32.5 or so inches.
MonteCarlo31 is offline
post #8 of 16 (permalink) Old 10-17-2010, 09:53 AM
Nix Besser's Avatar
I have the 4.30's and am glad I ordered it that way. (I didn't see any 4.30's on the lot)
My machine doesn't see highway driving much, but I do tow with it and I have had a low of 12.2 mpgs and a high in ther 14's (on a tankfull) so I don't think you give up much to the 3.73's. And ther 4.30's are better on the go when towing.
NIX BESSER
...last of the Independents!!!
Nix Besser is offline
post #9 of 16 (permalink) Old 10-18-2010, 08:03 PM
Feedback Score: 3 reviews
3.73 no question..that motor has max tq so low 4.3's will just burn the tires off..5k tow...ya won't know its behind you..you will REGRET 4.3's.
caryt is offline
post #10 of 16 (permalink) Old 10-18-2010, 09:27 PM
Chuckdogg6.0's Avatar
Send a message via AIM to Chuckdogg6.0
I love my 3.73, unless you are towing all the time i would go with the 3:73's
2011 F350 6.2 XLT Crew cab SRW 4x4 3:73 E-locker Sync 4.2lcd
- Banks Exhaust w/ custom extras
- 5600k Head Lamps
- 5600k Fog Lamps
- Blacked Out Cab lights
- Blacked Out Mirror lights
TRADED--10/03 build F250 6.0 XLT Ext Cab 4x4 Auto,
06 Yamaha Banshee
Anniversary Addition
Powder coated black T5 exhaust
Chuckdogg6.0 is offline
post #11 of 16 (permalink) Old 10-19-2010, 06:11 AM
Nix Besser's Avatar
Originally Posted by caryt View Post
3.73 no question...you will REGRET 4.3's.
Dude, "REGRET" might be a bit strong. Have you had one with that ratio?
post #12 of 16 (permalink) Old 10-19-2010, 05:16 PM
Ya know I made a bigtime mistake and I'll retract my post as I didn't see this was about a Gas motor..sorry to all.
Cary
caryt is offline
post #13 of 16 (permalink) Old 10-19-2010, 05:32 PM
I have 3.73's. Works really well for me. I tow maybe 12-15 times a year. If I towed all the time; 4.30's would be a better way to go. For those who will never tow or just tow every once in a while; the 3.73's are better. For those who do alot of highway driving without towing; the 3.73's are better also.
post #14 of 16 (permalink) Old 10-19-2010, 09:14 PM
Agree
- 5600k Head Lamps
- 5600k Fog Lamps
06 Yamaha Banshee
post #15 of 16 (permalink) Old 10-20-2010, 11:34 PM Thread Starter
How will 3.73's be with 35" tires?
Like I said, I will probably only tow 5,000# trailer once a year
hedgehog is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Gas Engines
