Disappointed In Lack of 6.2L Feedback - Diesel Forum - TheDieselStop.com
'11-16 Gas Engines Discussion of the gas engines available in the 2011-Up Super Duty trucks
post #1 of 26 (permalink) Old 08-17-2011, 08:01 PM Thread Starter
My Photos: (9)
I'm looking into moving up from my 2010 F-150 Supercrew and back to a Superduty. I can't justify the cost of the diesel for my use, bug based on the lack of real feedback on an engine that is a year old already, I can't really get excited about the 6.2L now, either.
Is the 6.2L that unpopular, or just not exciting enough to generate feedback?
Smokewagun is offline
post #2 of 26 (permalink) Old 08-17-2011, 09:17 PM
Old Mose's Avatar
I too would like to hear more about the 6.2. I wonder how many are out there, compared to the number of oil burners sold.
I do know that my '05 6.0 and this '08 6.4 have been much more expensive to run than my former V-10s or 460s. And my wife's '04 F-150 5.4 has been flawless.
Mose
2008 F-350 Lariat 4x4 LWB Crew Cab, 6.4, Auto Trans, Job 2
NRA Life Member
Oath Keeper "Not on my watch!"
Old Mose is offline
post #3 of 26 (permalink) Old 08-18-2011, 04:37 AM
JasonRandolph's Avatar
I jumped ship this past Monday
Went from a 05 F350 6.0 to a 2011 F250 6.2
I was starting to have problems with the 05 and it was not really cost effective to keep it
I only have 80 miles on it, So far so good
This Sat I am going to Massachusetts so I will fill her up and check milage
I have a 28' Travel Trailer I will be towing with this rig
Jason
2013 Ruby Red F350 CC Lariat Short Bed 6.2L
2011 White F250 CC XLT Short Bed 6.2L (Traded)
2005 F350 Lariat Crew Cab Long Bed ,MBRP 4" Off Road Exhaust,20" Ford Harley wheels with BFG AT,Bilsteins,Zoodad mod,Acufab Power Elbow (TRADED)
2005 Harley F350 Crew Cab Long Bed (SOLD)
2002 Excursion Diesel limited 4X4 V Code Front springs,F350 Rear Blocks,AFE Stg2 ProGuard7,MagnaFlow XL Exhaust 3.5DP, Helwig Swaybar, Bilstines F&R,285-70-16 BFG KOs on Stock F250 Rims (SOLD)
1999 E250 Work Van (CLUNKERED)
JasonRandolph is offline
post #4 of 26 (permalink) Old 08-18-2011, 02:00 PM
Old Mose's Avatar
Thanks, Jason. Congrats on the new truck. I'm real close to jumping, too. Look forward to hearing how your trip goes.
Happy Trails,
Mose
NRA Life Member
Old Mose is offline
post #5 of 26 (permalink) Old 08-18-2011, 03:52 PM
Sloo's Avatar
I have almost 40K miles on my 6.2. I have had zero problems and love it. I think the reason there are not a lot of posts is that there are not a lot of problems. It just runs good so people don't complain.
The transmission is a different story as you can see from all the posts on it in other sections.
Sloo is offline
post #6 of 26 (permalink) Old 08-22-2011, 01:37 PM
Sloo...your having transmission issue on your 6.2 too?
2015 Power Stroke F250 Lariat
, Bakflip cover with Rhino Bedliner so far.
6757 is offline
post #7 of 26 (permalink) Old 08-23-2011, 09:44 AM
Sloo's Avatar
Yes. Same as some of the diesels. 2-3 shift flare on first drive of the day and 4-5 shift issues.
I am currently waiting on my dealer to replace several parts (solenoids) on my transmission related to the latest TSB, 11-7-10.
My Build date is 5-2010, so maybe they got it fixed on new trucks.
Sloo is offline
post #8 of 26 (permalink) Old 08-23-2011, 04:05 PM
11-07-10 is the TSB for the diesels. The original TSB for the trans issue on the 6.2 is TSB 11-05-19, which has since been superseded by TSB 11-06-11 (it was only a wording change on the TSB, nothing changed in the procedure).
If your truck was built before 4/11/2011, you can get the update and based on your build date, may or may not need the solenoids replaced in the trans (before 11/19/2010 gets the solenoids replaced). Anything after 4/11/2011 got the update on the line.
I had the update done on mine (build date 12/2010, didn't need solenoids) and it's been hiccup-free since then.
BTW - I'm lovin' my 6.2, no complaints here.
2011 F350 Sterling Gray 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, JL HD900/5, JL C5-570's, JL 13TW5, Spl2k box, LC6i converter, Amp steps, Ford Sync Lockpick, Rancho 9000's, Bilstein 7100 stabilizer, leveled w/ 35" Toyo's, 5 Star tuned
Sold - 2000 F250 V10, sc, lb, 6.5in Pro Comp lift, Bilstein 5100's, 37in Toyo M/T's, 17in MT Classic II's, K&N FIPK, 3.5in B&B exhaust, Randy Ellis light bar, 4 - 8in KC 800 Series lights
Last edited by 2000silverbullet; 08-23-2011 at 04:06 PM. Reason: added remark about the 6.2
2000silverbullet is offline
post #9 of 26 (permalink) Old 08-24-2011, 07:51 PM
Sloo's Avatar
Was yours for the 2-3 shift issues? Especially on first drive of day?
Sloo is offline
post #10 of 26 (permalink) Old 08-25-2011, 02:22 PM
Yep, in the morning on the way to work before the trans warmed up and in the evening on the way back home (after a long soak, ~8hrs of sitting).
It would behave most of the time but sometimes it would go from 2nd, long pause, then into 1st, then into 3rd or 4th, it was goofy when it would occur. I could make it do it on command to but haven't been able to since the update.
post #11 of 26 (permalink) Old 09-20-2011, 04:20 PM
Towed with mine over the weekend
Ran great
Very happy with my decision to go to a gas 6.2 from my 6.0
Jason
post #12 of 26 (permalink) Old 09-23-2011, 12:08 PM
mbot's Avatar
Talking
Love my 6.2L
Truck was built in June 11, I bought it in July....
Have 3,300 miles on it now, and it's great. Mileage is decent on the road (with 3.73, I can get 16-17mpg on the hwy. City is 11-13 depending on how much I let it idle and how hard I drive it. Both figures are slightly better than my old 6.4 Diesel got.
Power is good...........off the line, it's a tad sluggish, but Ford has the ECM tuned to only open the throttle part-way until you hit 4000 rpm, regardless of throttle position.......this is partially why there's such a burst of power when you hit 4000 rpms.........
It's a heck of a lot simpler than a new diesel, with much less emissions crap to worry about. That's why I made the jump, and I have no regrets. It's my daily driver, and I only tow heavy (8500#) about 2x a year.
Works for me
2011 F250 CC/SB 4WD Lariat 6.2L
mbot is offline
post #13 of 26 (permalink) Old 09-24-2011, 01:26 PM
00buck's Avatar
Mbot, sounds like a great ownership report so far.
I was curious, what speed was the 16-17mpg highway obtained at?
2011 Silver Crew Lariat 4x4 6.7l w/ B&W Companion hitch & Firestone air bags
2012 Starcraft 278 BHS 5er
2009 Polaris Ranger XP
00buck is online now
post #14 of 26 (permalink) Old 09-24-2011, 08:01 PM
ZMANN's Avatar
I have not paid much attention to the new gassers until I noticed this thread
kinda cool!!
ROBUST, FORD TOUGH: ALL-NEW 6.2-LITER GASOLINE ENGINE COMPLEMENTS 2011 FORD SUPER DUTY | Ford Motor Company Newsroom
O6 King Ranch cc sb 4 inch lift ,35 Pro Comp,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Marinco Mod ,Zoodad waste Fabtech traction bars, Some other stuff
ZMANN is offline
post #15 of 26 (permalink) Old 09-24-2011, 09:32 PM
mbot's Avatar
About 62mph, 2-lane rural highways.....
mbot is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Gas Engines
