Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 04-09-2005, 10:18 PM   #1 (permalink)
05 V10s leak too!
I am getting a little tired of my oil leak and got a wild hair up my butt and test drove a V10 today. Drove about 20 miles and parked it back at the dealer, looked underneath at bellhousing knowing it would be dry because it was not a PSD. Blew my mind, it had wet oil on the bellhousing. What the heck is going on with these trucks?
2004 F250 6.0 PSD, XL Reg. cab, Torque Shift, 3.73 limited slip. Build date 9/03.
2004 26ft Salem fifth wheel w/super slide 6500#.
Krispy is offline
Old 04-09-2005, 10:23 PM   #2 (permalink)
Re: 05 V10s leak too!
Ridiculous in today's world that ford cannot figure out how to build it without leaks. It sure shows they put quality as job 1 [img]/ubbthreads/images/graemlins/vomit.gif[/img]
'05 Dodge, Bright White 2WD Quad Cab 3500 H.O. Cummins TD 325/610, 48RE, SRW, SWB Laramie.
29' Alpenlite Riviera RK Limited Edition, Hijacker 16K Ultra Slide Hitch
Previous RAM - '98.4 12V CTD.
tschwab is offline
Old 04-10-2005, 02:39 AM   #3 (permalink)
hitecdan's Avatar
My Photos: (20)
Ford would probably claim that is was assemble lube leaking out and should stop after a few thousand miles.
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC (Stationary Elevated Idle Control for 03s & 04s)
Born on date: Jan 20, 2003
Mileage Record
Latest Oil Report
Number of times the EGR valve has been replaced/cleaned: 0
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 04-10-2005, 03:22 AM   #4 (permalink)
My 1999 F-150 had a head gasket leak at 8000 miles. Ford never seen one leak at that spot. They wanted the whole engine. So at 8000 miles they pulled a new engine off the assembly line. I traded that in on a 2001 F-350 with a V-10. I had it for a couple of months and I stopped at the post office to get the mail. I stopped and all of a sudden smoke started pouring out of the engine. I jumped out and opened the hood. I could see nothing. As fast as it started to smoke, the smoke was gone. I took it home and climbed under it to see oil all over the bell housing. It turned out to be a rear main that was dripping on the exaust sheild and pooling in there. It never dripped on the ground, it always caught its own drip. Then my 2004 6.0 started to leak right from new at the rear main. All were fixed the first time, never to happen again. Heck, with the F-150, the first time I went to use my AC it did not work. The problem was the line to the compressor was never hooked up.
2004 F-350 Lariat supercab 8ft bed
6.0 w/ Torqshift
Dark Shadow Grey w/ Black Accent
3.73 Limited slip
ESOF, Power rear sliding window, FX4 package
Tele/HTD/lighted mirrors
Pioneer AVIC-N3 navagation/ roof lights
Adjustable accel/brake pedal
Reverse sensors/ heated seats
polished cab steps
MFD 02/04
ISSPRO Guages (Boost, EGT, and Trans Temp)
Diesel Turbo Lifesaver
Sirius Satellite Radio
XM Radio
XM Navtraffic
2004fx4 is offline
Old 04-11-2005, 01:45 PM   #5 (permalink)
jstrauss's Avatar
My truck has 82K miles on it and I have never seen a drop of anything on the driveway underneath. So it ain't all of 'em.
1991 F150 SC 4.9L ZF5
1991 SAE Bronco 5.0L E4OD
1993 F250 4x4 7.3L IDI NA E4OD
jstrauss is offline
Old 04-11-2005, 02:47 PM   #6 (permalink)
People *****ed about the torque converter being rusty so they started putting an oily/paraffin coating on the torque converters. This stuff will sling off and end up as a drip that may appear and can be wiped off and never re-appear.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.88 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 feet on the floor Elite/Outlaw LQ horse trailer. Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 04-11-2005, 02:50 PM   #7 (permalink)
If you recall, Ford conviently changed their motto to "Built Ford Tough", thus showing us their change in their quality focus. [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
<font color="blue">"Sic Semper Tyrannis" </font>
<font color="red"> 2003 King Ranch F-350 FX4 Crew Cab SRW SWB 6-OH!</font>
woodsracer is offline
Old 04-11-2005, 04:00 PM   #8 (permalink)
I am on my second personal V10 and our private company owns 8 V10 and 2 6.0L. No leaks here.
Like all things mechanical, it is entirely possible to get poor seals and improperly torqued components but in the modular motor series I bet the very rare plug blow out is 100 times more frequent than rear main seal leaks.
I take care of my personal truck and the only leaks or seepage in the last 35 years of Ford trucks has been older, near worn out ones. I have never had a leakage "concern" addressed within warranty period on any new Ford product. I guess maybe I am just lucky, or is it perhaps others are not lucky?
White 05 F350 King Ranch 3 valve V10 5R110 Auto 4.30:1LS 4x4 LWB SRW born on 3 Sept 04
fredvon4 is offline
Old 04-12-2005, 12:38 PM   #9 (permalink)
With 56K on my '00, I haven't had a drop from mine yet, or any other problems with the engine thus far. Wish I could say that about the front suspension components and front rotors.
2000 F-250
2005 Expedition
kanertop is offline
Old 04-12-2005, 02:53 PM   #10 (permalink)
99.5 v10, about 90k no leaks. Hmmm but close to an overhaul. [img]/ubbthreads/images/graemlins/grin.gif[/img]
robsd is offline
Old 04-15-2005, 04:13 AM   #11 (permalink)
55,000 miles on mine with no leaks from the engine. Did have to replace a hose clamp on the transmission cooler line right under the radiator though. Caught it before it ever dripped on the driveway.
'00 F250 CC SWB 4x2 XLT V-10 Auto 3.73LS Silver/Graphite
Sport is offline
Old 04-15-2005, 07:54 AM   #12 (permalink)
The V10 has been a pretty good engine and will tow just fine if your wallet can keep up with the amount of fuel it uses. The biggest problem I have seen is spark plugs blowing out. The new 3 valve engine is sweet and uses a different design plug so maybe that problem is behind us now. As far as low mileage oil leaks from the rear of the Ford engines most of the time it is from assembly and not a major problem.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 04-18-2005, 09:04 PM   #13 (permalink)
This is the first time I've ever heard of ANY V10 leaking - I spend a lot of time in the V10 forum on ford-trucks.com, and this is the first I've ever heard of it.
Sounds fishy.
Spark plug blowout is something very rare, there are many of us at the above mentioned forum, and never a one of us has had one let go, it's always someone new that found the site from Google...
Very good engine, good gas mileage for a 415 cube 425ft/lbs monster (in 2001, anyway)...
'01 F250SD V10 auto 4x4 SC SB
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline
