2001 4r70w Hard Shift Blinking Od Light - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 08-23-2009, 10:44 AM   #1 (permalink)
Red face 2001 4r70w Hard Shift Blinking Od Light
well i have a 2001 with 80k miles noticed slip about 65mph but if you pushed in od button to off every thing ok just not overdrive . so i took to tranny shop to have scanned showed 4 codes p0741,p1728,p1744,p0783 they said might be tcc solenoid so i dropped pan put new one in now the od light blinks cant just shut od off and it shifts as hard as my race car no slipping just solid shift any help greatly app.
ohiobigdog is offline
Old 08-23-2009, 10:45 AM   #2 (permalink)
Super_Dave's Avatar
How did you get a 4R70 with a 7.3 PSD? Or is this on a different engine?
Super Dave
2006 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
Old 08-23-2009, 10:51 AM   #3 (permalink)
yes its a gas eng. just found you guys seem to know what your talking about and im pulling my hair out
Old 08-23-2009, 12:40 PM   #4 (permalink)
Banned
Your codes are indicating that a lot more than just you torque converter is slipping... your P0783 is even indicating some sort of 3-4 error.... I am going to hang my hat on some kind of slipping friction element... You might be able to isolate the concern by using a decent scan tool and watching two PIDs... GEAR_RAT (the PCM/TCM knows the ratios built into the trans and will display the gear ratio for the commanded gear) and TRAN_RAT (the TCM can compute the real time gear ratio through the transmission taking into account any slipping friction elements). TRAN_RAT and GEAR_RAT should be lock-step.
GrampyJim is offline
Old 08-24-2009, 05:37 PM   #5 (permalink)
any one else?
Old 08-24-2009, 09:11 PM   #6 (permalink)
Mark Kovalsky's Avatar
Since you didn't seem to like Grampy Jim's suggestion, I'll try something different that's simpler.
It's broke. Take it to someone that knows how to fix transmissions. He told you exactly how to diagnose what's wrong.
Mark
Mark Kovalsky is offline
Old 01-02-2010, 02:20 PM   #7 (permalink)
slamming into 2nd gear
My 99 F250 gas did this and it was just a road speed sensor. The part was under $30 at the dealer and that fixed it.
1999 F-250 SD, V-10 4x4
alwelch is offline
Old 01-02-2010, 05:44 PM   #8 (permalink)
I think you mean vehicle speed sensor (VSS.) There is no such thing as a road speed sensor.
And most likely that's not the problem here. It didn't set a code for that, but it has other codes that indicate other problems.
Mark
Old 01-09-2010, 02:19 AM   #9 (permalink)
klhansen's Avatar
My Photos: (169)
The tranny expert speaks.
Hard or no-start? Check Here
klhansen is offline
