Re: 2001 Expedition Faulty Diode? or Simple Fix? HELP..PLEASE
It's the intermediate one way clutch. This trans didn't get the mechanical diode. Only the diesel trans had that problem. If the intermediate one way fails, it's the same as the mechanical diode failing. The fix on the diesels is to replace the mechanical diode with the one way sprag clutch design that your trans has. It isn't failure proof, either, but it is a lot better than the diode type clutch.
I'm sure it isn't any consolation that it's a sprag type clutch that failed, not a mechanical diode, but that's what happened.
Casey,
I stand corrected. thanks for explaining. Now that I've had time to think about what the tranny guy said he seemed to hint of what you said (About Diesels and Gassers Diode/sprag)but what was key was he said the fix is to go BACK in time and retofit the trannys to 2000 models.Hopefully I can get better results out of the rebuilt tranny! Thanks again for your info. and time!
