Re: 2001 f250 question
The truck's curb weight will be about 6,000 lbs, and adding the trailer, you, friends & family and stuff, you'll probably end up around 11,000 to 11,500 lbs total -- well with both the GCWR of 13,500 lbs. You'll also likely be well within the trucks 8,800 lb GVWR.
Milegae will likely be as noted above. I get 16 or so lightly loaded on the open road, and 11 to 12 commuting in suburban traffic. I got 12.8 towing my 3,250 lb trailer on a long trip this past summer.
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS TTPkg Black/Silver
