Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 02-26-2007, 02:00 PM   #1 (permalink)
2002 V10 which spark plugs?
I have a 2002 Econoline Van with a V10 and was wondering which would be the best spark plug to use. I have stuck with Motorcraft because of plug blow out issues. But the Motorcraft plugs I am using now only have 45,000 miles on them and they are starting to miss. They are all tight in the head and the only thing I can think is that when I towed last summer and had it working hard that the plugs got deposits on them or something.
Anyway, whats your thoughts on the plugs
Andrew.
andrewzx92000 is offline
Old 02-26-2007, 10:58 PM   #2 (permalink)
Re: 2002 V10 which spark plugs?
Don't use Bosch plugs. I used them in my Jeep and within 3K miles I had two of the insulators come apart. I like Splitfire and NGK.
Black 2002 F250 4X4 DIY Tymar, Autometer A-pillar gauges EGT,Boost,Trans Temp, 4in exhaust turbo back, DP Tuner on the way!
99' Jeep TJ LIFTED
too many mods too list-see website
1983 Custom RockKrawler
coming soon to website
Kevin Mathis
www.emptypocketsoffroad.org
kevinmathis is offline
Old 03-05-2007, 06:39 PM   #3 (permalink)
BadDogPSD's Avatar
Most V10 guys recommend using Motorcraft plugs... At almost 50k miles, it's probably time. Make sure you clean out the plug area before removing the old plugs as they tend to collect dirt in the recesses. Also make sure you use a good anti-seize on the plug threads, di-electric grease on the boot connection, and torque to the proper spec when installing the new plugs.
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 03-06-2007, 12:49 PM   #4 (permalink)
I always have luck with the NGK here.
2002 f350 v10 red lots oh goodies.Some call it the "POWERSMOKER".
fasttriton is offline
Old 03-12-2007, 09:31 PM   #5 (permalink)
I changed mine at 100k and they looked perfect !! I used Motorcraft...
If its missing it might be something other than the plugs...
I had to replace one coil pak as it was cracked but it still worked....
I would check all wires first...
Good luck
Tim
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member.
My Truck
twinbulls is offline
