Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 12-07-2007, 08:24 AM   #1 (permalink)
5.4 engine starts and dies instantly after start up
2000 Excursion with 5.4 with appx 100k miles. Sometimes on engine start up the engine starts and then dies. When it does this the only way to keep the engine running is to apply some throttle to keep it at a high idle and after about 10 seconds the engine will rev up without moving the throttle and the truck will then operate perfectly. Very intermittent. There are no indicator lights, and no codes present.
Red, 2000 F-250, 7.3, 4x4 lariet, 35" BFG, 4" lift, Hyperteck chip, K&N drop in filter, Bought new, 2006 Front end,cab lites, little ears, 2008 F-250 6.4 4x4 Lariet, crew, cab lites, moonroof, 20" wheels, 373 gears, instance heat,chome pkg. BTS Awsome trans. 4" exhaust
fedexpsd is offline
Old 12-07-2007, 01:31 PM   #2 (permalink)
Re: 5.4 engine starts and dies instantly after start up
sounds like a vacuum leak
2006 F250 CC FX4 5.4L 3.73 gears, 2007 Palomino Bronco B1251 Truck Camper, 2002 Carolina Skiff DLX16 25hp Yamaha 4 stroke,2004 Kawasaki Bayou 250, 2000 Kawasaki Bayou 220
NEG297F is offline
Old 12-07-2007, 02:01 PM   #3 (permalink)
Or a stuck idle air control motor, if it even has one. When my Mustang would do this that was the culprit.
08' F350 Reg Cab 4WD V10/6SPD/4.30LS
Ugly-Jeep-Truck is offline
Old 12-08-2007, 02:28 AM   #4 (permalink)
DaveV10's Avatar
My Photos: (5)
! second vote for the IAC motor/valve being stuck/dirty. Mom's old explorer needed it cleaned about once a year or so.
2006 F250 V10 4X4 Lariat FX4 SC, SB 142WB,Auto,4:30LS,ESOF,TT Mirrors,Ford Chrome Step Tubes,White over Silver,Chrome Package,- DR 4.5" lift kit with 275/65/20 Goodyears on 08' wheels and stainless flowmaster 50.
DaveV10 is offline
Old 12-23-2007, 11:50 PM   #5 (permalink)
Lightningfast01's Avatar
Pull and clean, tap, or replace the IAC motor and look for an vacuum leak around the PCV elbows as they crack and rot with age.
2005 F250 FX4 SuperCab SWB in DSG
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 12-25-2007, 11:20 PM   #6 (permalink)
fxdwgi's Avatar
Stuck IAC....
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Front Bull Bar w/ K.C. Daylighters * Draw Tite Fold Over Gooseneck * Gauges whited out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics *
Sitting in garage waiting to install: 6.0 IC
The REAL toy....
http://community.webshots.com/album/561972003NGydsT
fxdwgi is offline
Old 12-26-2007, 09:43 PM   #7 (permalink)
My vote is for a stuck IAC. Those things have kept me busy over the years.
2002 F-350 CrewCab Lariat Auto 4X4 7.3L PowerStroke Diesel, DRW, 4.10LS, Camper package, Auto-jet muffler delete pipe, Digital Pyro, Trans Temp Gauge, True Blue, SCMT, DELPHI SKYFi XM Radio
Mastertech is offline
