5.4 No power cold. Runs great cold - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 11-11-2012, 11:41 AM   #1 (permalink)
Ty1
Ty1's Avatar
I have a 99 5.4 which is throwing codes P1131 and P1151. I cleaned the MAF sensor and am now wondering what else. I have read it could be anything. The truck runs great cold....but when it get's warm it gets less and less power the more you push on the throttle. Basically less rpms with more gas (only when it's warm). Runs smooth also. Please help!!
Ty (Dukey)
I may be the average teenage Farmer/Rancher, but everything done to my trucks I did myself!
2006 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, IPR Research Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 tuner, Air Lift Load Lifter 5,000s w/ On Board Compressor System~~
Early 2004 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008 F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
JUST SOLD>>400,000 MILES!!!~~1999 F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
Ty1 is offline   Reply With Quote
Old 11-13-2012, 08:37 PM   #2 (permalink)
akrewat's Avatar
Sounds like you have a major vacuum leak, or some other metering issue. Check the air intake system and make sure there are no cracks or leaks between the MAF and the throttle body.
'01 F250SD V10 auto 4x4 SC SB Volant CAI, ebay headers/y-pipe
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline   Reply With Quote
Old 11-13-2012, 09:26 PM   #3 (permalink)
chuckster57's Avatar
What did you use to clean the MAF?
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 11-13-2012, 09:40 PM   #4 (permalink)
I worked on a 2000 super duty last month that kept throwing misfire codes and acted about the same as you describe. On a lark I took the EGR valve off, cleaned the valve and the EGR sensor (DPFE) fittings on the EGR tube, and the truck is good as new.
Not saying that will fix yours, but youight want to try it.
